Fiveform 2
Flight distance : 136230 ft
Punchbuggy Posted at 2017-6-11 19:48
Can't comment on the other thread referenced. But I upgraded both fine.
I updated the P4P first via Assistant 2, then I powered up my RC with tablet attached. The RC and P4P wouldn't connect, and the RC LED was rapidly flickering red/green - I assume to confirm that action was required. On the tablet I started DJI GO, and on the splash screen I was advised that the RC needed a firmware upgrade - do I want to? I agreed, and it downloaded OK. Then I just needed to power cycled both devices, and performed a manual connection (C1+C2+Record).
I am experiencing the same issue, only in my case, using DJI GO4, the P4P upgraded fine to 1.2.0604 (?) and then no options for RC via Assistant 2 other than factory defaults, but even that wouldn't work. I'm seeing an upgrade notification on GO4 when RC is connected but as many times as I tell it to upgrade, nothing happens, so I'm currently stuck with an aircraft that is upgraded, but doesn't do a video link to the RC which is still on an older firmware. I'm seeing a few possible resolutions on these threads like manual re-linking and getting closer to wireless router, re-installing Assistant 2, etc., etc. I must say that this should be much easier. In the past things didn't work until 5 or 6 reboots of drone and RC, etc. Perhaps a DJI Admin could chime in here like Natalia or Mindy or someone. I need to get the P4P up again with a few jobs fast approaching... |
