Montfrooij
Flight distance : 2560453 ft
If you live in Canada, I can sure see why you want this.
But, it might be hard to take half the weight out of the battery and still have something that flies for more than a couple of minutes, since there is also 'overhead' weight in the battery that will have to remain there (casing, electronics etc.).
Next the AC will be off balance probably, so they will have to do something about that also. (correcting this with just the engines might also cause less efficient flying, even less flight time)
Not sure if you still should want to modify an existing product to this extent.
But I sure understand the reason for Canadians.
