Why is my Cendence beeping?
1946 25 2018-4-24
Cougar1
Flight distance : 924393 ft
After updating the fw on the Cendence RC from .45 to the new fw.90.  My RC is beeping (fast-paced) upon normal start-up (press and hold) of power button, if I shut it down and restart all seems normal.
Why is it beeiping? Tried to look in manual but there is no mention of start-up sounds.
2018-4-24
Mims
Flight distance : 1686991 ft
Since the latest update, I've had this happen a few times too. I've seen an error in the LCD. Something about a battery error. Always goes away after I restart. Other than the warning beeps and having to restart, I haven't had any other problems with it.
2018-4-24
Cougar1
Update: got a response and it seems like it was asking for a calibration. Did a calibration of the sticks (all) after new fw was installed last week. Redid calibration so hope that is it.
2018-4-24
RichJ53
Flight distance : 1837356 ft
Cougar1 Posted at 2018-4-24 16:37
Beeping like what you were talking about means the stick centers were off. Remote calibration will fix this issue and I have had the same problem before
Rich
2018-4-24
Cougar1
Thx Rich, hope that is it.
Edit: if this was only a call to calibrate, why would the beeping not come back when I restart? Seems strange it would disapear if the issue is still there.
2018-4-24
RichJ53
Cougar1 Posted at 2018-4-24 17:27
I have found that if you start up the controller (remote) and have something causing the sticks being pushed off center will start things beeping. I think many things can happen during the start up sequence and if something doesn't report back to the hardware brain....  you get errors or beeping.
Rich
2018-4-24
Cougar, please let us know if the issue persists when you calibrate the Cendence, if yes, is there any error message in the APP?
2018-4-24
Rodger8
Flight distance : 20145135 ft
What Manual?
2018-4-26
Rodger8
Mims Posted at 2018-4-24 15:58
You need to update all of your batteries with the latest firmware and once updated let the sit for al least 72 hours without use.
2018-4-26
Cougar1
The manual for Cendence RC.
2018-4-26
Rodger8
Cougar1 Posted at 2018-4-26 04:07
Where did you get that? I didn't get one with mine and was told that there was none?
2018-4-26
AvatarAir
Flight distance : 150932 ft
Rodger8 Posted at 2018-4-26 04:49
This manual: https://dl.djicdn.com/downloads/ ... _User_Manual_en.pdf
2018-4-26
Rodger8
AvatarAir Posted at 2018-4-26 05:27
This manual: https://dl.djicdn.com/downloads/Cendence/20171106/Cendence_User_Manual_en.pdf
Thanks, I did find that.
2018-4-26
Mad_Angler1
Flight distance : 2741657 ft
Make sure you have calibrated all the knobs and sticks as this can cause this.
2018-4-28
bobo
Flight distance : 1544416 ft
Looks like you may have the new firmware installed. If you do and have the Patch antenna installed the Cendense controller will beep on startup signaling the antenna connection
2018-4-28
Rodger8
Try re-linking the Cendence with the Inspire. Fast beeping usually means that there is no connection between the two.
2018-4-28
Cougar1
Rodger8 Posted at 2018-4-28 17:43
Read post #3, already answered, issue seems resolved. (I hope) No issue with linking, seems to be calibration. Thx
2018-4-28
Rodger8
Cougar1 Posted at 2018-4-28 17:48
In the release notes for the latest update, DJI states to recalibrate everything including your compass and excluding your IMU. I had no issues with my update other than the compass seemed to be a bit out. Yesterday I had the Cendence on and not the Inspire for a few minutes and the Cendence was sounding and kept so even after I turned the Inspire on and I had a firmware warning banner. I powered everything down and back up again and everything was fine.
2018-4-29
Cougar1
Rodger8 Posted at 2018-4-29 04:42
Not sure what you are answering, I also read and followed the release notes, TestFlight went well and all working with the exception of the gimbal issues that has been documented elsewhere as well as some issues with taking still photos.
The Issue with my Cendence started after several test-flights, there where no issues after the fw update. 2 days later RC for some reason had reverted all my custom mapping of buttons, after redoing all my settings on the RC as well as a second calibration, beeping stoped.
My initial question was quite simple, why is the RC beeping? As far as I know there is only 2 resons for this, 1: binding and 2: calibration. So if anyone has any knowledge of any other reason for the beeping, I like to find out.
Lots of rain here so no chance to fly, but will as soon as weather permitts.
2018-4-29
fansc763c176
Flight distance : 3341063 ft
Good morning.  I have the same issue.  My set-up is M210 with Z30/XT, Cendence keeps beeping.  On the PILOT APP, the option to Calibrate controller is not there.  its only on the DJIGO4.  I'm stuck on suggestions.  Other issue we are having is No GIMBAL tilt control on unit now.  It Pans but no up/down.
Lost for Words.
2018-5-11
Cougar1
fansc763c176 Posted at 2018-5-11 04:22
Lost for Words.
Well I still have this beeping issue but not every time. Only way to stop it seems to be to restart the RC.
Have redone the calibration several times as well as reinstalled the Go4 app, still beeps at times when starting RC. My friend also have the Cendence and his RC is doing the same thing.
2018-5-11
RichJ53
Cougar1 Posted at 2018-5-11 04:30
Hi Cougar
I just got back and saw your post. I am surprised you are still having trouble with the Cendence. As you know I have not been using my Cendence for awhile now, but it was working okay since the FW update.
very strange beeping issue for sure. Your friend has the same thing? Why is this not happening on all of the remotes? do you think it something to do with the sticks centering?
As far as the gimbal tilt issue you must make sure you do both gimbal wheel calibrations during the radio calibration (right side did not show progress before new FW).
Rich
2018-5-11
Cougar1
RichJ53 Posted at 2018-5-11 08:19
Hi Cougar
Hi Rich and welcome back, hope u had a great time.
Yes the beeping is strange indeed, had some other issues with all custom setting for the buttons suddenly vanishing  and reset to default. Think that issue has been fixed by reinstalling the app, initially when I updated the fw on the RC,  I never replaced the Go4 app and just updated it and seems like that caused some problems. Haven't seen that since so hopefully gone.
But the beeping persist, have done several calibrations of all the RC but it is still there, not all the time only happens casually. And my flying buddy has exactly the same issue, restart the RC and the beeping is gone.
2018-5-11
Mad_Angler1
Yes this is being seen and it has been reported back to DJI, its not every time but it seems to think a stick is off slightly sometimes and only rebooting resolves it..
2018-5-11
Cougar1
Mad_Angler1 Posted at 2018-5-11 10:57
Thank you Mad for confirming the issue. So I am not the only one, of a select few going Mad
2018-5-11
RichJ53
Cougar1 Posted at 2018-5-11 08:35
Hi Cougar
That's weird for sure and would guess that DJI has maybe set the stick centering tolerance to tight(?)  Glad you are doing okay.
Rich
2018-5-11
