Emacs42
Flight distance : 8520 ft
smbishop Posted at 12-30 12:41
I have had the Pocket 3 for three days and I am doing a bunch of comparison videos between modes and comparing to the Pocket 2. It would be great if there was an easy way to know what mode you are in, like a tag in the file name or something. The Custome file name is great, but really not applicable when doing a multitude of tests. I ended up keeping a record on paper, then manually renaming the files...
Thank you all.
That HLG is marked in the metadata was clear.
> It's easy to tell from the metadata, which files were taken in HLG, but everything else seems to be labled just as Rec.709.
The core of my question was more about DLOG-M vs Normal vs NightMode - as all those are regular Rec.709.
I still need to find and check the comment field in the metadata to see if there is anything in there. But as far as I interpret the answers above, that won't be a complete solution anyways.
Cheers,
Emacs |
