What is the difference between rm700 and rm700b?
2144 29 4-13 06:36
djiuser_9TueQ5W3BG78
South Korea
And Can rm700 adjust agras t20p and m300?
4-13 06:36
Johnnokomis
Flight distance : 14031719 ft
The firmware is the only difference. Both the RM700 and RM700B are covered under a single FCC filing which tells you that there is no hardware difference. The B version only works with the Inspire 3. DJI should really do a better job of telling customers this.
4-14 05:43
DJI Wanda
Hello, there. Thank you for your inquiries. RM700 represents DJI RC Plus (for Enterprise or Agras drones), and RM700B represents DJI RC Plus (Inspire 3).
The remote controller for DJI Inspire 3 cannot be used with other drones.
DJI RC Plus (Inspire 3) cannot be used interchangeably with regular DJI RC Plus (for Enterprise or Agras drones), and there is currently no plan to add compatibility.
4-22 00:57
South Korea
DJI Wanda Posted at 4-22 00:57
Thank you for your answer. Then, can I control the m300 and t25 with one rm700 controller?
4-30 06:40
DJI Wanda
djiuser_9TueQ5W3BG78 Posted at 4-30 06:40
Do you mean to control the two drones at the same time with one controller or use one controller to control two different alternately?
5-1 05:12
Johnnokomis
DJI Wanda Posted at 5-1 05:12
Nobody in their right mind is asking if you can fly 2 drones at once with a single RC. Was that question really necessary? I hunted for an answer myself and only got more confused. Your web page for the T25 says that it uses standard O3 transmission instead of O3 Enterprise like the RC Plus supports. It also says it only has a range of 2km. The Mini 4 Pro has 10x that range.
5-1 11:19
DJI Wanda
Update:
Due to the different firmware, you can not control the M300 RTK and T 25 with one DJI RC Plus controller.
5-2 06:01
DJI Wanda
Johnnokomis Posted at 5-1 11:19
After confirmation with our engineers, I will update here.
5-2 06:03
ManLittle
Flight distance : 443 ft
I think that there is a mistake here, I always thought the RM700B was for M30T / M300 / M350 and that RM700 ( Inspire 3 ) Is only intended for Inspire 3 and it isn't compatible with anything else. Correct me if I am wrong.
5-2 13:02
Johnnokomis
ManLittle Posted at 5-2 13:02
Who knows. They can't keep their story straight because the only difference is for "market strategy". A.k.a screwing the customer.
5-2 17:30
ManLittle
Johnnokomis Posted at 5-2 17:30
Who knows. They can't keep their story straight because the only difference is for "market strategy". A.k.a screwing the customer.[view_image]
Oh yeah I confirm that well as. I can say that boards are identical ( I have dismantled 2 RC Plus ) and only firmware is different for each aircraft. Yup no big deal. But thanks for the info. I like that.
5-2 17:37
DJI Wanda
Hi, there. The model name is correct. RM700B represents the DJI RC Plus (Insprie 3).
5-3 04:38
DJI Wanda
Update:
Considering the size of the Agras aircraft, they are categorized into middle-size UAVs. There are potential risks in controlling the aircraft. Thus, the permitted range for the Agras aircraft is 2 KM.
5-3 04:45
Johnnokomis
DJI Wanda Posted at 5-3 04:45
Update:
I can understand the potential danger there. So then what is the purpose of the DJI Relay module? It seems like DJI has created a problem through software and then sells a solution to that problem via hardware. I don't use this model drone so it doesn't have an impact on me. What does interest me is you stated that the Agras RC Plus isn't compatible with the M300 RC Plus. So if the M30/M300/M350 use the RM700 and the Inspire 3 uses the RM700B. That means there would have to be a third RC Plus for the Agras (RM700C). Because it's been said by admins before that the RC Plus isn't compatible with consumer series Ocusync 3 but the Agras webpage says this is exactly the transmission protocol that it uses.
5-3 10:29
Johnnokomis
DJI Wanda Posted at 5-3 04:38
So why are some of your resellers listing the RC Plus as if there is only one model? The fact that two seperate retailers have word for word the same item description makes it clear that this writing had to come from DJI. Is causing mass confusion what DJI means by market strategy? Screenshot_20240502-222949.jpg
5-3 10:34
South Korea
DJI Wanda Posted at 5-2 06:03
엔지니어들과 확인 후 여기에 업데이트하겠습니다.
제가 원하는 것은 동시에 제어하는 ​​것이 아니라 개별적으로 제어하는 ​​것입니다. 물론 펌웨어 변경이 필요할 수도 있다고 생각합니다. 설명서에는 t25 컨트롤러가 rm700b라고 되어 있는데, 펌웨어를 바꿔서 m300을 제어할 수 있을지 궁금합니다.
5-3 22:21
DJI Wanda
Johnnokomis Posted at 5-3 10:34
So why are some of your resellers listing the RC Plus as if there is only one model? The fact that two seperate retailers have word for word the same item description makes it clear that this writing had to come from DJI. Is causing mass confusion what DJI means by market strategy? [view_image]
We are sorry that we can not control the information on the other platforms. We can only advise our customers to refer to the information on our official information.
5-5 02:47
DJI Wanda
Johnnokomis Posted at 5-3 10:29
The questions raised by you and  djiuser_9TueQ5W3BG78 are waiting for our engineers' further confirmation.
5-5 02:49
DJI Wanda
djiuser_9TueQ5W3BG78 Posted at 5-3 22:21
5-5 02:49
Johnnokomis
DJI Wanda Posted at 5-5 02:47
Yes you most certainly can control this. DJI controls the pricing of every single product that your dealers have listed. DJI has revoked dealer's status for much less. Not selling $100k+ of DJI product annually? You're not a DJI dealer anymore. It's sad because DJI Enterprise relies on third party dealers for most of their customer support but the only metric your company cares about is how much product one is selling. Take my state for example. My state used to have 7-10 dealers listed. Today there is only 1 DJI Enterprise dealer left in my state of over 5,000,000 people. So tell me again how DJI has no control over your steadily shrinking dealer network.
5-5 12:52
DJI Wanda
Update:
1. Differences in the model name:
The model name of the DJI RC Plus is RM700. RM700B is the name after the DJI RC Plus (Agras) was certified and released overseas.
2. Switch firmware to control Agras and Enterprise drones with one DJI RC Plus.
Technically, it does not support due to the firmware.
3. O3 System
Agras, Enterprise, and Inspire 3 all use the O3 system.
The differences rely on the firmware of the products.
Refreshing firmware across the aircraft models is not supported.
5-6 01:42
DJI Wanda
You may check the update below.
5-6 02:22
DJI Wanda
5-6 02:22
Grimtheviking
Flight distance : 12584416 ft
ManLittle Posted at 5-2 17:37
Hi, is it difficult to open the RC Plus? I see on the antenna cable just inside of the mount that the cable is wearing away, Is there a youtube or diagram any where. Thanks,  any advice is welcome.
5-23 11:05
ManLittle
Grimtheviking Posted at 5-23 11:05
Sorry I am seeing that now, can you PM whenever you have time?
5-23 17:21
KAPtureDM
Flight distance : 25385184 ft
The love/HATE relationship we all have with DJI is INFURIATING. Instead of being happy with owning the global market, they went ahead and confused everyone with this so people would buy more of them only for them not to work.
While I’m at it, how about this complete debacle with the H30? They FINALLY tell retailers they can order them yesterday, but delivery date is still a secret. They’re being arrogant children.
7-18 14:36
Renames
Flight distance : 5774157 ft
ok then what about whats shipped with your drones ?
I was shipped a brand new m30t from you guys.. it came with a RM700B ... what you just claimed in for the inspire 3..
Your stories are all over the place
7-21 18:13
Johnnokomis
DJI Wanda Posted at 5-6 01:42
Update:
I'm trying to make sense of your comment and I don't think it can be done.
1. Where does the RC Plus (Inspire 3) fall in this naming?
2. You say "switch firmware" then immediately "It does not support due to the firmware". So why are you suggesting something that is not even supported?
3. They all use O3 which should make cross compatibility fairly easy. The Mini 3 Pro, Air2S, the Mavic 3 and all variants have different firmwares too but can share the RC Pro.
7-22 20:01
Renames
I dont think they have a clue..
Anyhow I am using a RC plus now that covers all my drones thanks to a modification.. its a shame with have to go to 3rd parties to get this when you spend  100k+ on dji gear
7-23 00:35
KAPtureDM
I’m using a RC PLUS RM700B with M30 Enterprise daily for work. All firmware.
8-31 13:47
