Vision System not working
12Next >
5796 45 2018-3-12
aigarart
Hello. Hopefully will get advice here as there is no information on internet about this problem. All is updeted all is on ( not flying on sport mode ) Looks like Vision System is not working ( settings are fine ) I cant see radar on my remote cantrol screen as well. Once more Vision system settings are fine. GPS signal works good (around 14-19 ) I think Vision system never works with my Phantom 4 Pro plus. Didnt check this properly before. Also maybe becouse of this problem drone is totally unstable.
All is updatet, calibration is done (compass, IMU), vision system icon is green. Just cant understand where could be the problem.
2018-3-12
Archangel3356
Flight distance : 4655896 ft
Without enough information about what sensors,  if it’s the side sensors your talking about they only work in beginner mode or tripod mode. If your front sensor are working in GPS mode and the side sensors working in beginner mode your good to go.
2018-3-12
DJI-Mark
Check the app to make sure your sensors are turned on.
2018-3-12
aigarart
Archangel3356 Posted at 2018-3-12 09:30
All sensors, even in begginer mode or gps mode.
2018-3-12
aigarart
DJI-Mark Posted at 2018-3-12 09:54
Thank you Read information again !
2018-3-12
Labroides
Flight distance : 9991457 ft
aigarart Posted at 2018-3-12 10:20
It might help if you actually gave some information to describe what you've observed.
Also be aware that there are limitations to the ability of the sensors.
They aren't magic and won't work in all situations.
The manual explains these limitations.
2018-3-12
aigarart
Labroides Posted at 2018-3-12 13:50
I know about limitations and I know all about magic. I dont need magic at all
What kind of info you need ? This system is not working when it SHOULD work. There is no radar on the screen, icon is green, please dont tell me to check settings I am not on Sport mode, system is not working on beginer mode as well. GPS is fine. Just need some kind of idea what kind of problem could be.
Did all calibrations again. Shoot me please
2018-3-12
Aardvark
Flight distance : 384432 ft
How do you know vision system is not working, what sort of indications or error messages are you seeing, can you post a screen shot ?
If it's just that you can't see the obstacle avoidance radar, then make sure it is toggled on in DJI Go 4, along with obstacle avoidance (Visual navigations settings menu).
2018-3-12
aigarart
Aardvark Posted at 2018-3-12 14:50
There is no messages.  I tested it using my hands, trees, car, wall, door, shed etc etc obstacle avoidance not working.
Does anybody have any idea or just questions about settings
2018-3-12
Geebax
aigarart Posted at 2018-3-12 15:39
'Does anybody have any idea or just questions about settings '
They keep asking about this because it is the most likely problem, and you do not answer their questions. What are you using for a display? I ask that because it may affect what you are seeing on the screen.
2018-3-12
aigarart
Geebax Posted at 2018-3-12 15:47
Settings are fine. Should be enough with this ? No ? I have phantom 4 pro +
2018-3-12
Geebax
aigarart Posted at 2018-3-12 15:50
Is you aircraft still in the warranty period? If so, I would start a ticket and send it back for repair. If not, then I would do it anyway.
2018-3-12
Archangel3356
Seriously? People are trying to help you so why are you being such a child? I’m pretty sure everyone in this thread is done with you. Grow up and try again   Jeez!!
2018-3-12
DJI Susan
Just to verify, have you tried to calibrate the VPS in DJI Assistant 2? You mentioned that you have done the calibrations, but I'm not sure whether the VPS calibration included, please help us confirm, thanks! Also, Thor tried to help you with your last post, but it seems that there is no much progress: https://forum.dji.com/thread-139228-1-1.html In this kind of situation, I'm sorry that we might not be able to help you in a long distance. It is recommended to send the unit in for a full diagnosis at your earliest convenience: http://www.dji.com/support
2018-3-12
Labroides
aigarart Posted at 2018-3-12 14:17
How about telling exactly what you are observing and what you've done, screenshots ... you know, some relevant details rather than just saying it doesn't work.
2018-3-12
aigarart
Archangel3356 Posted at 2018-3-12 20:25
Dont take it personaly. My answers is not angry. That is the problem - there is nothing to show you and if I am saying that you need to believe me. Fanally I showed it to drone specialist and yes there is nothing, looks like everyting should work, settings on app is fine, drone is fine. Solution is to try calibrate again, update firmware again and 99% need to send it back as I still have insurance.
2018-3-13
aigarart
Labroides Posted at 2018-3-12 23:51
Thanks a lot
2018-3-13
aigarart
Geebax Posted at 2018-3-12 15:58
Yes I still have insurance. I showed it to specialist and he said the same as there is nothing wrong with drone.
2018-3-13
Labroides
aigarart Posted at 2018-3-13 00:40
How do you expect anyone to help when you won't give any information?
Would you tell your mechanic that your car doesn't work (and nothing else) and expect him to provide a solution?
2018-3-13
aigarart
Labroides Posted at 2018-3-13 03:04
I would say please change brake pads becouse I would know that I need it. I gave all info needed. Good luck
2018-3-13
Labroides
aigarart Posted at 2018-3-13 03:24
You didn't come here telling anyone to replace a component.
You came here asking for help working out what was wrong with your VPS.
But you don't want any help.
You just want to be annoying.
2018-3-13
aigarart
Labroides Posted at 2018-3-13 03:31
Relax and read my first question where I said there is no problem with settings !!! Posted here as I thought maybe someboday had the same issue. You dont know what I want and what I dont want. If there is info that there is no problem with settings ( or ussual problems, calibration etc ) maybe you need to think about it ? And if you dont know how to help and never had the same issue maybe you need to add coments somwhere else ? like insta or FB about setting problems when someboday dont know what settings should be becouse cant check out info on google or youtube. Relax and fly with your drone
2018-3-13
Labroides
aigarart Posted at 2018-3-13 03:42
You can type all that unintelligible and meaningless garbage but can't provide any info at all.
I give up.
2018-3-13
Labroides
2018-3-13
aigarart
Labroides Posted at 2018-3-13 04:20
'' unintelligible and meaningless garbage'' ''can't provide any info at all''
Excuse me. Siriusly ?  Are you sick ? Good luck man and take care.
2018-3-13
Aardvark
Have you sorted your problem as per other Post
Did switching from ATTI mode to P mode resolve your problem ?
2018-3-13
aigarart
Aardvark Posted at 2018-3-13 04:51
No unfortunately. Looks like DJI never had this problem before, I talked to support as well. Always there is or should be some kind of error message if VPS is not working. In my case all is fine, no messages. VPS works normaly ( DJI app info) So they asked me to send it back.
Did VPS calibrations (assistent2) compass,Imu few times, remote - compass, linking etc. factory settings. No result.
2018-3-13
Aardvark
aigarart Posted at 2018-3-13 05:01
Sending it back is probably the best option then given the information provided. The returns process to the Netherlands should be quite straight forward. I have dealt with them once in the past and it took ten days from sending for my Mavic to return with a new RC unit. Of those ten days eight were when the unit was in transit. So a two day turn around at DJI.
2018-3-13
aigarart
Aardvark Posted at 2018-3-13 05:11
information provided - maybe you are right
Well hope so, need my drone back until 18 of april
2018-3-13
DroneDriver
Flight distance : 1164226 ft
I am just an observer. I do not own a P4. I like to see the community work with others to learn.
A lot of people come here for help because they do not know everything they might need to know. Funny, though when the online community here, asks, the very same questions that everyone is asked when they need help, people like this all of a sudden DON'T know what's wrong but THAT can't be it.
An attitude check in order to get along here, goes a long way. It's called humility, look into it.
Being a jerk with jerk-like responses followed by a cute smiley face emoticon does not portray you as humble.
Just my humble opinion...
2018-3-13
aigarart
DroneDriver Posted at 2018-3-13 10:11
hello and  thanks , what else ? Should be something more. I am listening and of course --> :) :)
2018-3-13
DroneDriver
aigarart Posted at 2018-3-13 10:21
No, you go ahead.
2018-3-13
aigarart
No no thats fine. I am listening I can feel you have a lot to say.
2018-3-13
Labroides
aigarart Posted at 2018-3-13 10:55
What a total tosser.
Don't expect any help next time you need it.
2018-3-13
aigarart
Labroides Posted at 2018-3-13 13:51
Call your GP, looks like you need some special attention. Not sure if you need to be so rude !
2018-3-13
DroneDriver
An ah-ha moment. I understand, now.
Most of the people who come here do a lot of thinking, I'm sure because you have to use your brain to successfully fly a DJI drone, not that much, mind you, but you do have to think.
We use words here, to create conversation and subjects to THINK about. We do NOT come here due to our FEELINGS. We don't make decisions due to our FEELINGS.
If anyone needs a GP, it would be somebody who has his brain functions mixed up with his nerve endings.
Also, according to my humble opinion that would be someone who  has to have the last word and could not pass the opportunity when there is absolutely, no more to be said.
So, go ahead tell us what you are FEELING.
2018-3-13
aigarart
DroneDriver Posted at 2018-3-13 15:56
Dont know why you still posting here this khm... I am working and its so funny to read your stories \Keep going show me your brains ;)
2018-3-13
DroneDriver
I will if you show us some more of your feelings
2018-3-13
DroneDriver
By the way. How's that working out for you to get help on your drone. FEEL ME?
2018-3-13
aigarart
DroneDriver Posted at 2018-3-13 16:12
Why you are so interested in my feelings. Thats strange. Keep going.
2018-3-13
12Next >
