Can you track yourself via the main camera on an iPhone?
4917 6 2018-7-25
fans01b6162a
I just bought my Osmo Mobile 2 yesterday and getting to grips with how to use it today.
I really want to use the device to film videos of myself out in the field demonstrating macro photography using an iPhone 6s.
I've worked out how to do the video tracking on the facetime camera ie the one facing you. But the resolution on this camera is low. I want to use the main camera to get the full resolution of the camera. But how do you select yourself when you are facing the camera and you can not see what's happening on the screen?
Am I missing something obvious?
All the best,
Oliver
2018-7-25
DJI Tony
Hi, I would like to clarify first, are you trying to track yourself using the camera which is located at the back of your iPhone 6s, not on the front facing camera?
2018-7-25
Brolly99
DJI Tony Posted at 2018-7-25 11:17
The front/rear camera thing is a little confusing.
To try and make it as unambiguous as possible.
When the iPhone is attached to the Osmo so you are using the camera that is facing you. I’ve found it easy to see your face in the camera and therefore select it.
Using the main camera on the other side of the phone. There’s no way to see your face on the screen. Therefore how can you select it?
Using the main camera the selecting works as I did on a friends face. But for me one of the key things I wanted to do was use this in the field on my own and use the main camera to track me.
Is there a way of doing this?
Oliver
2018-7-25
LouisP
Flight distance : 41952 ft
I think that you would have to have someone else select the target (you) for tracking.  Unless there is some sort of remote screen app that would let you control the phone on the osmo from another phone in your hand.  I have never seen an app like that but that doesn't mean that one does not exist.
2018-7-25
Brolly99
LouisP Posted at 2018-7-25 13:27
That was sort of the conclusion I was coming too. Not being able to use the main camera (which is by far the better camera on the iPhone6S) to track myself if I'm on my own (which I often am on these shoots) is a bit of a limitation.
2018-7-25
8TrackMind
Brolly99 Posted at 2018-7-25 13:48
One great idea would be for DJI to incorporate simple gesturing in the GO app for the Mobile 2, like in their drones. There, you just make a picture gesture with your hands, and after 5 seconds the drone will take a photo. Something like that for the gimbal app, except with starting video instead of taking a picture, would be really helpful.
2018-7-25
fans03055fca
Flight distance : 6591 ft
8TrackMind Posted at 2018-7-25 17:16
I have the same issue and cannot track myself and I believe this should be solved asap as with COVID19 not so many people are around to help setting the Osmo in tracking mode :-(
2020-4-22
