Buzzyone
Flight distance : 4647913 ft
The USB-A connector can be used for a 4G dongle, it can also be used for USB SD card readers, it won’t recognise USB SSD but I suspect this is more to do with the size limitation of 128gb max card size. Which is handy if you have increased the internal storage with a card in the slot on the controller.
You can also connect your smart phone and share its picture library with the explorer on the controller.
A connected smart device will charge from the SRC.
The Go4 App on your smart phone won't connect to the controller, so you cant use your smart phone as a backup to the SRC display.
Edit .. You can use an SSD if its the right format! MSDOS - FAT32 - not formatted on a Mac, it doesnt seem to like that.
