With some of recent updates I start to get often IPhone crahes with DJI app, some of them in the middle of the flight.
Also I got winter specific problem. IPhone battery die in cold. It can go all the way from 90% to 1% in 1-2 min. So far I alwasy be able to restart phone, warm it up and return drone back to home. But to my surprise it is not returning by automatically. Just yesterday I have scary case when drone with 50% of battery was above waterfall and I try to warm-up my phone to return it back.
Hi there, we're sorry for the inconvenience caused. Regarding that, please make sure you have enough storage to avoid app crash. I suggest you uninstall or delete some unused app and make sure you are only using the DJI Go 4 app in the background. I hope this helps. Thank you.
DJI Natalia Posted at 2-10 16:44
I have a lot of free space on the phone and typically kill all other apps before I start DJI app. Will try to get more accurate repro steps for this issue.
MaxKazi Posted at 2-11 07:14
IPhone SE (Fimware 7.32.00); 128 Gb (78 Free)
Current iOS 12.1.4 (updated yesterday)
The SE puts you on the outermost limit. That little A9 chip is going to be running at max, get hot in short time then begin to slow its self down to prevent overheating.
Try this, in this order:
To improve iPad/iPhone performance while flying (as part of preflight)
* Remove device from case (causes heat build up)
* Close all running apps (force close)
* Turn off cell service (not airplane mode)
* Turn off Bluetooth (not airplane mode)
* Turn off WiFi (not airplane mode)
* Shut Down device
* Turn on device
* Adjust volume to max
* Adjust brightness to max
* Turn off video cache in DJI Go app
* Shade device with your own shadow when possible
Any thing you can do to lower the demand on your iPhone and anything you can do to keep it cool will help.
* Completely shut down & restart daily more often with high use
* Turn off auto brightness
* Turn off automatic download updates
* Turn off all notifications
* Set ALL app Location Services to Never or While Using the App
* Don’t use Dynamic Wallpapers
* Turn off Live Photo & turn on preserve Live Photo setting in camera settings
* Turn off background app refresh
* Remove unused apps at least offload
* Remove or move to iCloud, photos, movies, music & podcasts, to free up as much storage/working space as possible. Shoot for 50% of total space free.
No idea what may be going on with the battery life? My be bad could be heat sense you are able to restart.
Use the return home button on the controller if you louse phone the controller is still connected.
Suggest You avoid flying around potential hazards such as waterfalls until after you test and verify your equipment .
Grumpy D Posted at 2-11 07:39
the A7 processor with 1GB LPDDR3 ram on iOS 12.1 and 12.2 doesn't seem to mind it too much..
i imagine higher clocked Apple A9 with faster 2GB of LPDDR4 of ram handles it better
as for why its crashing.. idk...... OP may need to delete the app and reinstall.. dji go app isnt that well designed, probably something broke in the app during OS upgrade.
as for all those optimizations mentioend above me by another poster.... Apple already suspends most in background if something chewing up resources.. i just suggest airplane mode while flying.. prevent interuptions with people calling or texting you, and suspends apps/services that trying to communicate and update and refresh in background until internet is restored... and other suggestion i will make is remove heavier social media apps that love to talk in background.. like facebook/FB messanger, and twitter for example.. i actually getting alot of lag and cpu load errors on my iPhone X in dji go app before when i had heavier social media apps installed.. i actually uninstaleld them and my problems melted away..
Have you tried force quit the app and open it later? Or how about force restarting your iPhone? Besides, make sure that you have enough storage space, which in some ways, prevents the app from becoming crashing. Finally, if you are willing to use a third-party tool, then you could employ professional iOS system repair programs such as TunesKit iOS System Recovery to fix your issue.
Tiana Posted at 2020-10-26 21:46
I searched on every forum on internet and eventually end up fixing this by disabling the offloading of unused apps on your iPhone is a simple process. Here's how to do it:-
1. Open the Settings app on your iPhone.
2. Scroll down and tap on App Store.
3. Locate the Offload Unused Apps option. It will likely have a toggle switch next to it.
4. Tap the toggle switch to turn it off. The switch should turn gray to indicate that offloading is disabled.
If you have problem persist after trying these step, follow for more details instruction below.
