Phantom 4 Pro V2 Video Issue
667 16 2020-12-4
Tokamajiro
Hi everyone!
Sometimes I record video with my device and I get some ondulations on the image wich I cannot identify its cause. Someone here could help me with this?
If you see the video at 1:30, you'll se a soft ondulation. That is a problem tha I have with some videos. Any idea?
2020-12-4
Tokamajiro
You can see better this effect I'm talking about in this video downhere, at 1:30 min.
https://www.youtube.com/watch?v=3-TX5crrr-Y&ab_channel=AlexCornelles
2020-12-4
JetSam
Flight distance : 3462946 ft
2020-12-4
JetSam
same video mate !! Did you suffer a crash ?
2020-12-4
JetSam
1º Make sure you are using the correct Sd class 10 Card apropiate for your device
2º Try to fly using Plane mode in your mobile device to avoid unwanted Process running below ...
2020-12-4
JetSam
La ondulacion es notable en la parte que  señalas , yo intentaria tambien Reinstalar Firmware a ver si se soluciona : https://www.dji.com/es/downloads ... t-dji-2-for-phantom
2020-12-4
DJI Gamora
Hi, Tokamajiro. We're sorry to read about the problem you're experiencing. Could you confirm whether this issue happens most of the time and if you encountered any flight accidents prior to the start of this issue? Do you also have any ND/PL Filters installed during that flight? Please let us know.
As an initial suggestion, we recommend that you perform a quick gimbal auto-calibration and refresh/update the aircraft's firmware thru the use of the DJI Assistant 2. You may also check whether you're using a suitable SD card for your aircraft (Write speed ≥15MB/s, Class 10 or UHS-1 rating required, Max Capacity: 128 GB).
Kindly keep us updated.
2020-12-4
Tokamajiro
JetSam Posted at 12-4 10:55
I know haha, didn't know how to remove my comment. I haven't had any crash...
2020-12-5
Tokamajiro
DJI Gamora Posted at 12-4 23:59
Hi!
It happens mostly with slow camera moves or static recording.
I've not had any accident with the device, and the micro SD card I'm using is a 30 Mb/s one. Also, I haven't installed any filtres on the device and I make regular calibrations and firmware updates as soon as required.
It doesn't happens allways but It usually ruins my work.
I've had sometimes really agressive Flicker effect while reccording but I don't know if it's related. I'll try to bring more exames of both issues as soon as possible.
Thanks!
2020-12-5
Tokamajiro
JetSam Posted at 12-4 11:05
Lo revisaré, muchas gracias!
2020-12-5
JetSam
Tokamajiro Posted at 12-5 01:08
Revisa la opcion anti flicker en la app , quiza tenga algo que ver , espero que no este en auto
2020-12-5
Tokamajiro
Here you can see the flicker effect I talked you about. I don't know if it's because of sun incidence on the propellers and the camera position or there is something else. There are some recordings that I cannot guess why this effect appears.
https://www.youtube.com/watch?v=mnwbm-Qk20c&ab_channel=AlexCornelles
2020-12-8
JetSam
2020-12-8
JetSam
Tengo un Phantom 4 . el normal, y a veces tambien me hace esas rayas, dependiendo de la calidad que use, a veces sale y otras no ...... una rayada jaja
2020-12-8
Tokamajiro
Here in this video you can see again that anoying jelly effect. I don't know why is this occurring.
https://www.youtube.com/watch?v=PiG4Y2fj6DA&ab_channel=AlexCornelles
2020-12-8
JetSam
2020-12-9
JetSam
If your device is still under warranty, I would use it
2020-12-9
