Maxx2206
IftiBashir Posted at 7-22 00:36
The above mod will take your suggestion forward (a scripted response) but this won't happen.
The attached mod (display or power) acts as the 'brain' of the system, so it is needed for any data transfer. Data transfer cannot happen with the camera module alone - this is why we see so many third party cases with an external USB-C pass through for charging only - NOT data transfer.
Hi,
thanks for your view, but technically it doesn't make much sense.
The point is, for a static setup you don't need a battery, which obviously is what takes up most of the space in the battery and screen module.
Reduce the mount to just the sd-card socket, the usb socket and the controller circuit and it shouldn't be bigger than the smallest passive mount alone.
That's all I would ask for...
PS.
And tbh... while at it I would like to add another annoying thing which seems to be related to USB-C spec limitations... make it 2 usb-c sockets.. one purely for powering reasons.
That way we could finally use extgernal mics AND a power source at the same time with the Action 2 (which sadly is not possible right now, no mater how many different ways people try). |
