Nickel_
India
djiuser_zDGXL5BI8UIp Posted at 9-24 01:09
I also tried with the local adapter, it didn't work.
Taking the suggestion, technica adapter is so bulky and expensive too. I tried with the one plus adapter too, but that didn't work. But I have seen many videos where just a regular adapter was working fine. I talked with the support, they said unless you try with the DJI adapter, they can't make sure of anything. I'm not getting hold of DJI adapter online, don't know if it's available. Can you guys please suggest a proper adapter which is small, available on a budget and working properly. I mean it should be convenient for cycle or moto vlogging.
The adapter isn't working because it doesn't have DAC built into it. Action2 can only deal with digital signals. So adapter should be capable of converting analog to a digital signal. Try Apple adapter/ old Samsung ones / search for DAC aux to USB C. This fixes the issue, but I've tried using it with my helmet, the gains are too much and the audio is creepy. unusable! We don't have a software workaround for this at the moment, the only way is to connect a gain controller to your mic and adjust to a minimum |
