G1tgudscrub
Flight distance : 1434603 ft
So I'm designing some mounts for the Action 3, which I don't own yet.
Does anyone have measurements of the Camera body? Online, it seems the online dimensions of..... 70.5mm x 44mm x 32.8mm includes the lens. Which made my first mount pretty much invalid, as when I overlayed a top down view, i could tell I was clearly off. I also want to ensure I can clear both side doors, allowing the mount to be minimal by design and have full access to battery/SD or USB if needed.
Also any help with the spacing of the index points of the magnetic mount would be helpful, including the cross sectional shape of the index point of the Action 3, and relationship to the body would be a greaaaat help.
Lens cover diameter and height would be helpful as well...
From just extrapolating photos and sizing to my model, i'm guessing the Lens height is 4.00mm, with a diameter of 33.00mm (no rubber? w/ Rubber what size?), but I need a more exact measurement.
Ideally I'd like at least XX.XXmm Accuracy, but XX.X0mm accuracy is acceptable.
Thanks.
