Issue with flying
768 10 2022-11-29
Ezra1
Israel
Hi,
When I try to take off my Mavic air all the propelors are working but the droan just circle and not take off the ground.
Looks like the right front propelor is not turning as fast as the others so the draon circle around it and not taking off.
I replaced the propelor with no luck.
Any idea what is the issue?
Ezra
2022-11-29
DJI Gamora
Hi, Ezra.  Thank you for reaching out and we're sorry to read about this. May we ask how were you trying to take off the drone? We will wait for your update. Thank you.
2022-11-30
Vofas
Flight distance : 200853 ft
Russia
Hello! Check if the propellers are installed correctly.
2022-11-30
Ezra1
Israel
Hi,
I just uploaded a Movie that shows the issue - https://youtu.be/lnB4yGyA3L4I
I  also tried replacing the propellers with no success.
As you can see all propellers are working but seems that the right front propeller might be turning slower and when the droan try to take off it just roll over.
Ezra
2022-12-12
Ezra1
Israel
DJI Gamora Posted at 11-30 01:35
Hi Gamora,
I tried in few places, not in  restricted areas.
2022-12-12
Mobilehomer
Flight distance : 18150351 ft
You have the wrong propeller on the right front. I can see in the video. Pot the correct one on.
2022-12-12
Ezra1
Israel
Dear Mobilehomer,
Thank you for the quick reply!
I will purchase new propellers and replace them.
I will advise back.
Ezra
2022-12-12
Sean-bumble-bee
Flight distance : 15997 ft
Mobilehomer Posted at 12-12 06:46
Good eyes Mobilehomer.
2022-12-12
Sean-bumble-bee
The props are handed for clockwise and anti clockwise rotation, put a wrong handed prop on a motor and the prop tries to push that motor into the ground.
I would have thought DJI would have made that impossible to do with what looks to be quick release props, I can't woith the M2P/Z but I recently noticed you can do it with the FPV
2022-12-12
UKMoose
Flight distance : 3657552 ft
Here you go.
2022-12-12
DJI Gamora
Ezra1 Posted at 12-12 06:38
Hi Gamora,
Hi, Ezra.  Thank you for the update and for providing a video. Just like what our fellow DJI Pilot mentioned, please check your propellers. Make sure to attach the propellers with white marks to the motors with white marks. Press each propeller down onto the mounting plate and rotate in the lock direction until it is secured. Attach unmarked propellers to the motors without marks. Please see the photo below:
We hope this helps. Please keep us posted. Thank you.
2022-12-13
