Sean-bumble-bee
Flight distance : 15997 ft
I am afraid that with respect to my "weaker" binding I disagree with DAFlys with regards to the controller. If, by some quirk, your drone does have the stronger binding then his concerns are valid.... but, if that were the case, I think you would have already discovered that the drone was grounded.
In my experiments I saw no mention anywhere of binding the controller to the drone and WAS NOT able to do that. I WAS however able to use any of the 5 controllers available to me to fly the drones, I think I bound at least 2 of the drones and might have bound the third.
As I said, if you can currently fly the drone with no warnings about the drone being bound and grounded, then I think you have the weaker binding the same as I was able to establish.
I have no idea of the interaction of binding, weak or strong, and Geo Zones ............ BUT......... given that the RAF etc. use Scotland as a low level flight training ground I would be very wary of Geo zones, the idea of an encounter with one of the sheep shearing aircraft scares the crap out of me.
I very much doubt that, using the scrap of the email address that you can see, you will be able to get in contact with the original owner, it has happened but it must have been an unusual email address. However, if you contact DJI Wanda by PM SHE may be able to contact the original owner on your behalf, she will not be allowed to give you the contact details of the original owner, hence my stressing 'she'. She will need a certain serial number but would have to tell you which serial number that is. The original owner can then remove the binding in their FLY app, they DO NOT need to connect the App to the drone i.e. they could be in Timbuctoo and still unbind the drone. Once the App has connected to the internet and the unbinding registered your App will, when connected to the internet, see the change in status.
