DJI Paladin
Albator74 Posted at 10-9 19:39
ok thank you, so the fly more kit for the Mini pro 4 is actually the same as the mini 3 pro ? are there any differences I should be aware of ? thanks
Hello! You can purchase the accessory pack of DJI Mini 3 Pro to use with DJI Mini 4 Pro. However, please keep the following points in mind:
1. Due to inconsistent batches of propellers' screws, there may be variations in screw thickness. While mixing them could potentially cause a slight probability of image shake during shooting, it will not affect the overall flight performance. We recommend using the same type of screws for optimal results. For more detailed information, please refer to the diagram below.
2. The aircraft will weigh more than 249 g when DJI Mini 4 Pro is used with the DJI Mini 3 Pro standard battery or battery plus. Therefore, registration with a civil aviation administration is required. |
