CruxisX
Flight distance : 2146 ft
If it's tipping over forward on take off, it sounds like one of two things:
1. the propellers are not installed properly, check the direction of the props are going in the right direction
2. the connections from the ESC's to the main flight controller are installed incorrectly. Make sure that M1 is the front right motor, M2 is the front left motor, M3 is the back left motor, and M4 is the back right motor.
I've had this exact same issue before. Once it gets up in the air without a problem, let me know if it has any other problems. |
