Flight distance : 2560453 ft
nucmanchh Posted at 2017-9-9 16:37
I'm a still photograher enthuiasts - new to drone photography/videography. But to answer ur question, no i didn't speed it up in editing. On one shot segment I did use 'sport' mode. But that's it. The software I used was Filmoa. I have no idea about frame rate so I had to have used the default rate.
I'd like to hear more -so I can learn. Can u explain further?
Ok, that sports mode will explain a lot.
That causes for abrupt movements indeed. Not too good for taking video.
(but a ton of fun!)
The framerate of the Spark is limited to fps (or something like that) and if you edit / render in a different framerate it causes the motion to 'stutter'.
(because every xx frame is dropped)
Not sure if that is the case here, but you can check in the rendered file in it's details. It will tell you the framerate. |
