New Spark Firmware Released (31/10/2017)
40111 229 2017-10-31
Oracle Miata
Flight distance : 3759829 ft
Just updated, can't find the 360 pano?
2017-10-31
Flight distance : 10186312 ft
Convert Posted at 2017-10-31 07:15
To confirm - 2.4ghz wifi option has now disappeared. So if you are in the EU especially and using 2.4 made a significant difference to your usability where you live this might be a firmware upgrade to avoid.
Also with assistant this time it did not seem need to be done for every battery - I put a new battery in and it still showed up as having the latest firmware. I did it for every battery just in case anyway.
Are you sure option for 2.4 is missing, also not a battery firmware update.
2017-10-31
Wachtberger
Flight distance : 261509 ft
hallmark007 Posted at 2017-10-31 09:20
I got the firmware update for Spark and it installed well. But I did not get an update for the batteries. Should there be one today?
The 2,4 Ghz issue has been answered in 38#.
2017-10-31
Convert
Flight distance : 6129 ft
see further posts about 2.4/5.6. No idea about battery - does not seem to be one. But when the last two firmwares were launched (.600) I can't recall it mentioning the batteries firmware specifically though it did happen at the same time.
2017-10-31
Convert Posted at 2017-10-31 09:27
Yeah there is no battery FW update, sorry should have read on thank you.
2017-10-31
Wachtberger Posted at 2017-10-31 09:25
Thanks Watchberger, should have read on, No battery firmware they are very few and far between, we might get one if they ever bring out higher capacity battery, just 4 extra minutes would suffice.
2017-10-31
dzp
Flight distance : 79 ft
I have updated Aircraft Firmware: V 01.00.0701
I find problematic Pano 360 mode.
I can not process the image successfully.
I dropped out of the program before successfully.
ิby DJI GO 4 App iOS: V 4.1.15   ios 11
2017-10-31
ZukySpark
Flight distance : 226066 ft
Portugal
How mant photos take Sphere pano?
2017-10-31
djiuser_Kf4iPA3
Flight distance : 510968 ft
Israel
Wachtberger Posted at 2017-10-31 08:39
Thank you for the information, that's interesting then and it will probably again take two weeks or so before it becomes available for all of us in Playstore...
What did the release notes say for your 4.1.14 concerning changes in the App?
4.1.14 for Android has just appeared in apkmirror too.
2017-10-31
JxckSweeney
Flight distance : 634692 ft
Yes sphere pana finally who else is hyped
2017-10-31
Quad-Ken
Flight distance : 20810 ft
I'm psyched about the spherical pano but my DJI GO4 app is stuck at V 4.1.12 and the IOS app store says that I am up to date. Guess I have to wait for it to catch up before I can give the new feature a try!
2017-10-31
need4speed
Flight distance : 64423 ft
I'm interested if IOS with OTG still works without Problems? There's a rumor that max. high is limited to 50 meters while using OTG.
2017-10-31
Kloo Gee
Flight distance : 16783757 ft
I updated my Spark via DJI Go 4.  When I changed batteries, I got an "inconsistent firmware" message and had to run the battery update.  It did this for each of my 3 additional batteries.
EDIT:  The reason I had to update my batteries was because I was one of the lucky few that had installed the 0700 firmware.  This firmware had an incorrect version of the battery firmware and was part of the reason they rescinded that version after a couple of hours.  Because of this, when I did the 0701 update, it had to put the correct battery firmware version in place.  So if you are coming directly from the 0600 firmware, you will likely NOT have to update your batteries like I did.
2017-10-31
Anuvis
Flight distance : 1976736 ft
no battery update for me too
2017-10-31
N8m888
Flight distance : 80535 ft
In CE region 2.4g is 300m and 5.8g is500m.
With fw0701 set to auto will RC change from 5.8 to 2.4 once at or beyond 300m ?
2017-10-31
N8m888 Posted at 2017-10-31 11:31
Other way around 300m 5.8ghz 500m 2.4ghz.
2017-10-31
N8m888
hallmark007 Posted at 2017-10-31 11:48
Yes you are correct......my mistake.
Do you know if it will change channel ?
2017-10-31
Zbig
Flight distance : 7349 ft
Being the geek that I am, I found the ESC's updating one by one in sequence immensely cool
2017-10-31
N8m888
Do you know if it will change frequency ?
2017-10-31
Zbig
N8m888 Posted at 2017-10-31 11:56
Almost certainly not. They wouldn't risk dropping the WiFi connection, then reestablishing it - and possibly failing - on another band in flight.
EDIT:
Apparently it does, after all: https://forum.dji.com/forum.php?mod=viewthread&tid=118078&fromuid=1140654
2017-10-31
N8m888
Zbig Posted at 2017-10-31 12:01
Ah ok thanks.
Seems what we in CE regions really needed was to be able to select 2.4g with auto selection within the allocated 2.4 frequencies
2017-10-31
Zbig
N8m888 Posted at 2017-10-31 12:05
Ah ok thanks.
Yes, I find it perplexing that after all the feedback here clearly indicating that we needed to lock our Sparks to 2.4 GHz but still have it choose the best channel on this band automatically, they went ahead and implemented it kinda-sorta-not-quite-right.
2017-10-31
medyq69
Flight distance : 15358 ft
Hi, i had problem with update - succesfully went only with dji asistant 2 - without  asistant updateing stopped at 0% - i played 2hours to try it without assistant.
After update I confirm that choosing  wifi band is related with channels. If u choose lower one u run in 2,4 if u choose above 1xx channel u run in 5,8 band. What is important for us - 2,4 stays after dron turnoff/on in custom manual settings
One issue is app version  - for android in Poland current one in play store is 4.1.10 atm so cant test spherical pano (still got 3 panos icons - imo should be four?) Probably firmware is prepared for new options but now we will wait few weeks for apps?
2017-10-31
ddavewoods
Why do I only have app V4.1.12 and have no spherical option in new .700 firmware IOS 11
2017-10-31
ddavewoods
Mullheliflier Posted at 2017-10-31 06:14
I just updated my Spark with ease. However, I do not seem to be able to select 2.4ghz now, only 5.8 now showing on my iPhone 6S. This is frustrating as 2.4 had a good range. Maybe I have missed something.
Set the slider to manual and select a lower channel this will switch to 2.4
2017-10-31
Rubik
Flight distance : 1224921 ft
Hello everyone, I am introducing myself as Rubik. I am just seeing if I am welcomed onto this forum.
2017-10-31
ddavewoods
If you set the slider in the WiFi section to manual then select a lower Chanel that switches to 2.4 G
2017-10-31
ddavewoods
2017-10-31
His415
Flight distance : 105853 ft
I thought the same thing, but If you choose the manual mode and then scroll left right on the channel numbers you'll see the 2.4ghz numbers there.  1-11
2017-10-31
ddavewoods
Bluedot Posted at 2017-10-31 07:20
I just read in another forum, that by choosing the channel you indirectly also choose the Wi-Fi Band: higher channels are located in 5,8 GHz, the lower ones are located in 2,4 GHz.
Can a more tech savy person confirm that this is correct?
Correct in manual mode select a lower channel in the 2.4 g band
2017-10-31
Rubik
The latest firmware downloaded and uploaded to my Spark without any issues. I pressed the battery button for approx 6 seconds (2 bleeps) for WiFi tablet connectivity and the downloaded firmware update just followed from the tablet to the drone. My several batteries didn't appear to require the update file. What would improve this drone is to abolish the silly EU rulings and enable all Spark drones wherever they are to have FCC outputs and to stop this discrimination.
2017-10-31
chris jhun
Flight distance : 52 ft
United Arab Emirates
After updating my Dji go 4 app and spark firmware i started getting this pop ups, i tried 5 times today to remove and reinstall the apps but still im getting the same pop up message please help DJI
2017-10-31
Wachtberger
Rubik Posted at 2017-10-31 13:02
Since you are heading for Brexit, just request this to your government as priority action (sorry, couldn't resist to this one)
2017-10-31
DrawsWithLight.
Flight distance : 2136716 ft
TuanPham Posted at 2017-10-31 06:52
I stucked with the update and could not use my Spark now...it said FAIL TO UPGRADE ERROR CODE (0x000000). Please help.
Are you connected to controller via OTG, that's the message I got at first when using OTG. I reverted to WIFI and it worked fine.
2017-10-31
Wachtberger
DrawsWithLight. Posted at 2017-10-31 13:56
Firmware update does not work with OTG connection, only via WiFi or best with DJI Assistant.
2017-10-31
nixuspix
Flight distance : 2864974 ft
Latvia
Are the relevant update for Crystal Sky on the horizon? We are still sitting on go4 4.1.6 version, after paying these big extra bucks for better monitor, not justice
2017-10-31
kev001
Flight distance : 251778 ft
Good work DJI .. Happy with the custom 2.4ghz and not having to restart (android 4.10)  However keen to stop using the OTG cable with 2.4 and remote.  Has anyone got a process for this (UK)
2017-10-31
jyc
Flight distance : 2261319 ft
Rubik Posted at 2017-10-31 12:50
You bet you are welcome!
2017-10-31
Todd in Chicago
Flight distance : 513757 ft
Since my Spark is less than a month old, this is my first firmware update.
I know there is a lot of excitement, and I was too.  However, in seeing whats in this update, for me this update really doesn't have anything that I think I would be that interested in.
None of these things fix problems that I had.
I do hope that everything is rock solid stable, and improved security would always seem to be a good idea.
So I anxiously await the next update already!  :-)
As I mentioned, I'm new to this.  One thing I've heard folks say is you'll need to update each battery, but that must only be if you update the DJI Go 4 app.
I successfully applied my firmware, and the shut everything down and restarted everything to make sure all was good.  It was, so I shut everything down again, and put in my second battery and started everything up again.  It said I was good to go, which I thought was weird.  So I tried my 3rd battery using the same shutdown/startup process, again, no update needed.  So is that right, the batteries are updated when you get a new App version, and not a new firmware version?
My Android app is stuck on the .10 release for now.
Cheers...
Todd in Chicago
2017-10-31
Kirbz252
Flight distance : 360138 ft
Zbig Posted at 2017-10-31 11:56
I properly enjoyed how each motor played the DJI bootup tune once the ESC had been updated.
At first I thought it was a new initialisation sound, as a single motor sounds much better than all four at the same time.
2017-10-31
