Free or Follow mode
1821 6 2017-11-18
Vjelovic
Croatia
What is the difference between two modes,
because in both modes i can pan the camera??
In the manual is strictly said that in Follow mode"pan cannot be controlled"??
2017-11-18
Mark Guille
Flight distance : 2277992 ft
Guernsey
In Follow mode, the camera will rotate with the yaw of the aircraft, in free mode, the camera will remain in the same direction when you rotate the aircraft. You can pan the camera in both modes.
Mark G.
2017-11-18
Vjelovic
Croatia
Thank You for info. DJI should correct the manual.
2017-11-18
Mark explained very clearly, the user manual may be a little more professional with some jargon and is not very readable.
If there is any problem with user manual, please let us know.
2017-11-20
Vjelovic
Croatia
It is not question of jargon, manual clearly states that pan in follow mod not possible.
2017-11-20
Electro-Nick
Flight distance : 7083891 ft
That's how it worked when the I2 was originally released. The gimbal yaw motion was added  to replicate the behaviour from older I1 systems.
2017-11-20
Vjelovic
Croatia
Electro-Nick Posted at 2017-11-20 13:06
Ok, but then, let DJI correct the manual, and publish it.
New users will find this information very confusing.
By the way, many things about DJI GO 4 app, didn't included in manual, especially advance settings.
2017-11-21
