Verison 4.1.18 dated 16 Nov 2017 issues
123Next >
8100 103 2017-11-17
Un33kone
2017-11-24
S-e-ven
Flight distance : 5922034 ft
It is , isnt't it?
2017-11-24
iamburny
DJI provide functionality within the DJI Go App that allows you to Live stream the Spark's video feed via Facebook and Youtube (among others) I have tried this and its works (if a little choppy), however if we are forced to use WiFi to connect to the controller how is this every going be achievable? we will not be able to connect to the internet for said streaming services?  as far as I can see the only way to do this is to use an OTG cable to connect to the controller and have the DJI Go app connected to the Internet via Wifi or 4G.
Am I missing something? as the same applies to the Live Map mode, the map has to be downloaded to be viewed.
I want to retain an internet connection while I fly for many reasons, and do not want to dedicate my Wifi connection to connect to a device mere centimetres from my phone when a cable is much better suited to that purpose.
Matt
2017-11-24
S-e-ven
iamburny Posted at 2017-11-24 05:02
Sat view is only possible if online, too!
All good reasons, that OTG  NEEDS to be tested and supported 100% if the Spark is sold for android devices
2017-11-24
Virgil Quick
Flight distance : 1074104 ft
On an iOS device, how do you go back to an older version of the GO 4 app?  It doesn't not appear that the App Store will allow prior versions to be downloaded.
2017-11-24
sibu
Flight distance : 322454 ft
Kuwait
All this is due to the SPARK software version 0.7000...The RC and SPARK is losing communication link during mid flight or while landing...I downgraded the firmware using NLD software and not DJI software and it worked super fine linking was a cool breeze and flight was absolutely stable...
The problem is after using the current version, downgrading through DJI assistant to 0.6000 version also does not correct the software issue...therefore I was forced to use the NLD software...
2017-11-24
rxdeath
DJI Elektra Posted at 2017-11-20 23:46
I don't think so. I think OTG is unstable. That's why we always recommend users use WIFI connection instead.
i have a thread with the same problem, and similar nonsense from 'elektra'.
what you THINK is irrelevent, all your users are saying it worked fine, until your app engineers explictly broke it.  i've used it for 4 months on 3 different devices flawlessly, but .18 comes out and they all magically become 'unstable'?  don't buy the lies, they ruined it on purpose to eventually force us onto their overpriced crystal sky device.
2017-11-24
Wachtberger
Flight distance : 261509 ft
rxdeath Posted at 2017-11-24 12:43
Please stop with your either uncontrolled or driven by other motivations postings in this forum. Enough is enough!
2017-11-24
PixelSyndicate
Flight distance : 110407 ft
I experienced some issues as well, but didn't consider it was happening with the cable only.
Here's my experience... The DJI Go app suggested I contact support regarding this, but I thought i'd go to the forums first.
With the latest software and firmware updates, I've noticed twice in two days that the 'auto-land' button is disabled while in mid-flight, and the 'auto take-off' is enabled. By this i mean the on-screen icon is greyed out for return-to-home / land. While i mid-flight I tested to see if perhaps the issue was with the visuals of the UI along, but it wasn't clickable either. I clicked the 'auto take-off' icon while in flight and got the confirmation slider. Sliding it to confirm take-off provided an error stating I should contact DJI support.
I'm using Android.
Steps to duplicate:
DJI GO 4 > Auto Take-off > (fly a bit)
The only way i was able to select 'return to home' was from my controller, and even than just started the landing cycle, and didn't return to home as it previously did before the update.
Wil
2017-11-24
Wachtberger
PixelSyndicate Posted at 2017-11-24 15:16
Thank you very much for these additional observations that will certainly help to make the next version of the app working as it should again! For the time being it can only be recommended to return to DJI GO 4 version 4.1.15 which is working pretty well.
2017-11-24
Un33kone
And the crash after update this ought to be totally enough for them to fix and replace my spark
2017-11-24
Wachtberger
Un33kone Posted at 2017-11-24 16:00
Would you mind uploading your relevant flight records to http://www.phantomhelp.com/LogViewer/Upload/
and share the results with us? I have the strong impression that there were more factors in place than just the latest app version.
You will find the flight records in the DJI folder on your mobile device.
2017-11-24
Un33kone
Wachtberger Posted at 2017-11-24 16:06
and share the results with us? I have the strong impression that there were other factors in place than just the latest app version.
sure no problem
2017-11-24
$gambino$
Flight distance : 1563980 ft
Wahlburger how about u let other users explain how they feel and mind your business....thanks good day
2017-11-24
$gambino$
Wahlburger its obvious the app is borked dji screwed up again and should fix it. This forum is wild smh
2017-11-24
Wachtberger
$gambino$ Posted at 2017-11-24 17:50
I fully agree that there are serious issues with the latest app version which need to be fixed and hope that they can be identified all.
2017-11-25
UncleManuel
Flight distance : 4104 ft
Taking away the working OTG connection with the controller is just bull****. Now the users are forced to use the more unstable and more energy hungry WiFi connection. Great...
Btw: Anyone noticed the update policy for the Android version? I've updated to 4.1.18 and a day later another 19 MB update appeared. I guess a hotfix?
2017-11-25
fansfb1bf277
Flight distance : 104449 ft
Ukraine
UncleManuel Posted at 2017-11-25 08:11
I suspect that small update was just to add black friday ad
2017-11-25
marikello
Flight distance : 59537 ft
I actually was thinking the same, how can I live stream if I can't? Use WiFi and 4g at the same time simultaneously on android device (have no clue about is) . Or can I?
2017-11-25
djiuser_Kf4iPA3
Flight distance : 510968 ft
Israel
You can, at least on my device (LG G3). If the wifi can't see internet, it connects to the internet with cellular. You can most probably set your device to do that in Settings.
In my device it's a checkbox under Settings - Networks - WiFi.
2017-11-25
marikello
djiuser_Kf4iPA3 Posted at 2017-11-25 13:32
Mine Huawei P10 seems don't have this option, or I haven't figured out yet how. Funny thing is that dji Electra suggested to use IPhone... Think it's appalling that I have to buy iOS just to fly with better connection and stream online... Is DJI owned by apple or its just coincidence?
2017-11-26
Mildman
Rumous are that Apple are buying DJI...just a rumour though...
http://appleinsider.com/articles ... -customer-crossover
This quote below isn't a rumour though and so for me, after only a month, I'm selling my Spark,   When I spend £700, I expect that feeling of value, quality and fun...and most of my photography related purchases have made me feel this way.  The DJI purchase has just been an irritation from day one and DJI are showing no intention of improving the experience.  Even GoPro listens to customers, DJI are laughing at us.
My orginal intent was to get the Spark, then if I liked it, upgrade to the Mavic Pro.  No chance!
Christian Struwe, head of European public policy at drone maker DJI told BBC Breakfast: "The good thing is that as an industry we are already working on it. We can limit how high they can fly."[/b]
What a spineless, obtuse, backward thinking organsaition.  I'm so disappointed!
2017-11-26
Locationscout_B
Flight distance : 62201 ft
Mildman Posted at 2017-11-26 04:17
http://appleinsider.com/articles/16/03/02/drone-maker-djis-new-apple-partnership-inspired-by-customer-crossover
no rumors, just a interview you can read if you want.
http://dasfilter.com/technik-wis ... ische-modellflieger
You will be smart enough (as you´re owning a drone) to use google translate, because its only in english.
2017-11-26
Wachtberger
Locationscout_B Posted at 2017-11-26 05:41
http://dasfilter.com/technik-wissen/drohnen-und-politik-ein-interview-ueber-flugsicherheit-schwierige-eu-gesetze-und-muerrische-modellflieger
Thank you for sharing the link. Very interesting and good interview.
2017-11-26
djiuser_Kf4iPA3
Israel
You do see the date on your link, don't you?
Look at the date of that German interview too...
2017-11-26
Mildman
djiuser_Kf4iPA3 Posted at 2017-11-26 08:00
Yes, but only since I've owned a DJI product have I needed to look.
2017-11-26
nullr0ute
Flight distance : 14941 ft
My experience with 4.1.18 was so bad that I downgraded back to 4.1.15. Let's wait until DJI sorts this out.
2017-11-26
fans2a392238
Flight distance : 299 ft
Beejay81 Posted at 2017-11-20 02:17
Yup theyve broken the telemetry feed over OTG cable in 4.1.18, and the wifi seems a little choppy too... wonder what the app is doing.....  back to 4.1.15 and OTG is still ok.  If you like OTG ( I reckon the feed is always smoother that way) back to v4.1.15.... https://www.apkmirror.com/apk/dji-technology-co-ltd/dji-go-4/dji-go-4-4-1-15-release/
There are 2 variants of 4.1.15 on the apkmirror site.  What's the difference between them?  I can't find any useful info on the page.
2017-11-26
djiuser_Kf4iPA3
Israel
Most probably one is more suited for tablets.
2017-11-26
Matronix
Kloo Gee Posted at 2017-11-17 07:09
I don't see 4.1.18 yet either.
I saw your video ! Thanks for telling me that pano mode will come later
2017-11-27
DOWSETT
Flight distance : 392234 ft
I've only experienced 4.1.18 with otg; what new adventures will I experience, once whatever is fixed ?
2017-11-28
Edd_88
fans2a392238 Posted at 2017-11-26 11:43
I heard that 1 for phone and 2 for tablet.
2017-11-28
_KERBEROS_
Flight distance : 98179 ft
I Confirm that app DJI GO 4.1.18 from November 28, 2017 have support OTG, but with problems. For example auto landing doesn't work.
2017-11-28
ArnoSpark
Kenya
_KERBEROS_ Posted at 2017-11-28 11:29
well i didnt noticed the update till today then after updating i noticed that there is a problem on landing as well as no battery info on the app screen, of course i was using the OTG, then i decided to reinstall the app and still the same problem, then i came here to see all this issues of the update.
So i decided to use WIFI and all the info and the landing was on the screen.
So am not sure if what is happening to me is happening with everyone else?
I connect the OTG i dont get battery info (charging level, low battery warning level, voltage) the min i connect wifi i get all the info.
Well am not going to repeat what have been said, but for me my major issue will be i wont be able to use cellular data while on Wifi, am android Samsung J5 Pro so the location and GPS wont work if am connecting Wifi to RC, unless there is something am missing .
I used the OTG and i loved it i wish it will get back to normal soon.
2017-11-28
UncleManuel
ArnoSpark Posted at 2017-11-28 13:06
Dude, have you even read post #1 in this thread?
In short: there's no official support that OTG works with the Spark since this is software code developed for the Mavic. That it has worked is just a "happy accident"...
Btw: there was another 18MB update in the Play Store for GO 4. It still says version 4.1.18. I wonder what that's all about...
Edit: Ok, I've tried it - OTG still does not work...
2017-11-29
ArnoSpark
Kenya
UncleManuel Posted at 2017-11-29 02:48
I did And i don't  think i said anything differently.
ye i got that patch of update let me see if it will correct anything or not, but i doubt as you just mentioned it didnt change anything
2017-11-29
dansmar
Flight distance : 422149 ft
Looks like more issues related to dropping otg support
2017-11-30
djiuser_Kf4iPA3
Israel
yet another patch, day after day. This is beginning to look like panic.
Which is actually good, it means DJI acknowledges something is deeply wrong.
i just wish they were a little more forthcoming toward us in telling us what issues they recognize and intend to fix, what's being solved by each iteration, etc. I think as customers it's really the bare minimum we deserve.
2017-11-30
fans54d746fc
Flight distance : 48720 ft
Malaysia
I'm new in Dji Spart... I bought Combo Spark on the 2nd Disember 2017 using all the latest firmware and apps but it does no support otg on wifi yes its worked. I'ved downgrade my apps Dji Go 4 ver4.1.18 to Dji Go 4 ver4.1.05 its really work, so until now I'm using ver4.1.05,
2017-12-9
Jos A
Flight distance : 73209 ft
Its now a week later since 29 nov last update of the 4.1.18 and DJI still not fixed this major issue.
2017-12-9
123Next >
