Problem Gimbal Phantom 4 Pro
1494 11 2017-12-5
Pacelli
Flight distance : 6099 ft
After replacing the yaw motor, the gimbal is only in this position
2017-12-5
Pacelli
2017-12-5
kykphantom
Flight distance : 5892388 ft
Cyprus
This issue has been resolved. Please search in this forum and you will find the solution.
2017-12-5
Hey Pacelli, please place the drone as the below picture and try to calibrate the gimbal to see whether it helps.
2017-12-6
Pacelli
DJI Susan Posted at 2017-12-6 02:06
I already tried this.
2017-12-6
Pacelli
kykphantom Posted at 2017-12-5 09:09
I did not find this post
2017-12-6
kykphantom
Cyprus
Have you tried to turn manually the gimbal at the opposite side (when the P4P is switched off)? Try it, turn the gimbal very softly towards the opposite side of the yaw until you reach the end but don't push it too much, step by step.
2017-12-6
Pacelli
kykphantom Posted at 2017-12-6 06:29
2017-12-6
lannes
Flight distance : 4465 ft
Pacelli Posted at 2017-12-6 13:14
You may need to turn it while the AC is on.
2017-12-6
Titanbot
Flight distance : 2485909 ft
Mine was doing same thing but when i was in mid flight, and just kept getting gimbal motor overload warning.  Tried everything that ppl had posted, looked closer at ribbon and found it was separating.  On its way to ca now.
2017-12-6
Pacelli Posted at 2017-12-6 04:17
Just to verify, do you repair the drone in DJI Official Service Center? If yes, please kindly offer the case number, I'd like to look into it.
2017-12-7
Pradipwb
Flight distance : 20545 ft
Hi DJI Susan
I am interested in attaining dji workshop for services.can you tell me whom to contact.
2018-3-8
