Flight distance : 10186312 ft
1/ if you lose gps signal aircraft won’t fly home, it will revert to Atti mode
2/ if you lose radio signal your aircraft will RTH after 3 seconds
3/ Spark won’t handle strong winds well (always fly mission into wind when beginning)
4/ yes you should have gps signal in the mountains (never fly with less than 11 sats)
5/ remember to sign into your app before leaving home (you may not have WiFi signal up the mountains)
You should have no problem with spark up the mountains and a great opportunity to film where very few get the chance to from the air.
Make sure you have a preflight check list and use it, it is your best friend and one way to insure that your aircraft is in good working order and you have done your best to make sure of this.
Good luck and enjoy the trip. |
