Slow propeller spinning?
3457 8 2014-11-13
arsh_yho
I have discovered that one (front right) of the propeller is spinning slower than others, is this can occur a problem during the flight in future? And how it can be solved?
Thank you in advance!
2014-11-13
b.w.j
Is the named motor warmer after a flight ?
mine had also one spinning slower than others, and i will not risk a crash, so i changed it.
PS. my English still sucks
2014-11-13
arsh_yho
b.w.j thank you for answer!
You have changed motor or propeller? If motor I have red that it is problem of ECS(or how it is called) board problem.
Actually because mine is slower just a little bit I am not sure it is a problem or not. But visually i can see the difference!
2014-11-13
b.w.j
arsh_yho@yahoo. Posted at 2014-11-14 04:28
You have changed motor or propeller? If motor I have red that it is pro ...
I have read a lot of this issue, the conclusion is, if motor get warmer it is advised to change it, if not - no problem.
Mine motor get warmer, so I change it.
2014-11-13
DJI-Jolie
China
Hi Arshi_yho,
may I ask whether your copter can still fly properly?
2014-11-14
arsh_yho
DJI-Jolie Posted at 2014-11-14 19:10
Hi Arshi_yho,
Hi Dji-Jolie, yes it seems it can!
2014-11-14
DJI-Jolie
China
arsh_yho@yahoo. Posted at 2014-11-15 05:22
Hi Arsh_yho,
like b.w.j suggested, if the ESC or motor does not get warmer than others and your copter can still fly very properly, then it is fine.
2014-11-14
arsh_yho
DJI-Jolie Posted at 2014-11-15 11:44
Hi Arsh_yho,
like b.w.j suggested, if the ESC or motor does not get warmer than others and your c ...
Hi Dji-Jolie thanks, is there any way to double check if motor or ESC working properly like some tool or soft, maybe it can be checked in assistance parameters ?
2014-11-15
b.w.j
I use an infrared thermometer, its quick and easy.
2014-11-15
