Abnormal Gimbal Vibrations and new low noise props
2784 13 2017-12-18
nottuppaware
Flight distance : 70745 ft
So I assume putting the new low noise props on a standard mavic is the reason that I get Abnormal Gimbal Vibration alerts sometimes now ?
2017-12-18
Jos A
Flight distance : 73209 ft
Yes don't buy them and return.
https://forum.dji.com/forum.php?mod=viewthread&tid=117478
2017-12-18
nottuppaware
Jos A Posted at 2017-12-18 00:25
Sigh... I guess I'm putting the old ones back on
2017-12-18
Jos A
It's compatible but only if you use it for flying and taking a picture, for video recording it's not good enough.
2017-12-18
Landbo
Flight distance : 502792 ft
Strange, my 8331 props I have no shakes from. So I've actually ordered an extra set if one should be damaged.
However, it should be said that I do not expect the new props to last as long as the regular because of their thinner spinners. One should definitely keep an eye to they do not get cracks.
Regards Leif.
2017-12-18
$gambino$
Flight distance : 1563980 ft
Yep lots of people including me have the gimbal shakes with the new props and The Old mavic Pro... Went back to the old ones all good
2017-12-18
nottuppaware
$gambino$ Posted at 2017-12-18 03:03
I'm glad its not only me. I guess they are really designed for the newer motors on the Platinum model.
2017-12-18
$gambino$
Its the esc's that are different motors are the same
2017-12-18
nottuppaware
$gambino$ Posted at 2017-12-18 18:09
So could it be fault in the new props in general ?
Be hard to take them back to the retailer now they are used.
2017-12-18
Hi sir, the new low noise propellers can be compatible with Mavic Pro if the drone is running the latest firmware. If you have any issues with using the Low Noise props on Mavic Pro, please kindly let me know, a video will be highly appreciated. Thank you.
2017-12-19
Blizzard
Flight distance : 173734 ft
Just have to properly balance those props!.
Take a toothpick or a sate stick that fits in the center hole of your propeller and put it on the edge of two glasses.
If you spin it slowly it should be in balance in any position.
If one side is always ending down, it means that that side is heavier. With some sandpaper, remove a little bit from the backside until both sides are in balance.
If you have a scale that can measure milligram, weigh each propeller and see if there is any difference. This also will give vibrations?
2017-12-19
nottuppaware
DJI Thor Posted at 2017-12-19 01:24
Thanks DJI Thor,
I'll try get a video of when its shaking. Its actually quite noticeable externally.
2017-12-19
nottuppaware Posted at 2017-12-19 19:58
Thanks DJI Thor,
Thank you so much for your cooperation. And please also add the firmware info of the drone and RC (power on the drone, RC, app and enter device---upper right icon---general----about). Appreciate your work!
2017-12-20
Picanoc Jack
Flight distance : 10598737 ft
well now I know why this has occurred, thanks so much for the info
2018-9-9
