Help with replacing camera
1316 6 2018-1-12
sigkill
Hello, I have ordered a replacement camera for my Mavic due to the original having a mis-aligned lens causing a portion of the recording always out of focus. I haven't received the shipment yet but I was looking at my Mavic and was wondering if someone has any advice for doing this repair in the correct manner.
I see two screws that appear to hold the camera module to the gimbal, and I see in the photo for the camera module there is a ribbon cable inserted into the camera's cable clamp. Am I to assume that I can simply remove the two camera module screws and then separate it from the gimbal module? Or do I need to remove the entire camera/gimbal unit to create slack in the ribbon cable and only then separate the camera module?
Any advice would be appreciated!
2018-1-12
DJI Diana
Flight distance : 2408 ft
To ensure the safety and performance, we'd recommend you to send it in for evaluation and get it repaired by engineers. Besides, unauthorized modification will void the warranty, for details, please visit: http://www.dji.com/service/policy
2018-1-12
4WDaus
Flight distance : 1187257 ft
Try  this link https://m.youtube.com/watch?v=KFiqxxkE5iE
2018-1-12
sigkill
DJI Diana Posted at 2018-1-12 01:19
I'm going to do it myself, may the heavens fall!
2018-1-12
Woe
Flight distance : 4129268 ft
Brave hope everything works out
2018-1-12
sigkill
Woe Posted at 2018-1-12 07:07
Thanks buddy. It looks very simple from the image of the camera module, its just I don't know if I need to drop the whole camera/gimbal out first due to my uncertainty regarding the ribbon cable, or can I just drop the camera with the gimbal in place. The ribbon is clamped in an edge connector on the underside of the camera and I'm just not sure if it will let go.
2018-1-12
DJI Diana
sigkill Posted at 2018-1-12 06:50
Well, hope it goes smoothly.
2018-1-12
