Anyone installed the new firmware v1.2.1.03?
4342 47 2015-5-6
ola
Overview:
1. All-in-One Firmware version updated to: v1.2.1.03
2. DJI Pilot app iOS version updated to: v1.1.1
3. DJI Pilot app Android version updated to: v1.1.0
Major Updates:
1. Reduced moire pattern in camera images.
2. Added support for YouTube live streaming.
3. Added support for the DJI Pilot app’s Director function.
4. Reduced power consumption of the Intelligent Flight Battery when it is powered off to protect the
battery.
5. Solved issue of the remote controller occasionally powering off automatically when using firmware
v1.2.1.0.
2015-5-6
Farnk666
Flight distance : 1711394 ft
It had only been 18 minutes since the announcement ola - give people a chance!
2015-5-6
ola
Farnk666 Posted at 2015-5-6 20:13
Ok.
I'm just curious about the camera-update...
2015-5-6
Farnk666
About to load it - haven't had a flight for a couple of weeks and need to charge a battery!
2015-5-6
markjacobs.talk
Flight distance : 120784 ft
Interesting they slipped in right at the end they have 'solved' the issue with some remotes turning themselves off !!
2015-5-6
Rockeyes
markjacobs.talk Posted at 2015-5-6 20:27
Interesting they slipped in right at the end they have 'solved' the issue with some remotes turning  ...
What bug? I see no bug
2015-5-6
sbarryjackson
Flight distance : 18931532 ft
Just upgraded the bird and two controllers with no issues. Also updated the app for IOS.  I really like the fact that there are now numbers next to the satellite bars. Also the highlighted percentage of the battery really helps and makes it stick out.
The only thing I would like to see is a degree number next to the lines that show the level of the gimbal. This would really help when trying to get a consistent degree of tilt after maybe returning to vertical center.
2015-5-6
Farnk666
Loaded up and no issues with the upgrade.
On the bench it's all powered up and running.
The menus are a little different in structure - take a few minutes to familarise yourself with the new layout!
I am getting a lot of pixelation and breakup on the slave RC's iPad Mini2 - picture is clear on the master with just the occasional breakup.
Haven't seen this sort of thing before! Will test everything tomorrow out in the park - looks like I have a fair bit of interference here!
2015-5-6
arunmehta
Flight distance : 120909757 ft
Updated now no problems
WARNING!!!! After firmware upgrade the "Failsafe height of craft when returning Home is set to zero make sure you reset it to the height you want...i discovered that "bug"
2015-5-6
lucaoms
Flight distance : 599049 ft
ola@almviken.co Posted at 2015-5-6 20:18
Ok.
and if u are curious , why you do not istall in your and give us your comment?
2015-5-6
ola
lucaoms Posted at 2015-5-6 21:47
I will when I get a chance.
2015-5-6
averbouwens
Flight distance : 83642 ft
I lost my Bird 1 into the river last week  "Solved issue of the remote controller occasionally powering off automatically when using firmware v1.2.1.0."  Still doing paperwork with DJI.  ?????
2015-5-6
lucaoms
averbouwens Posted at 2015-5-6 22:01
I lost my Bird 1 into the river last week  "Solved issue of the remote controller occasionally power ...
yes but with remote control in off , birds come at home , how you loose your bird?
2015-5-6
Christian
Updated the firmware with no errors - everything went super smooth!
CAUTION: All of my batteries need to be updated as well (4x TB47, 1x TB48)!
Update procedure for batteries (as they is no good description):
Insert SD Card with firmware update, insert battery, power up, wait and check if battery led starts blinking "unusual".
If firmware needs to be updated, battery led´s starts blinking "unusual" and gimbal is doing this D-D-D-D noise.
Wait approx. 1-2 minutes, then battery switch to "normal" blinking and gimbal sounds like this D---D-D.
Successful update - If nothing happens, your battery is up to date.
Cheers, Christian
P.S. After that, you have to check the value for self-discharge.
2015-5-6
markjacobs.talk
lucaoms Posted at 2015-5-6 22:12
Good question
2015-5-6
JKT
Farnk666 Posted at 2015-5-6 21:26
After I downloaded the last firmware I experience that a lot with my new iPad mini the videos was pixilated.
2015-5-6
nilsblix
Flight distance : 23047543 ft
Updated all with no problems - flying tonight
2015-5-6
d
updated
all 3 .text files (bird, RC1 & 2) : success
RC with "no signal" (red light)
Inspire with yellow flashing
help anyone !
2015-5-6
airimage.pl
d@van.ac Posted at 2015-5-7 00:18
updated
" The remote controller may become unlinked from the aircraft after updating. Re-link the remote controller and aircraft."
2015-5-6
Ph02on
Flight distance : 75673 ft
Inspire, both remotes and 4 batteries updated with no issues at all.  Happy Chappy here.
Jason
2015-5-6
panox
Flight distance : 568819 ft
Ph02on Posted at 2015-5-7 01:49
Jason ...
The update of Inspire 1, two transmitters and four batteries was successful.
2015-5-6
lesmess
Flight distance : 2753402 ft
Inspire, controller & three batteries updated no probs. Did a full IMU calibration and compass.  Not flown, too windy here in Aberdeenshire Scotland.
2015-5-6
rsghowellnj
Flight distance : 508255 ft
I upgraded my inspire, 2 controllers and 4 batteries no problems.  Did IUM and compass.  I had to relink my controllers and will be flying on Saturday.
2015-5-7
rsghowellnj
JKT Posted at 2015-5-6 22:34
After I downloaded the last firmware I experience that a lot with my new iPad mini the videos was p ...
I was noticing this pixilation before.  I thought it was because I was too far from my master.  I'm seeing it when my master and slave are next to each other.  Hmmm.  I wonder if this issue is that I have my cell service turned on my iphone on my slave.  Not seeing the pixilation on the master ... only the slave (but my slave is an iphone and my master is an ipad mini without cell.
2015-5-7
rsghowellnj
Does anyone know what this new version of the firmware does for us?
2015-5-7
rsghowellnj
updated
Did you make sure your controller was off when you were updating your Inspire & Batteries?  When Updating your RC, maybe making sure your Inspire is turned off might help.  That would be my recommendation.
2015-5-7
rsghowellnj
rsghowellnj@gma Posted at 2015-5-7 19:37
Okay .. now I feel really foolish ... it was in the announcement:
4.      Reduced power consumption of the Intelligent Flight Battery when it is powered off to protect the battery.
5.      Solved issue of the remote controller occasionally powering off automatically when using firmware v1.2.1.0.
2015-5-7
rsghowellnj
rsghowellnj@gma Posted at 2015-5-7 19:35
I was noticing this pixilation before.  I thought it was because I was too far from my master.  I' ...
Okay ... I tried this and it seems to have improved.  I put my slave (which in my case is an iPhone) in Airplane Mode.  Pixilation has reduced dramatically.
2015-5-7
panox
rsghowellnj@gma Posted at 2015-5-7 19:57
Okay ... I tried this and it seems to have improved.  I put my slave (which in my case is an iPhon ...
How can I get back the audio messages? I don't hear the voice any more.
2015-5-7
rsghowellnj
Nope ... I retract my statement.  Pixilation is still there on the slave.  Only when I move the camera around fast.  Again, I don't see it on my master or my recordings.  I guess this is a shortcoming that can't be corrected?
2015-5-7
rsghowellnj
panox Posted at 2015-5-7 20:29
Interesting ... I never heard my voice from my inspire camera.  I kind of liked that because I didn't really want to hear the props.  Must be an option some place ... now  you have my interest ... I'll have to hunt around.
2015-5-7
panox
rsghowellnj@gma Posted at 2015-5-7 20:44
Interesting ... I never heard my voice from my inspire camera.  I kind of liked that because I did ...
I do not mean "my voice" - I mean the voice of the Lady with the audio-messages. "Take off..."
2015-5-7
Dave E
Flight distance : 729560 ft
panox Posted at 2015-5-7 20:52
I am having the same problem panox. No voice on my nvidea shield, samsung galaxy note 8 or samsung s4 Phone. I reinstalled the previous app version 1.0.10 which is in the play store and the voice works fine.
The voice also works on my iphone with the latest ios app.
After a long struggle with the tech chat and them trying to go down the route of my devices not being on the list of compatible ones, they are going to look into it.
2015-5-7
jlivingston6
Flight distance : 82556 ft
Has anyone, after they updated, gone out and flown their Inspire? To windy here for me to try. I want to see if the flights and video are just as good as before the update. REMEMBER, the RTH value is lost after you turn off the machine or the iPad or iPhone. The box back to blank. So make sure prior to flight you enter your RTH value.
2015-5-7
daver/m
Flight distance : 234590 ft
jlivingston6@ve Posted at 2015-5-7 23:04
Has anyone, after they updated, gone out and flown their Inspire? To windy here for me to try. I wan ...
Going to test field today , will post pilot app flight record after testing some things .
2015-5-7
rsghowellnj
check the volume on your iPAD.  That happened to me once and I didn't realize that the clamp had been over the volume and muted my speaker.
2015-5-7
rsghowellnj
Sorry for asking but what is the Rth Value?
2015-5-7
Dangair
rsghowellnj@gma Posted at 2015-5-8 08:57
Return To Home... It is the height you select that ensures the aircraft is above any obstacles that your craft may impact on the return home.
2015-5-7
rsghowellnj
Dangair Posted at 2015-5-8 09:17
Return To Home... It is the height you select that ensures the aircraft is above any obstacles tha ...
Perfect .... thanks for the reminder
2015-5-7
panox
rsghowellnj@gma Posted at 2015-5-8 08:55
check the volume on your iPAD.  That happened to me once and I didn't realize that the clamp had b ...
All audio-settings on full. No voice. Android. Known problem. Not yet solved by DJI.
2015-5-8
