Mavic Air 4km range with a WiFi - how??
562204 562204 2018-1-25
yuumee
Flight distance : 1039029 ft
Taiwan
I am curious about technical capabilities - as I understand the Mavic Air uses WiFi technology - how is that possible then to achieve 4km range?
Someone please enlighten me.
2018-1-25
Tviscomi
Flight distance : 106886 ft
Good question, especially since the Spark also uses wifi and has a lower range
2018-1-25
Simmo1
Flight distance : 1624 ft
With my directional wifi 'extender' I get about 12 k. los.
2018-1-25
R&L Aerial
Flight distance : 298100 ft
I’m positive that the air gets no where near 4 km just like the mavic gets no where near 7km, unless you live on a high bluff overlooking the ocean with no trees, wi-if signals or clouds in the sky?
2018-1-25
Kevin79
Flight distance : 270899 ft
“Enhanced WiFi” not  too clear on what that is yet but the WiFi connection is only from your mobile device to the remote which operates at the standard 2.4/5.8 GHz, not the aircraft. If you are using your mobile device only your range is only going to be 80 to 100 meters. The antennas built into the leg extensions of the aircraft are further away from the main body of the AC which supposedly allows for a longer and more reliable signal up to 4K when using the remote/mobile device combo
2018-1-25
Mharro88
Flight distance : 26401 ft
Does anyone know if Australia will get the 4km or are we like Europe and get the CE half range crap?
2018-1-25
Foxeuphoria
Flight distance : 8110 ft
Perhaps it uses the new 802.11af standards.  That Wifi transmission takes place on UHF waves and has a range of miles.
2018-1-25
Malakai_UK
Flight distance : 536115 ft
You will find the link between the controller and your phone and the aircraft are separate and the aircraft will use a different communication protocol, albeit on the back of the wifi connection. The controller is probably more sensitive and can broadcast further than your phone can. It has two antennas suggesting one is transmit and the other receive. The range they claim of 4km is probably true, in an FCC area simply because the broadcast strength is higher from the controller and the aircraft. In a EC area the broadcast strength is toned down depending on frequency. 2.4ghz will be about 2km and 5ghz 500m.
Personally I don't see these limits on flight distance a big issue. I'm more concerned about stability of the connection.
2018-1-25
Vincent.
Flight distance : 459738 ft
Kevin79 Posted at 2018-1-25 05:06
On the Mavic Air, the connection between the remote and the phone is done with a cable. So the wifi is used between aircraft and remote
2018-1-25
Chuck1026
Flight distance : 1213816 ft
Foxeuphoria Posted at 2018-1-25 08:04
Hmmm... I wonder? That would be good news.
2018-1-25
Foxeuphoria
Chuck1026 Posted at 2018-1-25 08:59
Well, most racers looking for long range are using crossfire and other UHF based systems to allow for greater distances.  It would not be surprising to see similar movement from DJI
2018-1-25
MAVICDLNM
Flight distance : 10696686 ft
That possible has to do with the directional antennas install at the Mavic Air legs.
2018-1-25
AIister
Flight distance : 626647 ft
mavic pro
Operating Frequency
FCC: 2.4-2.4835GHz; 5.150-5.250 GHz; 5.725-5.850 GHz
CE: 2.4-2.4835GHz; 5.725-5.850 GHz
SRRC:2.4-2.4835 GHz;5.725-5.850 GHz
Transmitter Power (EIRP)
FCC:<=26 dBm
CE:<=20 dBm
SRRC: <=20 dBm
MIC: <=18 dBm
Mavic Air
Operating Frequency
2.400 - 2.4835 GHz
5.725 - 5.850 GHz
Transmission Power (EIRP)        2.400 - 2.4835 GHz:
FCC:≤26 dBm
CE: ≤18 dBm
SRRC: ≤18 dBm
MIC:≤18 dBm
5.725 - 5.850 GHz:
FCC: ≤30 dBm
CE: ≤14 dBm
SRRC: ≤26 dBm
they all use 'wifi' doesn't matter what they call it on their propaganda sheets lol.  not sure why the ranges differ so much, the air even has more power on 5ghz band
2018-1-25
HWCM
Flight distance : 5484997 ft
AIister Posted at 2018-1-25 21:20
mavic pro
Operating Frequency
Exactly. I think Occusync just means it has a more powerful output.  Probably close to 1 watt.
2018-1-26
Hi Yuumee, Mavic air uses the enhanced WiFi video transmission system, it can reach to 4000m in FCC mode when the environment is available. Please refer to the specs below. range.png
2018-1-26
A CW
Flight distance : 14754314 ft
Its omnidirectional antennas placed on the foldable landing gear help increase signal coverage to deliver a maximum range of up to 2.5 miles (4km)   with 720p real-time video transmission when flying with the remote controller.
That appears to be the most logical explanation from DJI as to why the range is greater than the Spark though 4KM in FCC and 2KM in CE areas are yet to be seen... And I hope that the small mAh in the battery has enough juice to sustain a safe return on a five mile round flight in modetate winds as using Sport mode to reach 42.5MPH will massively drain that battery and knock the max 21 minutes (16-18 in reality in normal flight) to less than 15 minutes quite easily. My biggest concern flying a WiFi only drone one or two miles away (other than losing VLOS) will be how sensitive the signal is to transmission interference - not sure what the speed is in p-mode and if the drone has dual compass redundancy to help prevent the potential of a fly away. Once more, this drone does not seem to be designed for long distance flying, as is the case with the Spark using the same enhanced WiFi transmission.
2018-1-26
Mharro88 Posted at 2018-1-25 07:32
Of course 'we' will get the tuned down transmission....
CE rules.
DJI can't help it.
2018-1-26
DJI Thor Posted at 2018-1-26 01:56
Hi Yuumee, Mavic air uses the enhanced WiFi video transmission system, it can reach to 4000m in FCC mode when the environment is available. Please refer to the specs below.[view_image]
Thanks for the clarification.
2018-1-26
BigBlueTsunami
Flight distance : 503635 ft
Montfrooij Posted at 2018-1-26 02:19
CE rules.
DJI can't help it.
Is this power output adjusted from FCC to CE based on the gps location of the acft?
2018-1-26
Wachtberger
Flight distance : 261509 ft
BigBlueTsunami Posted at 2018-1-26 02:45
Yes, it switches between CE and FCC modes based on location.
2018-1-26
Yes indeed. That is how it works.
2018-1-26
BigBlueTsunami
WOW. That's just, wow.
Jeff
2018-1-26
Jos A
Flight distance : 73209 ft
Just like the spark you can make your own go app with the option " force to FCC"
2018-1-26
Vincent.
Jos A Posted at 2018-1-26 07:51
How can you do that ?
And so my drone bought in Europe, but that I fly in USA automatically switches to FCC ?
2018-1-26
Jos A
Vincent. Posted at 2018-1-26 07:55
you have PM
and yes it's switch to FCC when you are in your country.
2018-1-26
Filip3rd
Flight distance : 39390 ft
Iran
Only in 5.725 - 5.850 GHz mode and FCC: 4000 m (unobstructed, free of interference) that means no air resistance, wind basically in a space.
2018-1-26
RG1825
Flight distance : 193353 ft
Jos A Posted at 2018-1-26 08:03
you have PM
Any chance you could PM me this too?
2018-1-26
Jos A
done rg1825
2018-1-26
RG1825
Thanks a lot!
2018-1-26
Filip3rd
Iran
you have PM
Would appreciate your info on this
2018-1-26
I am Sparkacus
Flight distance : 94626 ft
Can you let me in on it too?
2018-1-26
Klaush
Flight distance : 449219 ft
you have PM
Please sent me a PM for switching to FCC.
2018-1-26
Flight distance : 10186312 ft
Klaush Posted at 2018-1-26 10:27
Remember you sacrifice your warranty, also their have been flyaways in spark using this hacked app . I’m also 100% certain it voids any Care refresh warranty.
2018-1-26
Jos A
There a more flyaways with the normal app then a hacked app, read the spark forum
2018-1-26
Jos A Posted at 2018-1-26 11:09
Hey don’t be so ridiculous, of course there is simply because there are 95% more people using normal app.
But one advantage they have is if Aircraft malfunctions they have a warranty if they had Care refresh and they recover their drone they are covered, unlike anyone who decides to hack the app.
2018-1-26
fans4ee4a121
R&L Aerial  Posted at 2018-1-25 04:54
Really, because my mavic gets 4k and can go a lot further if I want to
2018-1-26
R&L Aerial
fans4ee4a121 Posted at 2018-1-26 13:34
Read what I said again....
2018-1-26
This might help explain why.
2018-1-28
DJT_MVSP
Flight distance : 2018645 ft
The range would probably be around 1.5 KM in real world conditions
2018-1-28
djiuser_0jeu44bvGedp
I would like to get that pm also
2018-2-3
