Poll:how many times have you lost control or the signal of spark
123Next >
5964 86 2018-1-29
ADM-Frank
Flight distance : 257428 ft
Mexico
hi friends, I  know we´ve all lost the signal or control of the spark at some point, but I would  like to know how many times and why that happened?, how you solved it?  and How did you feel when spark was going away?
(if it happened)
Single SelectVote, Total 296 people participate in voting
2018-1-29
spookster
Flight distance : 419649 ft
I actually never lost control of my spark so far.
But I only let it cruise in my line of sight and in open areas.
2018-1-29
Solestacz
Flight distance : 489193 ft
once, but it returned to my control in short order and was landed safely.
2018-1-29
Bright Spark
Flight distance : 22129 ft
Never.
2018-1-29
Shade220
When reviewing a flight log file i noticed the comment that signal was lost for about 1 second.   The drone was about 100m high, 370m out in the country with no buildings and few if any other wifi sources around.  Did not know the signal was lost during the flight, so would be hard to say how often it happens.
2018-1-29
djiuser_yxfdr03jCyHh
Flight distance : 338222 ft
Once at takeoff it just took off about 2 meters high. It thought I was in Germany but actually I was in Canada. Scared me but no damage. Landed in snow.
2018-1-29
ADM-Frank
Mexico
djiuser_yxfdr03jCyHh Posted at 2018-1-29 15:26
Your story caused me terror, XD, the first time I see that
2018-1-29
ADM-Frank
Mexico
spookster Posted at 2018-1-29 14:33
I agree with you, it is better to fly it always in sight
2018-1-29
Gunship9
Never lost control.  It has good links.  Once the video started breaking up at 1000 feet or so.  It did it because I lifted the screen up to block the sun on it only to wind up pointing the antennas at myself.  Lost video to the spark but gained video from an overhead satellite.  Tilted the controller back down and raced the Spark back to me.
2018-1-29
mtnlandpix
Never, but I always fly VLOS.
2018-1-29
Aeromirage
Flight distance : 1778045 ft
App was crashing bad a few updates ago.
But never lost control of the drone, just the app crashing.
Glad I read about it on forum so when it did happen I didn't FREAK!!!
2018-1-29
headshot9
Lost signal many times (never managed to fly more than 400m away), but never lost control
2018-1-29
Flighty
Flight distance : 1977175 ft
Croatia
Have two instances, one for loss of signal due out of range, second due Drone going behind an obstruction. Both were loss of signal to the RC, fortunately safe RTH.
2018-1-29
munchausen
Flight distance : 890217 ft
Crashing app freaks me a bit, there's the RC then.
But once a sudden gust took it away in seconds right after it reported "magnetic filed" [sic] interference and gone to ATTI in the middle of nowhere. No RTH, only to pray that it gets GPS again, which it did about 50m further away. RTH then immediately.
2018-1-29
Cubi
Flight distance : 27776 ft
I'm losing connection pretty often, even after my RC has been replaced. It's better than before but I still keep having connection issues. Last time it happened when I was at a height of 70m and range of 300m. But I learned that losing connection isn't really a huge issue. Spark RTH function does what it is supposed to do and the drone always came back to it's starting point.
2018-1-30
fans209e8746
Flight distance : 754872 ft
I’ve lost gps once in 140 flights don’t know why it was windy and I hadn’t experienced no gps and it flew into a tree but it’s ok
2018-1-30
Ram-UK
Flight distance : 1173045 ft
I never lost signal of my Spark. I always fly within the range (well below 100m altitude and 300m distance) and ensure I keep VLOS at all times. It helps to keep my Spark safe and enjoy my drone flying.
2018-1-30
WilfredFireSteel 8
Flight distance : 182215 ft
Never lost control but lose video signal every flight, especially over 70M away!!! (I am Uk user who sadly has a Samsung S8)
2018-1-30
manolism
Flight distance : 53035 ft
headshot9 Posted at 2018-1-29 20:08
The  same.
2018-1-30
Madseason
Voted once but have to be honest. I'm pretty sure it was my fault. I had only had it for a couple of days and didn't have the safety checklist I now use before flying. I'm almost certain it was compass interference created by me trying to calibrate it some 15 feet away from overhead powerlines Now I go through a 5 step process of checking stuff before flying and I never calibrate anything unless the drone prompts. Not one issue since. I've learned that these drones can really be fail safe if you take the time to understand them. I was very luck because the drone shot through the gap between the power lines without touching them and then I landed it safely.
2018-1-30
Gunship9
munchausen Posted at 2018-1-29 22:36
Gutsy move to put the autopilot in charge of flying the drone home, at slow speeds, when GPS is cutting out.  Putting it in Sport mode and racing back manually seems safer.
2018-1-30
m1n1s
Flight distance : 319915 ft
twice + , battery fell out of no.1 spark and crashed to the ground, second time was delibrate to see what happens when the rc unit battery goes flat during flight, third run the spark battery to flat during hover to see what happens.
2018-1-30
A CW
Flight distance : 14754314 ft
Twice but regained both times and landed safely - sold it after the second time.
2018-1-30
ADM-Frank
Mexico
A CW Posted at 2018-1-30 15:04
Of the drones you have had, which one do you think is the best?
2018-1-30
A CW
ADM-Frank Posted at 2018-1-30 22:11
For my personal needs the Mavic Pro Platinum has been the best all round drone that I have owned although the Phantom 4 Pro has the best camera. I've also flown a friends Inspire 2 X5S but yet to own one of those LOL
2018-1-30
Bing Err
Flight distance : 9249964 ft
2 times of 350 flights. Both times the Spark came back safely. BTW, you can't answer 2 in the poll
2018-1-31
ADM-Frank
Mexico
Bing Err Posted at 2018-1-31 02:58
you're right, the correct way would be two or more, thanks for the info
2018-2-2
ADM-Frank
Mexico
A CW Posted at 2018-1-30 23:54
XD, I'm thinking about getting a mavic pro, but I'm waiting to see if the mavic pro 2 comes out
2018-2-2
A CW
It is tough as you don’t want buyers remorse but equally you do want the next step ASAP! It’s important you make the right choice as selling and buying drones loses you a lot of cash. The Mavic Pro is a great drone, the Platinum slightly better due to the added flight time and quieter motors but there are also some great deals now on the Alpine White and even better on the original MP. The ‘MP2’ hasn’t been announced and nobody can say when it’s coming - the Mavic Air also looks like a great upgrade to the Spark
2018-2-2
ADM-Frank
Mexico
A CW Posted at 2018-2-2 14:50
thanks for the advice, friend, then I will wait a little longer to plan what will be the next drone to buy
2018-2-2
Chirpz
Flight distance : 20256 ft
Often, but we do have a lot of wifi interference in our area.  I loose visual connection to my Ipad 4 mini, but I do not loose control of the ship.  I always pay close attention to the direction the ship is pointing so that if I do loose the connection, I can still fly home on dead reckoning.  I do not trust the RTH feature and would never use it unless there is no other option.
2018-2-3
Beario
I've never lost signal but I've never flown with anything other than the remote controller.  I do not think flying with a phone is ideal and I wont ever fly without the remote.
2018-2-3
Tom_A
Flight distance : 899951 ft
I have received weak signal messages but never have lost control of the drone. The few times this has occurred have been at the beginning of a flight when the drone was close by and could be landed easily.
2018-2-4
TonyFonagerDK
Flight distance : 245013 ft
Recently, it happens on almost EVERY flight with my Spark - sad, but true!!!
2018-2-5
Velospinner
Flight distance : 532671 ft
No loss of signal or control so far. But I always fly VLOS, for me this means 150 m at max. - distance and/or height.
2018-3-17
The Bash's
After reading this I think I want to calibrate something or update a firmware because I loose signal a lot, sometimes a few times on each flight.  I don't have a incredible range on it either sometimes I cannot even break 500 meters.... I got to 1000 meters once but, I was sitting in my attic with the remote basically out of the window.  I might have been able to go further however, hitting the 1000 meters was accomplishment enough for me since most flights in that direction have signal lose.
2018-3-17
The Bash's
Oh forgot to add that all of the times that I have lost signal only three times I lost GPS and had to fly home to me in ATTI mode.  I have had a few instances recently that with GPS lock and 10+ sats the Spark has drifted and wont hover still... I snatched it out of the air last week because I was trying to land it in a parking lot that had little poles that had reserved spaces signs and it was drifting right for a cluster of them and I didn't want to accidently over correct and break a prop.
2018-3-17
JaredD
Flight distance : 298957 ft
I have had it lose connection intermittently when i was flying at 600+ metres away, but it was usually only for a moment,  I think the longest I have lost connection was probably about 20 seconds.  I do not fly unless I get confirmation in the app that the homepoint is set though, so i have not worried so far.
2018-3-18
heliman
I loose signal often, but always have a home point set near me. When it happens I usually try to make it ascend for better gps and rc reception.
2018-5-26
sidtx
Flight distance : 266729 ft
Never really lost control.
Just lost the signal a couple of times, due to distance and urban interference.
Both times, the Spark faithfully flew home.
Sid
2018-5-26
123Next >
