Dji Spark......no pano mode,no multiple photos mode
1614 7 2018-1-31
fans0f4e312c
Ho Everybody .
I just get a Dji Spark.....and when I open photo Mode I have only one option -Single Photo- no pano mode,no multiple photos ,no 3 photo burst etc mode.
Those are not displayed on screen very strange by the way I use only the I phone 6 to control the drone.Any help its apreciated...........
2018-1-31
Kloo Gee
Flight distance : 16783757 ft
Is it possible you are in gesture mode?  If so, switch out and go to normal mode.
2018-1-31
SOUNDWAVE439
Flight distance : 115597 ft
Make sure you are reading the manual. Test everything out.
2018-1-31
DJT_MVSP
Flight distance : 2018645 ft
Make sure you're not in sport mode
2018-2-1
Grmachine
The last guy on these forums had that problem, turned out he didn’t have an SD card in. Have you checked to make sure it is clicked in and a compatible SD, did you format it thru the Drone? I had one that couldn’t be used until I formatted it.
2018-2-1
fans0f4e312c
Thanks for everybody help the answer is : You must formated the mini sd card to let all new information flowing....now I have all photography modes back.Thanks
2018-2-1
DJI Elektra
fans0f4e312c Posted at 2018-2-1 19:49
Please check the message in the image screen when you encounter problems. I would recommend you read our manual carefully. Thanks for your support.
2018-2-1
lcw1982
Flight distance : 80522 ft
I had this issue and found out the remote controller was in sports mode. Switched it back to normal mode and it was ok.
2018-2-1
