New Mavic Air Firmware Released
123Next >
29722 106 2018-2-9
DJI Support
Flight distance : 2408 ft
Overview
  • Date: 2018.02.09
  • Aircraft Firmware: v01.00.0200
  • Remote Controller Firmware: v01.00.0100
  • DJI GO 4 App iOS: v4.2.5
  • DJI GO 4 App Android:v4.2.5
What’s New?
Aircraft:
  • Added support for using SmartCapture without a remote controller and DJI GO 4. Added a group photo mode to SmartCapture.
  • Optimized GEO Zone management.
  • Shortened time taken to power off.
  • Optimized transmission quality when transmitting at 2.4 GHz.
  • Improved takeoff performance to dampen a shaking phenomenon experienced by some aircraft during takeoff.
  • Improved takeoff performance when taking off in conditions that are not suitable for the Downward Vision System.
  • Optimized Asteroid exposure settings.
  • Fixed an issue that occasionally prevented the aircraft from taking off following activation.
  • Fixed an issue that occasionally caused the DJI GO 4 app to display a Downward Vision System calibration error.
  • Fixed an issue that caused the battery level display to be incorrect if an Intelligent Flight Battery was not fully charged when used for the first time.
  • Fixed an issue that occasionally caused the aircraft to land unexpectedly.
Remote Controller:
  • Added support for using the DJI Goggles Head Tracking Flight feature.
  • Shortened time taken to power on.
  • Changed default control stick deadband settings.
  • Fixed an issue that occasionally caused the remote controller restart automatically.
  • Fixed an issue that occasionally caused linking to fail.
  • Fixed an issue that occasionally caused iOS device to start charging and the DJI GO 4 app not to connect to the aircraft when a mobile device was attached using an RC cable.
  • Changed the default settings for the Function button and Customizable button.
Notes:
  • Restart the aircraft and remote controller after the upgrade is complete.
  • Please note that the firmware update may reset various Main Controller Settings, such as the RTH Altitude and Maximum Flight Distance, to factory defaults. Before the update, take note of your preferred DJI GO 4 settings, and readjust them after the update to suit your preference.
  • This firmware update resets the camera settings.
  • If the firmware upgrade fails, restart aircraft, remote controller and DJI GO 4 or DJI Assistant 2, and retry.
2018-2-9
d.a.v.i.d
Flight distance : 3301621 ft
Slovakia
@DJI,
Is there possibility to downgrade to previous firmware once upgraded?
Anybody tested?
2018-2-9
Thanks for the info!
2018-2-9
lannes
Flight distance : 4465 ft
d.a.v.i.d Posted at 2018-2-9 03:47
@DJI,
There is the downgrade option to .0100
2018-2-9
Flight distance : 10186312 ft
It’s FW update at the office today, P4Pro,Crystalsky, MavAir, anymore.... yes there is Mavic Pro .
2018-2-9
chrysek
Flight distance : 210574 ft
Hi, updated to new firmware and on my dji appI got two thick vertical lines.
2018-2-9
The flying dodo
Flight distance : 508255 ft
"Improved takeoff performance to dampen a shaking phenomenon experienced by some aircraft during takeoff." Nice Job
2018-2-9
Surface2Air
Flight distance : 167441 ft
Yeah! Thanks for addressing the ‘shaking’ issue so quickly. If I have a chance to test today, will report.
2018-2-9
Cameleon
Flight distance : 60394 ft
So want to install this, but also so aware its a Friday afternoon and being a software eng, I know what Friday afternoon builds/releases are like
2018-2-9
chrysek
After I updated my Air to new firmware I got those two vertical lines on my app, but it does not seem to affect video or photos.
UPDATE: when I rebooted both drone and remote plus restarted my app those thick vertical lines are gone and seems all to be ok.
2018-2-9
Tadango
Flight distance : 232359 ft
How do you activate the SmartCapture mode without the app?
2018-2-9
LoSBoL
Flight distance : 666483 ft
Good updates if I look at the changelog.
Updating worked great, although I still can't connect the Remote with the DJI Assistant on Windows 10. Had to update the Remote with the DJI Go app.
2018-2-9
Tadango
Mmh, my android app version is 4.2.6...... what am i missing?
2018-2-9
Cameleon
Tadango Posted at 2018-2-9 06:39
+1 - I'm not at home so I can't update and check it out. Some kind of release notes or instructions somewhere? Maybe it just does it as soon as you turn it on by default?
2018-2-9
Tomcatuk
Flight distance : 28743 ft
Being new to DJI and my first drone, I did the first update via the app, this second update I thought I would try Assistant 2 and happy to say they both worked first time, though did get a message pop up about a Kernel but vanished before I could read it fully, this on a PC windows 10 machine.. all in all a happy bunny
2018-2-9
LoSBoL
Cameleon Posted at 2018-2-9 06:55
Oh, yes please! +2
2018-2-9
Tadango
Maybe there is a new button mode with 4 beeps: Enable Smart Capture or something.... Will try in a few minutes
2018-2-9
Tadango
I did not find the option... but the controls feel much better
2018-2-9
dari_017
Flight distance : 6016004 ft
Is this update also for the intelligent batteries of the MA ?
2018-2-9
Wachtberger
Flight distance : 261509 ft
hallmark007 Posted at 2018-2-9 05:06
Yes, very exciting :-) CS done, now MA...
2018-2-9
M2Wair
Flight distance : 1192231 ft
I took  little drive to a monastery local to where I live today, hoping to get some nice aerial footage. Set up the Mavic, turned on the RC & AC opened the app go figure FW update notification, back home and updated, so will go back to the Monastery tomorrow.  Thankfully only 5 minute drive so no hassle.
2018-2-9
Wachtberger
dari_017 Posted at 2018-2-9 09:03
This time it's only for MA and RC. Have changed battery to check and there was no update notice.
2018-2-9
Spaceman_66
Flight distance : 82323 ft
Wachtberger Posted at 2018-2-9 09:34
I just within the last 1/2 hour did the same, and found just as you did that she was still 100% good to go after swapping out batteries. But like you I had to do an AC FW update, and I think a total of 2 for the RC (the second one was much smaller and faster, like 7 MB). Maiden flight tomorrow afternoon!
2018-2-9
dari_017
Thank you Wachtberger for that, I will only charge 1 battery to do the update since it is too windy to fly here today, have you had a chance to test the new firmware with your MA ?
2018-2-9
Wachtberger
dari_017 Posted at 2018-2-9 09:58
No, not yet. It's evening/dark here already. Tomorrow I shall test.
2018-2-9
dari_017
Wachtberger Posted at 2018-2-9 10:07
Great I’ll keep an eye here to see if you found anything , thanks again.
2018-2-9
Wachtberger
dari_017 Posted at 2018-2-9 10:30
You are welcome!
2018-2-9
I downloaded new FW and I flew for just 15 minutes as wind here was 45kph , everything is working fine, no shaking although I don’t know if I had shaking because this was the first chance I had to fly my Mavic Air.
I have to say it is working great I didn’t have any problems.
2018-2-9
RGMGFitness
Flight distance : 233757 ft
We'll, I just tested my new Mavic Air with this firmware release.  EVERYTHING WORKED!
Though, I'll mention it was suppose to be a quick 'Maiden Voyage' with my new Mavic Air.  Needless to say I did all the firmware updates last night (or at least I thought I had).  It's about 34 degrees (F) outside / 1 degree (C) and with the wind chill I would say it's 10 degrees colder.  So, that being said I guess I can confirm I did NOT have the "shaking phenomenon" some were experiencing.  Though it appeared to happen to most in the colder weather.   Again, everything appeared to be working fine.   Was just a little frustrated seeing the firmware update as I was standing outside trying to put a video together.
We'll, that being said I guess it's a necessary evil to fix some of the bugs.  I'm still warming up my hands.  For those interested I should have a video up later tonight on my YouTube Channel.  I think I got some good footage.
Oh, one thing worth mentioning.  The default setting for 'recording video' appears to be the INTERNAL Built in 8 GB STORAGE.  I got a prompt to change to the micro-SD card after memory filled fairly quickly (was shooting in 4K Video).  Just something to be aware of.  I did not see a setting to change this but the PROMPT I received allowed me to make the change.  I may have just missed that setting when setting everything up, but something to be aware of.
My YouTube Channel:  https://www.youtube.com/c/RGMGFitness
All good!
2018-2-9
Franco64
Flight distance : 542103 ft
Upgrade done. Tomorrow in the morning (hope in the weather here in Milan) second flight of my little career of MA pilot
2018-2-9
dari_017
hallmark007 Posted at 2018-2-9 10:31
Nice thank you for that. I wanted to fly as well today after updating but the wind is crazy here. Will test mine tomorrow.
2018-2-9
slyfox0
Flight distance : 118 ft
Glad to see that the shaking problem has been addressed. Thank you DJI.
2018-2-9
RGMGFitness
DJI Team,  shouldn't this 'Announcement' be posted in the forum under 'Mavic Air'.  Looks like it's just posted under 'Mavic'.  I'm thinking it will have better visability under the heading of 'Mavic Air'.
2018-2-9
North Idaho Guy
Flight distance : 2310082 ft
Any chance the aircraft's FW update tweeks flight handling? As compared to my Spark and Pro Platium, my Air just doesn't seem to fly as fluid. Anyone else notice this? Just me? The Air fly's okay but, just seems a bit more refinement is needed in overall flight smoothness, especially indoors I notice this...........Seems to jerk around a bit at times, the Spark in same flight area is sooooooooooo much smoother.
2018-2-9
fans6d0133cb
Flight distance : 400 ft
I have noticed this as well with my air. Doing the update soon and Will test it.
2018-2-9
North Idaho Guy
fans6d0133cb Posted at 2018-2-9 13:30
I as well, just not able to update until later tonight, be able to fly tomorrow and will report back............Glad to hear someone else noticed this bit of random erratic flight behavior.
2018-2-9
fans473e667d
Flight distance : 620600 ft
Presd the function button two time and it will start the smart capture. Put it on the ground and it will start recognise the pilot. Use the palm to takeoff as usual
2018-2-9
Cameleon
fans473e667d Posted at 2018-2-9 14:04
I was just about to post this. Havent tested it properly as inside at the moment and dark outside, but did the F/W update and if you have the controller and phone connected and press the rear button twice the MA will beep and you will see it in smart capture mode on the screen. Does the same with no RC so assume it works without the RC.
Now, do I trust to use it in Smart Capture mode with no RC, hmmmm.
2018-2-9
AussieFlyer
Flight distance : 165213 ft
Cameleon Posted at 2018-2-9 15:16
Is it just me or does anyone else think it ironic that a 'new' drone released only on 28 Jan 18 needs so many 'fixes'?
2018-2-9
North Idaho Guy
AussieFlyer Posted at 2018-2-9 15:42
A bit, yes!  Beta testing seems to have fell a bit short........Perhaps we (initial run buyers) are the beta testers eh?
2018-2-9
123Next >
