RTH while in Sportsmode, Obstacle avoidance?
729 4 2018-2-11
LoSBoL
Flight distance : 666483 ft
So I've been reading the manual and turned it up side down and inside out (way to windy to fly today) and I can't seem to find the answer, so maybe some of you already have the experience.
I know that when in P mode, even with Obstacle Avoidance turned OFF, the Mavic Air will turn it on by itself if you hit the RTH button.
But what happens when you hit RTH in Sports mode? Does it change the flight mode itself, turn on Object Avoidance by itself and slowly return to Home? Or does spear home with sports speed without Object Avoidance?
2018-2-11
cyborg
Flight distance : 123960 ft
will MA do RTH in sports mode ?   I suppose you have to override RTH (if initiated by MA) and then switch to sports mode and do manual RTH ?.  I remember seeing a youtube video where MA actually slows down to preserve battery charge, so no sports mode there
2018-2-11
Jeff7577
Flight distance : 1916821 ft
Yes it will, as log as it is enabled in settings. While returning home you can push the stick forward and it will go faster.
2018-2-11
LoSBoL
Jeff7577 Posted at 2018-2-11 06:32
Thanks for the confirmation!
2018-2-11
cyborg
thanks for the info..!!
2018-2-11
