DJI Assistant v1.1.6 DevTools (NO LINKS)
20791 33 2017-9-8
M1dn1ght N1nj4
Flight distance : 11522 ft
NOTICE!!!!!!
Due to DJIs rules, I will NOT be posting links to any of my work here.  No guide on how to do it, links to a modded app, or an app that will bypass any safety measures in the Assistant app.  If you want to know how to do it (when I release it), you'll have to do a bit of Googling on your own)
What's being posted here is for informational purposes ONLY!
Since installing the new version on the PC, I noticed I couldn't get into DevTools by the old "main.js" method anymore.  So I set out on a mission.
My initial attempts brought me here:
https://ibb.co/mnU7gv
It flashed into view for about half a second, then went blank.  Poo.  Needs more work.  So on to a different approach.
This one bypassed the debug method, and enabled the main menu options shown here.
https://ibb.co/nwKnYa
However, upon opening up the Dev Tools option, a new, fully blank window opens up.  In fact, all three new options open blank windows.
My next method will be detailed later.
2017-9-8
R&L Aerial
Flight distance : 298100 ft
Im following this. ( wink,wink)
2017-9-9
lafoto
Flight distance : 1402680 ft
Portugal
subscribed!...
2017-9-9
bapski
Flight distance : 56171 ft
Interested to know
2017-9-9
M1dn1ght N1nj4
UPDATE!  Not there yet, but I'm really close to getting some extra features working!
  (if the video doesn't load, just wait.  It should be available within the hour.  I JUST uploaded it)
2017-9-9
M1dn1ght N1nj4
In the mean time, if your Spark is on the latest .0600 firmware, you can still use Assistant 1.1.2, enable DevTools, and still be able to change settings and parameters.
I just gave the speed hack (Sport+) a go, and it most certainly works!
Word of warning!  Probably best to leave the deceleration speeds on default.  Doing a -10 for decent can EASILY cause your Spark to slam into the ground.  That's what happened to mine, except I landed on a field full of thick, fluffy grass, so it sustained ZERO damage.  I was lucky, but you might not be.
I'll make a video about it later this week.
2017-9-11
Realphil
Flight distance : 326644 ft
Does somebody can give me the download of the Assistant 1.1.2?
thx
2017-9-30
ThomasBest
Flight distance : 33891 ft
https://www.apkmirror.com/apk/dji-technology-co-ltd/dji-go-4/
2017-9-30
Supervisor
Flight distance : 197602 ft
M1dn1ght N1nj4 Posted at 2017-9-9 18:39
https://youtu.be/1WJwiqUyw6k  (if the video doesn't load, just wait.  It should be available within the hour.  I JUST uploaded it)
main.js is now integrated in app.asar. You can unpack the file, modify it, and then repack it. util.js has a function called "banDevTool()". I think that's the culprit that prevents dev tools from showing up under 1.1.6.
2017-12-16
Supervisor
I just compared the files inside app.asar. The HTML for the dev tool menu has been removed from 1.1.6. Looks like we are stuck with 1.1.2 for now.
2017-12-16
Ricardo Ghion
Flight distance : 1042037 ft
Acompanhando
2017-12-19
fansa2fa9188
Flight distance : 43074 ft
there is the 1.1.8 now check goggle re web page ... how to activate ground station in 1.12 ? thkks
2017-12-22
Drones Puppet
Flight distance : 390154 ft
Any news here?
2018-2-20
Sparkinator
Flight distance : 204416 ft
interesting
2018-2-20
M1dn1ght N1nj4
I am still timing with v1.2.0.  Not much to report at the moment though.
2018-2-20
djiuser_Cyclone2390
Flight distance : 84065 ft
How do I get a copy of Assistant 2 version 1.1.2?
2018-2-23
fans011bfe06
Flight distance : 259462 ft
very interesting.. I hope you managed to unlock the devtools.
2018-3-14
Jos A
Flight distance : 73209 ft
THIS IS REALLY INTRESTING
[size=14.6667px]https://dl.djicdn.com/downloads/dji_...(b21de8d8).zip
[size=14.6667px]
[size=14.6667px]With Notepad++, edit the main.js file.
[size=14.6667px]Look for " // mainWindow.webContents.openDevTools()"
[size=14.6667px]Delete the "// " (slash slash from that line
[size=14.6667px]Save the file
2018-3-15
Jupiops
Flight distance : 121555 ft
For .asar opening with Windows use this Plugin for 7 Zip. Works well with the latest Portable Version of 7 Zip.
In the main.js you can finde a Line where closeDevTools() will be called. Commenting this line out will prevent the DevTools from disappearing after 1 Second.
Tested with DJI+Assistant+2+1.2.2.845
2018-3-17
AvatarAir
Flight distance : 150932 ft
What's going on, bro? A lot of people are anxiously waiting. "-)
2018-4-5
FlyEarthes
Japan
I use DJI Assistant2 ver1.2.3  I succeeded in opening devtool. But  I am troubled not to recognize the aircraft.
2018-4-15
M1dn1ght N1nj4
FlyEarthes Posted at 2018-4-15 17:59
I use DJI Assistant2 ver1.2.3  I succeeded in opening devtool. But  I am troubled not to recognize the aircraft.[view_image]
I'm going to try to get a little more done on this tonight.  And I'll try to make a video on it on my YouTube channel.
It should still recognize the Spark.  Try closing the debugger to take it out of :pause" state, and see if it works then.
2018-4-16
fansa2fa9188
Is there some tools to compil the .asar , seem , there is a cheksum test and when you change the main .js , seem to  kill everything..
thks
2018-4-18
FlyEarthes
Japan
fansa2fa9188 Posted at 2018-4-18 12:42
thks
All the files in the AppFiles folder are being monitored.
It will not work if you make slight modifications to other files.
2018-4-18
Alexis007
Flight distance : 227208 ft
How did you do it?
Thanks,
Alex
2018-5-13
APPSolute
Flight distance : 25095 ft
Hungary
subscriibed
2018-6-25
M1dn1ghtN1nj4
Well, account got reset back to zero.
2018-6-25
M1dn1ghtN1nj4
I can't get back into my original account.  Don't know what happened.  It's still me, just short the "4" from my old name.
2018-6-25
fans4f77c561
Flight distance : 223 ft
DJI Assistant v1.1.6 - DevTools
2018-7-4
Papaxiclas
Flight distance : 5455981 ft
Portugal
hummmm any news?
2018-8-15
Olivier27
mmm, still can't detect the device once debug enabled
2018-9-28
zendx2009
Flight distance : 112972 ft
Ukraine
In the new versions, DJI uses VMProtect for some dll \ exe, in which the checksum of files located in the AppFiles directory is checked. Therefore, any change in app.asar (and some other files) causes the backend to stop. Unfortunately, it is (practically) impossible to bypass such a check, because VMProtect is used for executable files.
2018-11-14
zendx2009
Ukraine
I have successfully managed to bypass hash checking, but, unfortunately, in debug mode, the backend does not expose all needed (in debug mode) endpoints.
2018-11-21
sincabeza
Flight distance : 2508911 ft
no any news on 1.1.6 ?
2019-9-16
