Video feed still gets disconnected on iPhone 6
1165 12 2015-5-13
mountmotor
Hey guys, so my RC and Craft are both updated to the latest firmware and I still lose video feed on my iPhone. However, I still have complete control over the Inspire. It happens rarely but when it does, it still freaks me out...Does anyone else still have this problem?
2015-5-13
sbarryjackson
Flight distance : 18931532 ft
Mount...go HERE. Does not look like this will ever be able to be fixed.
2015-5-13
mountmotor
sbarryjackson@s Posted at 2015-5-14 04:08
This happened on the last firmware as well...Seems like the firmware for the RC might be glitchy.
2015-5-13
dbeck
Same here on mini.  First time. Who has the older version (1.1?) of the iOS app. I'm done upgrading anything. More bugs then before!
2015-5-13
Blademan
I have had this problem twice last weekend.
image missing on iPhone and HDMI output
Firmware v1.2.1.03
Previously, this has not happened.
2015-5-13
dbeck
Same here. And there are people who state it's our moral, civic and legal responsibility to ALWAYS UPDATE. Bull. I want the old iOS 1.1 back. This new one sucks
2015-5-13
christopher.kee
I just flew the I1 30 minutes ago. I experienced my first ever loss of video feed using an iPhone 6.
I thought it was a cord problem, but here we are!
I was over water and lost about .5 years of my life through shock I think.
Also, the video has never been this "choppy".
This is a direct result from channel restriction feature in the new upgrade as sbarryjackson's link suggests.
The overall experienced has been dramatically deteriorated by this new upgrade.
I hope an answer surfaces, I don't have the time to learn how to code.
2015-5-13
PeteGould
READ THE SECOND EMAIL IN THIS THREAD, posted by sbarryjackson, and follow the link. This is NOT a bug.  It's a legal limitation.
2015-5-13
dbeck
I read it. I get it. It still drops out. So what's the solution?  I can answer that. Go back to a previous version. This is dangerous!  I (and others) loose total screen drop out for minutes at a time,  The only solution is to land (hopefully where you can see where). Unacceptable. I know the reasons. It needs a fix ASAP
2015-5-13
PeteGould
dbeck@promobox. Posted at 2015-5-14 09:00
I read it. I get it. It still drops out. So what's the solution?  I can answer that. Go back to a pr ...
What fix do you want?  DJI can't put the original channels back or they will be fined out of existence by the FCC.  Obviously this was a huge screwup by DJI when they initially designed Lightbridge and apparently just used whatever frequencies the engineers felt like using, without bothering about what part of the spectrum they fell in and whether or not they required licensing.  It may not be possible for them to fix it.  I don't know offhand what other frequencies may be used without a license or whether the existing hardware could be programmed to use them.  My guess is that the 8 currently available are all there is.  Yes - huge problem, and we need answers from DJI.  But I don't see those other channels coming back.
As to it being dangerous - the FAA requires line-of-sight operation and specifically prohibits FPV operation.  If you're following the rules, losing the camera signal is annoying but not dangerous.  If you're not... that's on you.
2015-5-13
sbarryjackson
PeteGould Posted at 2015-5-14 10:58
What fix do you want?  DJI can't put the original channels back or they will be fined out of existe ...
"the FAA requires line-of-sight operation and specifically prohibits FPV operation.  If you're following the rules, losing the camera signal is annoying but not dangerous."
Exactly!
2015-5-13
DrPhil
I live in southern Norway where the lightbridge can not be used all channels are blocked.   Yeey  i got a inspire 1 with a dead videofeed. Almost no reason to own one here now after the update.
2015-5-14
FoxSTI
Flight distance : 11286 ft
So what does this mean?
You can be in the middle of a shoot and then you loose your feed and metrics?   does the video lag ?  I bought the inspire specifically for the light bridge as I was fedup with how the parrot bebop's video was laggy and just plain crap.
I have not upgraded firmware, just the tablet app. However, I was looking forward to upgrading in the future and allow DJI to improve their product.
Is there really not way for them to fix the performance? We can live with less channels, but they just need to perform.
@DrPhil, have you contacted DJI or your reselled?
2015-5-14
