iPhone SE screen dims after a couple of seconds
1432 20 2018-3-5
Yesterday I tried to make some hyperlapses with active track, but I noticed the screen dimmed after a couple of seconds. My Osmo Mobile (1) is up to date and I am using an iPhone SE running the latest iOS (11.2.6)
I tried to find a setting for this, but could not find any.
Do I miss something?
Thanks in advance,
Peter
2018-3-5
Is this the first time this issue happens? How about rebooting everything? Does the issue persist?
2018-3-5
pauldpaul
I'm still waiting for my osmo mobile 2 to arrive but something ive noticed with my SE is if it is in battery saver mode then the screen dims much sooner, check you dont have battery saver mode on, if the battery icon in the top right is yellow then you have battery saver on.
2018-3-5
pauldpaul Posted at 2018-3-5 02:25
It seems a nice point, thanks for sharing.
2018-3-5
DJI Mindy Posted at 2018-3-5 02:15
Yes, it was the first time.
And only when in hyperlapse mode.
I will try if it also happens in other modes.
2018-3-5
Thanks for the suggestion, but the iPhone does not dim the screen in other apps.
Only when in DJI Go.
2018-3-5
I will also try rebooting.
2018-3-5
Montfrooij Posted at 2018-3-5 02:36
No problem, more tests would be much appreciated.
2018-3-5
DJI Mindy Posted at 2018-3-5 03:07
To be continued.
2018-3-5
Snaver
Flight distance : 45226 ft
My 6s plus dims as well when shooting any time lapse. I assumed that this a feature, to reduce phone battery drain. If your shooting for long periods of time, do you need to see a fully lite screen? When darkened, just touching the screen restores it to full illumination.
Brings up a good point though.
DJI really needs to improve the operating manual for the OM2.
2018-3-5
Snaver Posted at 2018-3-5 06:10
I agree on the timelapse part, but when shooting a hyperlapse with active track you do want (need) to check if your subject (that you are tracking) is still being tracked.
Otherwise you may end up with a perfectly ruined video of something you did not want to have tracked as GO lost track (and you did not see that in the dimmed screen).
2018-3-5
Dear Mindy.
Can you confirm it #10 is right?
(like this is designed to work like that)?
And if so ask for either:
1. a way to disable this (that would be my preferred way)
2. disabling this when in active track mode
PS, both for Osmo Mobile v1 and v2
2018-3-5
I verified with another user (https://forum.dji.com/forum.php?mod=viewthread&tid=138762) he also has the dimming. (see #7)
2018-3-5
Montfrooij Posted at 2018-3-5 23:01
I didn't notice Miltmanos's screen got dimmed as well from the video, but I'm confirming with our engineers for verify the working principle of the current DJI Go APP since I saw other users reported the same issue but I didn't find it with my iPhone, I will let you know once I hear from them, please wait for a moment.
2018-3-8
DJI Mindy Posted at 2018-3-8 02:03
Patience is my middle name
Thanks already.
I can imagine why DJI made this for regular timelapses and even motion timelapses. (saving battery)
But when in hyperlapse mode you want to check your screen.
2018-3-8
Montfrooij Posted at 2018-3-8 02:09
Thanks already.
Hi Montfrooij, thanks for your patience, we have verified with our engineers, this is a feature aiming to save battery, we will add the button the future APP so that customer can turn on/off this feature.
2018-3-9
DJI Mindy Posted at 2018-3-9 02:15
Thanks a lot. That would help for hyperlapses
2018-3-9
WebParrot
Flight distance : 23625 ft
Sorry for the delayed reply.... missed your original post.  With regard to battery preservation.... You may be experiencing some of the battery protection algorythms that Apple employed when a battery has started to loose it's capacity.
Apparently Apple added firmware that would slow down certain demanding operations to save battery, the idea being that you could still make a phone call/emergency call with the battery being low.  In the last week ( today is April 10 ) an iOS software update (11.3) was released.  It has as part of it the added <Battery> under Settings.  One of the options under <Battery>  "Battery Health (Beta)" which when selected will display your batteries Maximum Capacity as a percent.  Basically telling you how much "life" is left in your battery.
While there are other functions that allow you to "turn off" the slow-down/protections, the capacity one is most helpful to me.  Lets me know whether it's time to replace the battery without that day when I've not backed up the phone and the battery dies....permanently.  You SE is a few generations old and you might be close to needing a replacement.
Hope this helps.
2018-4-10
WebParrot Posted at 2018-4-10 05:11
Apparently Apple added firmware that would slow down certain demanding operations to save battery, the idea being that you could still make a phone call/emergency call with the battery being low.  In the last week ( today is April 10 ) an iOS software update (11.3) was released.  It has as part of it the added  under Settings.  One of the options under   "Battery Health (Beta)" which when selected will display your batteries Maximum Capacity as a percent.  Basically telling you how much "life" is left in your battery.
Thanks for the suggestion.
I will give it a try.
Just updated a few days ago
2018-4-10
Yeri Tan
Try updating the app and other common ways like restarting and hard resetting iPhone. If no use, maybe an ios system recovery tool can help you.
2021-6-24
Yeri Tan Posted at 6-24 23:08
Thanks.
No problems anymore.
2021-6-24
