Missing photo from DJI go, using OSMO Mobile
12950 40 2016-11-19
fans93ffb7a6
Flight distance : 145328 ft
I have been the DJI Go app with IPhone to take video and photo.  Noticed that my photo are all missing.  Video is ok. Anyone has this problem?  Or is there any setup that I need to do,  I cannot find any!  Thanks
2016-11-19
fansd3fbd693
I am having the same issue! Did DJI fixed the issue yet?
2016-11-27
DJI-Thor
Try this
Connect your iPhone/iPad to your computer,
Launch iTunes
Select your iPhone under “Devices” on the left. If it’s not there, unplug/replug your iPhone/iPad.
Select Apps from the top menu
Scroll down; under File Sharing, Find DJI Go and select it
Find the two folders "HD300 Storage"  and "Video Cache"
The first stores your photos, the second stores the videos,
Select the folder and click "Save to" , and transfer these two folders  into your computer.
2016-11-28
titaniumtommy
Can you make this accessible via the app or better yet just save them to the camera roll?  I'm traveling and I can't connect to computer.
2016-11-30
DJI-Thor
titaniumtommy Posted at 2016-12-1 06:29
Can you make this accessible via the app or better yet just save them to the camera roll?  I'm trave ...
Please update your DJI Go app, it should allow you bulk save to camera roll now
2016-11-30
Pizzaya
Portugal
DJI-Thor Posted at 2016-11-30 19:54
My photos from yesterday are missing as well as slow motion videos and long exposures. I'm on travel with my iPhone SE. Where are they? This is NOT good!
2017-6-3
fansf3496fc1
Have they fixed this yet? It's really annoying having to plug into computer to find them in the cache folder.
2017-6-8
fansa786f6af
Flight distance : 80919 ft
I have the same issue each time I use it,.  Seems to be hit or miss to which photos I keep or end up missing. I would really like to know if this is fixable.   When using the mobile version it as to download from SD card, that shouldn't even be an option.  Please advise.  iPhone 7 plus, osmo mobile all the latest firmware.
2017-6-10
mculpii
Flight distance : 837625 ft
Just took video and photos with my iPhone7 Plus using my Osmo Mobile and DJI GO App. When I turned it on it had a new firmware update. The Update completed and I captured a lot of video and photos. I'm now
reviewing them in the DJI Go App Editor and my videos are there, but photos ARE NOT! The photos tab says "No Photos". Where did they go? I am very upset as this was my sons NJROTC Leadership Academy Graduation. If the photos I took are gone forever I will be sick.  Ugh Any advice is appreciated! Please Help!
2017-6-10
mculpii
Do the DJI admins answer on the weekends? If not I understand but still trying to find my missing photos. Ugh
2017-6-10
mculpii
Update : I found ALL of my missing photos! I followed DJI Thor's tutorial above and found them under the folder "HG300 Storage"!
2017-6-10
DroneGuyEd
Flight distance : 1168140 ft
This would seem like a pretty substantial bug that needs immediate attention by DJI.  Mine were missing too, and the recovery process worked, but few users would ever find this method.
2017-6-11
DroneGuyEd
Multiple updates to DJI GO and this is still broken.  Is anyone awake there at DJI?
2017-7-5
FlyingFish82
Flight distance : 3951427 ft
ive seen the issue where the images do not appear in the app, but then as soon as you turn the osmo and pair it to the phone they appear..very weird behavior from the app..hope DJI is looking into this..
2017-7-6
Kevinsworld
FlyingFish82 Posted at 2017-7-6 06:33
Same issue observed and quite annoying.  Sure seems like a bug that needs addressing.  One other way to get them exposed in the Photos App camera roll is to go into the DJI app, connect to the device, hit the play button to access current photos and video and then one by one use the bottom left icon which will Save it out back to the main camera roll.
Hooking up the device to the computer is of course another option but that's just a workaround that not feasible a lot of times out in the field.
Kind of hard to believe somebody at DJI wouldn't have seen this in some basic QC testing.
2017-7-25
fans36e4cf80
I'm having exact same issue with my photos missing from the library within the Editor. But once connected to the app, you can find your photos by pressing the play button. Seems this problem has been going on for a very long time without any fix or at least acknowledgment from DJI. This bug needs attention urgently!!!
2017-7-25
Hi. Guys, sorry to hear this issue.
Can you please provide me the version of your APP and OSMO Mobile? What mobile device are you using? Have you tried another phone to test?
Because I tested with the latest Osmo Mobile firmware and APP with iPhone 6s, the problem didn't recurrence, so I need your help to locate the problem.
Appreciate your cooperation.
2017-7-26
DroneGuyEd
I use an iPhone 7.  I always have the latest GO version and firmware.  Problem seems sporadic and not consistent.  This is the only device I have used with OSMO.
2017-7-26
shine7
Iran
Hi; Have you checked all items in you SD card?
2017-7-26
fansf3a266cf
Flight distance : 341007 ft
Malaysia
Same issue here as well; Osmo Mobile with latest updated DJI Go app also use with my Phantom 3 Advance. Photos only appear in app when osmo is connected. App and device version attached too.
2017-8-5
fansf3a266cf
Malaysia
fansf3a266cf Posted at 2017-8-5 00:15
Both iPhone 5s and 7 Plus
2017-8-5
DroneGuyEd
Saw this again on vacation...most photos missing in action..and some videos.
2017-8-11
Huaqing Zeng
I am using the latest DJI GO and Osmo Mobile 2 on iPhone and I still run into the same issue. I do not find the photos in App.
I can only find it by iTune and get to  iPhone device and under DJI Go APP and save the photos out.
Why DJI cannot fix this?
2018-2-27
AAllali
Flight distance : 24974 ft
I have the very same issue with an IPhone SE.
This kind of bug should have been solved by Dji. I hope that they update the app quickly
2018-3-11
fansecfd5a94
Flight distance : 32051 ft
Kevinsworld Posted at 2017-7-25 05:39
Great Idea. Thank you!
With my iPhone X (iOS 11.2.6) setup with iCloud photos, it's impossible to read iPhone's content with iTunes.  I could only retrieve the missing photos by  connecting my Osmo Mobile 2 to my phone, opening DJI GO in the image/movie capture mode, and then hitting the play button. Then, I was able to save to iPhone. But photos were still missing from DJI GO editor screen. Awful. DJI has to fix that soon.
2018-3-18
DroneGuyEd
Same problem over and over. DJI seems totally incapable of dealing with such basic issues.  A photo device that cant save photos...is just about completely worthless.
2018-3-18
dji_hieu
Flight distance : 65791 ft
I'm having this issue too! with my iphone X!
2018-3-19
fans6d20f655
Same issue here with iPhone X and Osmo mobile 2! Seems to have been going on for ages! Glad I found this out before taking any photos that matter or I’d have freaked lol
2018-3-19
DroneGuyEd
I had considered getting a newer OSMO Mobile 2, but now that I hear of others with the same problem there,, no chance I am going there now.
I think DJI has very good hardware, but their ability to debug and fix basic software issues seems non existent.
2018-3-19
fans6d20f655
I mean it’s a rubbish situation and seems amazing DJI haven’t fixed it. But so far I haven’t lost any photos or videos, and it doesn’t seem like anyone else has. Just a PITA having to have the device connected!
2018-3-19
DroneGuyEd
Since they seem incapable of saving to their own device area, maybe they should just offer the option to save all photos and videos directly to the phone device.  That would also save a lot of time as I always want them there anyway.
2018-3-19
fans6d20f655
Totally agree! I can delete the ones I don’t want from my camera roll. having the option to download/save everything there would be better than this
2018-3-19
DroneGuyEd
Please fix this!
2018-3-23
DroneGuyEd
Please fix this!
2018-3-24
DroneGuyEd
Please fix this!
2018-3-25
DroneGuyEd
Please fix this!
2018-3-26
MalcolmPorter
Flight distance : 172595 ft
Ok so of today mine did the same thing all videos and photos are showing but for some reason not the panorama shots.
Its on the SD card but will not show on the Go 4 app
2018-5-9
MalcolmPorter
never mind  was not importing from SD card my bad
2018-5-9
fans86f9fd59
Flight distance : 143215 ft
Haven’t flown since June, but went out this weekend only to find the same problem with my Mavic.  All firmware is updated, DJI app is updated, and all photos and videos from the past are there in EDITOR.  The VIDEOS I shot this weekend are there in EDITOR....the photos are not.  They’re on the SD card, but the Photos Album in editor are not there.  I tried reinstalling the app....no luck.
2018-9-6
fansdcebf7f7
Colombia
Hola. Tengo un problema con osmo mobile + iPhone 8 Plus, usando la aplicación dji Go. Los videos están en formato .mov, cuando los descargo a la P.C. aparecen corruptos y no se pueden editar. Esto no me pasaba antes.
2018-12-9
