Mavic pro aircraft disconnected at 50 meters randomly
2342 18 2018-3-29
HazzaVanVlazza
Flight distance : 439626 ft
Hi, i was flying my Mavic a few days ago and could not get out 20 meters without loosing signal compleatly on my iphone 7 plus and having to fly back with line of sight not relying on phone at all as it was just black.
I then went home to plug into dji assistant 2 to update all firmware and make sure it was all upto date. after that i took it out yesterday and had th exact same problem. This time i was 100 meters out and struggled to get it back. The drone should not be this unreliable. Has anyome else had this problem? If so how do i fix it or is the drone faulty?
Also i keep getting prompts to update the crutial inteligent flight data and i click update but it does nothing?
Thanks, Harry
2018-3-29
chiplifter
Flight distance : 745180 ft
I have that too on Android:
https://forum.dji.com/thread-138893-1-1.html
2018-3-29
DJI Diana
Flight distance : 2408 ft
Hi Harry, I'm sorry to hear about the issue that you are experiencing. May I confirm that did you fly the Mavic pro with the remote controller or only with the mobile device? Have you changed another open area where the GPS is good and no magnetic interference to try it? If there is any further issue, please feel free to let us know, we'll here for help. Thanks!
2018-3-30
HazzaVanVlazza
Hi Diana,
I was using the controller. And no i have flown there before a range of times and there was no problem.
Thanks, Harry
2018-3-30
Marian
Flight distance : 340597 ft
Hi Harry,
Sorry to hear about that.
I think (not entirely sure though) I had a similar issue with my Android. Have you had a chance to look at your flight logs? Mine was mentioning that  'downlink restored'.
2018-3-30
Harry, it looks like the disconnection is between the RC and mobile devices as you can still control the drone via the controller. Make sure both your mobile and APP have been updated to the latest version. If the screen goes black again, please try to re-plug the cable or restart the APP to check later.
Regarding the flight data, could you post a screenshot of About page for double check? If you have got the latest one, this might be the misinformation, please choose Ignore at this moment.
2018-3-30
integer
Flight distance : 113355784 ft
Try another cable to the bottom usb
2018-3-30
fans88ea0ede
Flight distance : 37103 ft
Same here from last updates. iPhone X and DJI App updated. Random "aircaft disconnected" messages appears
2018-3-30
jerome42
Flight distance : 10617 ft
Try in plane mode, the phone can make interferences.
2018-3-30
Marian
jerome42 Posted at 2018-3-30 04:14
I always wonder, if you are in airplane mode, the map won't be updated as there is no connection to receive data. How are you supposed to get a fully loaded map?
2018-3-30
Griffith
Flight distance : 98537 ft
Marian Posted at 2018-3-30 04:25
Maps can be downloaded and cached before taking off.  Be sure to scan the entire range where you plan to fly and zoom in tightly  in order to download the best resolution for the area.  Then enable Airplane mode before taking off.
2018-3-30
Marian
Griffith Posted at 2018-3-30 04:33
I've seen some folks have the download option in the GO App for maps but I don't have it. Therefore I am unable to download any maps but I could technically cache it before take off. Thank you.
2018-3-30
fans49fa0100
Flight distance : 1650 ft
iPhone X IOS 11.3 and DJI App updated 4.2.8 and last firmware updates 01.04.0300. Random "aircraft disconnected" messages appears.
It is not the USB cable, because when I unplug it, the "aircraft disconnected" red message disappears and a "disconnected" gray message appears.
2018-3-30
Ahmed Hussain
Flight distance : 1339761 ft
Kuwait
Guys, mind you that there are some weak geomagnetic stroms (Kp=5 or 6) that causes the problem.
2018-3-30
Suren
Flight distance : 13498560 ft
fans49fa0100 Posted at 2018-3-30 09:31
I am using the same version of go4 app with iPhone 6s+ and have no issues. Can I ask you to try something if you have the time. Plug your Ac into a pc and downgrade your firmware to 0100 including your RC, after this conduct a re-calibration of your imu, restart Ac and go for a flight and let us know if this fixes your issues.
There has been a lot of issues with the 0300 firmware noted on this forum and 0100 seems to be the most stable version out there for now.
2018-3-31
SparksBird
Flight distance : 10731690 ft
I was having the same exact issue to find out putting my iPhone in airplane mode fixed the issue and I never get disconnects anymore.  Seems my Phone was causing the interference with the controller.
2018-3-31
RBMTS
Flight distance : 169718 ft
SparksBird Posted at 2018-3-31 07:11
I had a couple of disconnects with my Android phone and MPP controller.  After watching a video from 51Drones about the same issue, I purchased a higher quality 1ft. USB cable and connected the phone directly to the bottom USB port (not the side port) as per his video.   Never had a disconnect since.  I now also put the phone in airplane mode just to be safe.
2018-3-31
mickongen
Flight distance : 1349816 ft
Same here from last updates. Black screen and have to land drone and restart drone and controller and then i works. will not reconnect if i restarts go app i flight.
2018-4-1
HazzaVanVlazza
Please fix this issue or can we return to the place we bought the drone from?
2018-4-1
