fans5b25584c
Flight distance : 24012 ft
Sundara Posted at 2018-4-20 22:02
Thanks a lot for your reply. It was helpful. I was able to convert log file to csv. However, the log file is not logging GPS timestamp for each lat,lon,alt etc... The converted csv as well as the log file in data viewer doesnot show the timestamp attribute. Can you help me in how to log timestamp?
If the fog file you converted came from the IOSD using the "EXPORT GPS" function, that file only logs individual points where the camera triggered according to the PC Ground Station mission.
The A2 controller does maintain a complete log of data points, including GPS coordinates, through the "FLTXXXX.DAT" file, but there is no DJI method of extracting that information that I know of.
The website "MAPSMADEEASY.com" provides a service where if you give them your FLYXXXX.DAT file, they will give you back a CSV file with the GPS coordinates at all points along the flight.
I have used it several times, and it works well.
You also get altitude, yaw, and several other useful parameters.
Hope this helps
Hank
Texas |
