OTG WORKS - DJI GO 4 _ 4.2.12 - For Android - 19th April ...
14524 189 2018-4-19
S-e-ven
Flight distance : 5922034 ft
djiuser_Kf4iPA3DtL3S Posted at 2018-4-22 03:58
Do you use the version that's on APK? the tablet version?
I don't see a phone version. Was there ever one available?
I could install the apkmirror version (20.xxxxx) on a huwaei tab and on a Xiaomi Redmi Note 4 Phone.
So give it a try!
2018-4-22
Ricky Aerial Photography
DMX_MLT Posted at 2018-4-22 04:41
Can you explain how I can do these Rick -
3) Do not allow any background apk running.
In Huawei P9 Plus "Setting", "Developer Option"
2018-4-22
Neville7
This is a very helpful discussion.  I live in Hong Kong and would like to try OTG on Spark with 4.2.12 (not yet installed, still not officially available here on Play Store for my Galaxy Note 4). Does anyone know where to get the cable below here in Hong Kong?
https://www.amazon.com/gp/product/B075N49YLV/ref=as_li_ss_tl?ie=UTF8&psc=1&linkCode=sl1&tag=oxmanagain-20&linkId=7f9e0816f33edde8eb39cc9188293fb7
2018-4-23
Neville7
OTG cable for Android
2018-4-23
Blellow
Flight distance : 1311056 ft
Otg still not displaying height,speed, n battery.  Shame!
2018-4-23
TsukoYomi
Flight distance : 23422 ft
Philippines
updated yesterday got the apk from apk mirror... otg works now in android!!!
@edit im on spark btw...
2018-4-23
CjMiller7
Flight distance : 35413 ft
New to the drones and OTG, so hopefully you guys can help out. I was looking into an OTG cable but saw at the time it was not supported with Android ( I have an Samsung S8+). So I stopped looking at what OTG cables did and went on my way using WiFi. However, now that its supposedly working again (or will be soon), what is the main benefit to an OTG cable? I have seen stuff like cutting down the time to connect to the drone and a more stable connection, but is that really it? I haven't had an issue with wifi but 1 time. However I do understand, like most things, hardwired always works better and is more reliable, just wondering what is being made better here with the addition of an OTG cable.
2018-4-23
I flew again to-day with wifi connection only. As expected, wifi connection worked great. I will not use OTG anymore. Video quality and response makes no difference in wifi and OTG. I flew this new version several times and did not experience any lost connection/no video signal.
DJI pulled out 4.2.12 from playstore shortly after release, may be this version of DJI GO 4 can "Make Spark Great Again!", it may hurt the sales of Mavic Air. :-)
Spark owners should download this APK, DJI may kill this version soon and replace it with an inferior update, to protect the sale of Mavic Air. haha.
I will keep this version and would not allow DJI to auto update. Just in case,DJI wants to kill this version.
Let's looking back. DJI 4 GO, versions 4.1.14, 15 are great, stable and reliable. DJI killed these versions with updates that had plenty of problems. The fate of Spark entered into dark era. Cases of lost Spark, uncontrollable Spark reported nearly every day. Mavic Air came into the market shortly afterwards. Is it a co-incidents?? May be or may be not.
2018-4-24
DMX_MLT
Malta
Ricky Aerial Photography Posted at 2018-4-24 01:47
Thank Ricky for all the Info. I tried to install the APK and gave me an error. Now I found the Problem.
It was asking for 'Resource File - NOT FOUND'.
1) As I never installed the DJI GO4 App I had to install from Google Play.
2) After install it downloaded 'Resource File'.
3) Now I have version 4.2.8 on my Samsung S8+
Questions is - What are my next steps now to install the Version 4.2.12 Rick ? Can I just uninstall the 4.2.8 and then install 4.2.12 ? Also as I use the Samsung S8+ the version available is still the 02 on the APK which usually is for Tablets, I install that version. If I need to do a backup can you explain a bit how to make it. Thank you !
2018-4-24
jh8
Flight distance : 39685 ft
Were you in CE mode (2.4GHz channels 1-13), not FCC?
2018-4-24
DMX_MLT Posted at 2018-4-24 02:41
I have 4.2.8 installed on my Huawei P9 Plus. I downloaded 4.2.12 in APK mirror and installed the download APK without first uninstalled the  4.2.8 version. The Installation ran as usual and it bootedup 4.2.8 in the process. After finish, it is 4.2.12.
I use "Fake GPS" to force DJI 4 GO running in FCC mode to answer the question of "Jh8".
2018-4-24
DMX_MLT
Malta
Ricky Aerial Photography Posted at 2018-4-24 03:13
Hi Rick,
All done here.
1) I installed 4.2.8 from Google Play
2) While installing the 4.2.8 App on the Phone it has Downloaded the Resources and created the Allocated Folders from DJI
3) Uninstalled 4.2.8
4) Downloaded 4.2.12 on Phone from APK Mirror
5) While Installing the 4.2.12 App On Phone it has NOW Downloaded the NEW 4.2.12 Resources and created the Allocated Folders from DJI
I cant understand why it didnt work straight from 4.2.12 but anyways, this way it worked.
** I never had any DJI GO4 app installed on my Samsung S8+, so I think the APK was searching for my resources folder and couldnt find it. So to solve do the above and it worked for me. **
2018-4-24
S-e-ven
Blellow Posted at 2018-4-23 18:56
Which App Version, please?
2018-4-24
S-e-ven
CjMiller7 Posted at 2018-4-23 20:54
my p.o.v.:
One wifi less to worry.
And that is the 5/10cm wifi, from RC to  Device.
That wifi you need to get away from bluetooth devices, or it can get disturbed.
That alone, one wifi less to worry, is for me reason enough.
Also still almost no lag, in case the Spark is a bit further away
2018-4-24
Terp1234
Flight distance : 50906 ft
I just noticed that Google Play has updated my app to 4.2.12(574-googlePlay) last night. Will give the OTG a try this evening.
2018-4-24
SirRobin
Flight distance : 9774 ft
Which of the both apks on apkmirror ist the right one? Same Version 4.2.12 but two variants...hm?
2018-4-25
DMX_MLT
Malta
S-e-ven Posted at 2018-4-24 05:49
my p.o.v.:
100% Agree with Seven.
Same thoughts.
Which u prefer in Home Internet Connection -
Wifi Air Signal ?
or
Direct Wired Internet Cable ?
I chose always a WIRED CONNECTION to be far more Reliable, its common sense.
2018-4-25
DMX_MLT
Malta
SirRobin Posted at 2018-4-25 01:21
I used this one - 2031008
Samsung S8+ worked ok without any problems. Installed well.
https://www.apkmirror.com/apk/dj ... droid-apk-download/
2018-4-25
S-e-ven
Thanks for telling!
I have the first 'in use on one phone and one tablet, but couldn't install that on my OP5
Will try the second one.
Out of my experience, yet: Try the first (older) version. That one seems to work
2018-4-25
ernieken
Flight distance : 547641 ft
Installed 4.2.12 as well and signal seems much better. With previous versions sometimes video dropped already after 50 to 60m (that was a reason to use otg with older DJI go version). Today flew 120m away (using wifi) without any problems. Only done one test but first impressions are very good.
2018-4-25
DMX_MLT
Malta
ernieken Posted at 2018-4-25 04:07
Thanks for your update ernieken.
2018-4-25
Blellow
Signal is better, but otg is still even better than no otg.
2018-4-25
idbl_fanatic
Flight distance : 509741 ft
Who knows what the heck DJI is doing anymore, I was told last Wednesday that it should be out to everyone by that Friday, here we are a week later, and I STILL haven't seen it in the store.
2018-4-25
Firehawk989
Flight distance : 198904 ft
4.2.12 update just showed up on Google Play for me. Probably won't have time to test it till tomorrow. Nice to see that Spark IS still on the radar for improvements/fixes, despite all the paranoid ranting on the forum about how we've been "abandoned".
2018-4-25
S.J
Flight distance : 322454 ft
Japan
Yes it is specifically OTG support for SPARK  the android version is 4.2.12.   I am using an OPPO mobile Android ver 5.1
2018-4-25
Firehawk989
Also some additional Android-specific improvements such as offline maps performance and media sharing.
2018-4-25
idbl_fanatic
What the heck DJI??
2018-4-25
DMX_MLT
Malta
Fanatic go to the Mirror Website, I installed the first one and many told me it works great. I didnt try it but installed it without problems.
https://www.apkmirror.com/apk/dji-technology-co-ltd/
2018-4-25
DMX_MLT
Malta
OMG !!
Another Version today !
I installed the first version, and it installed ok, but for now cannot fly drone as waiting for permits. I can confirm all seems ok.
Can someone tell us if the New Versions have something different, or any bug fixed as in description all the same.
I think DJI didnt upload on GooglePlay as they are still doing the FINAL TOUCHES to it, so its not really Official, thats what I heard.
We have to wait and see.
2018-4-25
Firehawk989
There's not some big conspiracy, they aren't blocking it from you. It just takes a while to roll out to every device in every country. Should show up for you any time now! I've seen this with other apps too, not just stuff from DJI.
2018-4-25
ZarcTheSpark
Flight distance : 460676 ft
My android phone (T-mobile REVVL) just updated to 4.2.12 b577-Google automatically in California.  I'll try it out tomorrow, but other people should get it soon.  Funny, but my other phone (S8) has it installed but shows no update when checking for updates on GP store.
2018-4-25
nmac
Flight distance : 256 ft
Been following this and just checked my phone with Verizon and was shocked as it updated to the new.  I did check yesterday but had the old.  phone did not tell me that it did any updates but seems it did.
2018-4-25
DMX_MLT
Malta
I am Wondering about this if anyone can Help - My Phone I was using is Samsung S8+- Set to Manual Updates so that any Update will need my Confirmation to be Installed
1) So I downloaded the 4.2.12 from the APK Mirror via Chrome Download
2) Installed the App from APK Mirror and Installed Resources Files
3) App from APK 4.2.12 - ALL INSTALLED PERFECTLY
Yesterday - from MALTA - EUROPE
1) Google Play made available the NEW Update the DJI GO4 in Google Play to the Newest Version 4.2.12 from the 4.2.8, File Size about 169MB (Maybe Both Phone & Tablet Version).
2) Google Play sent me Notification that - THERE IS UPDATE TO 4.2.12
Question is -
A) Why did Google Play tell me to UPDATE to NEW 4.2.12 Version, if I had installed it from the APK already which was already 4.2.12 ?
B) Are the APK Versions from the Mirror Site not Original DJI ?
Can DJI Support / Someone Clear this out for me please ?
Thank you so much, Darryl
2018-4-26
Vyborny83
Flight distance : 166014 ft
Czechia
DMX_MLT Posted at 2018-4-26 01:21
The reason is simple. There are at least three different builds of DJI GO 4 4.2.12 . If you take a look in the Me section, click on the Settings (the gear icon in the upper right corner) and scroll down, you will notice that you have DJI GO 4 v4.2.12(577-googlePlay) - that should be the newest version (newest build).
2018-4-26
DMX_MLT
Malta
Vyborny83 Posted at 2018-4-26 02:48
Thanks so much Vy, so from the APK Mirror (although they are uploaded by Users Manually... I Think) the DJI GO4 is not modded in anyway or not original ?
Its still safe to use th APK Mirror to downgrade if needed, from the Mirror Site right ?
I ask you as your are the PRO mate and will never use Modded Apps for my Drone.
2018-4-26
Vyborny83
Czechia
DMX_MLT Posted at 2018-4-26 02:51
They are all original ones. The different build usually suggests that there are some minor bug fixes but nothing large enough to deserve a new version (4.2.13 or something like that). The version on the APK Mirror is without any modifications, it just doesn't has to be the newest build that DJI released.
2018-4-26
DMX_MLT
Malta
Vyborny83 Posted at 2018-4-26 03:12
I am telling you this Vy, as I downloaded on my PC the ones we talked about -
4.1.14 / 4.1.15 / and now this one 4.2.12, so in case we need these files I will have them on my PC.
Thanks again Vy, as always for all your Help !
2018-4-26
JimFandango
Flight distance : 130768 ft
4.2.12 just landed in the UK Play Store for me!
2018-4-26
idbl_fanatic
ZarcTheSpark Posted at 2018-4-25 16:09
YES!!! Finally got it, just tried it out, all OTG functions are working, haven't flown yet though
2018-4-26
DMX_MLT
Malta
idbl_fanatic Posted at 2018-4-26 05:38
Very well. Thanks for your update Fanatic.
2018-4-26
