Faulty capacitor replacement
1146 7 2018-4-30
Flightrun
Flight distance : 108533 ft
Hello all.
My P3 Standard had a crashed because of a faulty (shorted) capacitor.
Does anyone now the right value for the capacitor next to the mosfet, marked in yellow in the picure.
2018-4-30
WD9EON
Flight distance : 686886 ft
I'd look at the other three motor esc to see if it could be identified.  Bound to be the same.
2018-4-30
Peterx
Flight distance : 1499708 ft
Do you can identify the capacity of the original capacitors in Micro or Nano farad ? You can ask a DJI hardware engineer for.
2018-4-30
Hellsgate
Flight distance : 1991555 ft
If you have a multimeter with capacitance testing then just measure the other 2 capacitors in that image i believe they are the same
The 2 either side of the M2 mark
2018-5-1
fans67772107
Flight distance : 8865 ft
Capacitors on this never short they open I suspect you're using your meter incorrectly in your forward biasing a parallel diode reverse the leads and see if you get a different reading I'd look elsewhere for my problem
2018-5-1
We're sorry there are no spare parts for sale now. If you need any further assistance, please kindly start a case and send the unit in: https://www.dji.com/support
2018-5-2
Flightrun
Thanks to all for your replies.
I measured a other capacitor and it gave me ~500 uF. D'oh. They are all in parallel. So I had to desolder a working capacitor (a step I would like to avoid) and measured 4.7 uF.
For everyone who is interested, I used my FLIR camera and made short video of the shorted capacitor when applying 15.2 volts.
2018-5-2
Flightrun
Forgot to mention, that the other part is a AO6500 N-Channel mosfet. After removing the faulty capacitor it doesn't heat up anymore.
2018-5-2
