Removing the filter ring
792 15 2018-6-7
SeanGalbraith
Flight distance : 891404 ft
I am trying to remove the filter ring thing so I can mount a filter... but the damn thing won't unscrew. I'm very weary of damaging the gimbal. Is there a trick to this thing?
2018-6-7
Hi. I understand that you want to remove the filter ring of the Mavic Air so that you will be able to put in a filter. Let me help you with this. May I know what is the brand of the filter that you have.
2018-6-7
SeanGalbraith
I have a Neewer set of filters. The problem is that the filter ring on the Mavic Air is just not unscrewing.
2018-6-7
Is this the first time that you will be removing the filter from the Mavic Air?
2018-6-7
JJBspark
Flight distance : 12717890 ft
just turn it, do not press to hard...(less force is better!)
2018-6-7
Wachtberger
Flight distance : 261509 ft
Two methods have proved to be working. Either rubber gloves or a rubber band tightly applied to the ring. Hold the gimbal with two fingers in position and remove the ring with the other hand. There is some initial resistance, but with some gentle effort it will eventually move. Good luck!
2018-6-7
alonzowest
Flight distance : 40938 ft
just turn it, you will be ok, make sure to use your thumb to support the gimbal though while your trying to turn it. so you put the stress on your thumb if that makes sense.
2018-6-7
Fabic
Hi
I used a thin nose plier, it worked.
2018-6-7
SeanGalbraith
Thanks for the suggestions. I'll give them a try.
2018-6-7
SparksBird
Flight distance : 10731690 ft
Yeah some on here have had difficulty doing this as well but persistence and following the advice given you will get it off.
2018-6-7
SeanGalbraith
Needed an elastic band, but I was able to get it off. Thanks all.
2018-6-7
Wachtberger
SeanGalbraith Posted at 2018-6-7 13:23
Glad to hear!
2018-6-7
Punchbuggy
Flight distance : 573054 ft
Well done. Suffice to say, don't have the replacement on as tight. There's also no harm in keeping it on either - I have a UV filter on as the default to keep the lens protected.
2018-6-7
A CW
Flight distance : 14754314 ft
Thin glove - be very careful - took me a while and I almost threw the drone into a wall in fury but it eventually came loose.
2018-6-7
Wachtberger
Punchbuggy Posted at 2018-6-7 13:29
Exactly, my UV filter for the same purpose was delivered yesterday :-)
2018-6-7
Punchbuggy
Wachtberger Posted at 2018-6-7 14:20
Cool! I honestly don't understand why DJI decided to deviate with the Air from what they do with their other drones - incorporate a factory-fitted UV filter.
2018-6-7
