Pilot Levels
16234 44 2018-6-14
ADG
Flight distance : 63363 ft
How is this determined?   Do I need to transmit a file of some kind?    I have over 40 flights and about 6+ hours and still the first level.
2018-6-14
SparksBird
Flight distance : 10731690 ft
When you go to your flight records you will see a little cloud icon.  Click that and it will sync your flight records.  Will change points in your level and also update your meters shown under your avatar here for flight distance.
2018-6-14
3-D
Flight distance : 635764 ft
Once you sync your flight records, it will update your flight distance.    Your activity in the forums will increase your level from lvl1 to Captain.
Here is a link that shows how you gain points.
Here is a link that shows the group levels
2018-6-14
chiplifter
Flight distance : 745180 ft
If you are referring to the lvl. 1 iunder your ava, that is you level in the forum. It is not depended on the number of flights but ranked based on use of the forum. Example if you daily login you receive 5 forum points. A reply gives 2 points etc. On you homepage you can see how many points needed for next level.
Forum points are exchangeble for dollars. 1800 points is 20 dollars, spendable in the DJI store.
2018-6-14
chiplifter
If you are you can sync your flights press on the cloud icon in the dji go 4  app.
2018-6-14
A CW
Flight distance : 14501142 ft
chiplifter Posted at 2018-6-14 12:12
$10 per 1800 points
2018-6-14
chiplifter
A CW Posted at 2018-6-14 12:38
$10 per 1800 points
Yep, thanks you are correct.
2018-6-14
Blizzard
Flight distance : 173734 ft
I can'( click on the word "EXCHANGE" on my homepage.
2018-6-14
davidmartingraf
As you fly more your level will change.
2018-6-14
Aardvark
Flight distance : 384432 ft
Blizzard Posted at 2018-6-14 13:20
click on left box and enter quantity you want exchanged, this is a minimum of 1800 and multiples of 180 above that.
e.g 1800 or 1980 or 2160 would all be valid entries.
Then click on '=', and finally click on 'exchange'. It will then show 'audit' against your claim. The points are redeemed at the start of every calendar month. So a claim on the 3rd of June for example, stays as audit until the end of the Month. Your currency value can then be seen against your account in DJI store.
2018-6-14
Blizzard
Aardvark Posted at 2018-6-14 13:56
Thx! That way it is working!
2018-6-14
Rockyraaccoon
Flight distance : 982382 ft
I clicked on the cloud in flight logs and it said that it had synced everything, but my numbers didn't change. But it doesn't surprise me.....I've been trying, unsuccessfully, to update my avatar for weeks and it never works. I get to 10% upload in a split second, then it stops.
2018-6-14
Hi, just to clarify, are we pertaining to the level on the DJI GO 4 app or here in the forum?
2018-6-14
SparksBird
Rockyraaccoon Posted at 2018-6-14 15:17
Sometimes I have to log out of the forums then log back in then it updates for me.
2018-6-14
Rockyraaccoon
DJI Tony Posted at 2018-6-14 16:04
I was wondering if the app is connected to the forum?
my numbers haven't changed since I joined
2018-6-14
nywrecker
Flight distance : 832421 ft
SparksBird Posted at 2018-6-14 11:54
It is interesting to note that although I have my app and syncing to show feet, the number below the avatar is in meters. Same as the RTH height.
2018-6-14
SparksBird
nywrecker Posted at 2018-6-14 17:41
Yes it will always show meters here in the forums regardless of how you have it set in the app.
2018-6-14
3-D
Rockyraaccoon Posted at 2018-6-14 17:25
Your level in the app does not equate to your level in the forum.
The more you fly, the higher your level in the app.
The more active you are on the boards, the higher your level in the forum.
2018-6-14
WebParrot
Flight distance : 23625 ft
Might be a good time to browse through the Forum Rules & Regs.... All the information you need lies therein :-)  https://forum.dji.com/forum.php? ... mp;page=1#pid623200
2018-6-14
A CW
chiplifter Posted at 2018-6-14 12:56
Yeah, it takes a while to build up the $hundreds
2018-6-14
Bokepacha
Flight distance : 149265 ft
davidmartingraf Posted at 2018-6-14 13:44
These levels are just forum related. It doesn't matter if you fly 100 km a day in your drone, if you don't participate in the forum (daily log in, start a thread, reply posts, etc.) you won't improve your lvl.
2018-6-14
A CW
and the max you can exchange is 5,400 per month which is a bit of a pain.
2018-6-15
davidmartingraf
Bokepacha Posted at 2018-6-14 23:30
Yes, the flight distance will change when you fly more.
2018-6-15
Bokepacha
davidmartingraf Posted at 2018-6-15 06:26
Distance shown in the forum has nothing to do with the levels.
2018-6-15
davidmartingraf
Bokepacha Posted at 2018-6-15 07:12
I'm referring to the DJI GO 4 Application - the more you fly - the more the App will raise your level. The Boards it's only dependent on the points achieved through the number of your submitted posts.
2018-6-15
A CW
Agreed - your level/rank in the forum is driven only by the number of points who have which in turn is driven by the amount you contribute to the forum. Once you have 5,000 points you will automatically become a Captain which is the highest rank for non DJI employees. There are Captains on here who do not even own a drone!
2018-6-15
doublefatman
Flight distance : 113930 ft
Dude, the more you fly, the more time and miles you put on your unit, the numbers go up accordingly
2018-9-21
fans906a4e41
Flight distance : 9127 ft
Nigeria
I don't get visual on my techno phone when connected to my mavic air.  What could be the problem?
2018-9-22
Jerry Seon
Flight distance : 326457 ft
Maldives
Pilot level 19+
2018-9-22
Alex B.
Flight distance : 21105262 ft
Pilot level 22
Fly safe
Alex
2018-9-22
maihem.rc
Flight distance : 2076335 ft
Alex B. Posted at 2018-9-22 13:10
Pilot level 22
Fly safe
So, I also have a pilot level of 22 but have a considerably lower flight distance than you do...how is that possible?
Sorry in advance if this is something that has been explained elsewhere, I know there have been a few threads on this but none of them have really explained it in a manner that has made sense to me.
2019-1-3
Alex B.
maihem.rc Posted at 1-3 07:16
I’m at level 32 now
22 I was in September
Flysafely
Alex
2019-1-3
maihem.rc
Alex B. Posted at 1-3 12:39
I’m at level 32 now
Well that makes more sense...I did not notice the date of your reply.
2019-1-3
FosyBear
Great information on leveling on both the app and the forum.  Thanks for the info.
2019-1-5
djiuser_4Ype3EtvimDx
Flight distance : 49741 ft
3-D Posted at 2018-6-14 12:03
3-D, Thank you for adding those quick links. I was wondering how the points and levels will work. I thought it was based on the number of flights.
2019-7-29
zusician
Flight distance : 919308 ft
Bangladesh
Where can I see all pilot level?
2020-1-25
Lucas775
Flight distance : 50642090 ft
Keep on flying and don't give up
2020-1-25
jyc
Flight distance : 2255846 ft
1800 points are worth 10 DJI Credits (USD). Oops, someone already postedthe correct information!
2020-1-26
djiuser_CTFn7pukqgCj
Flight distance : 4772267 ft
This is my first time On the forum's but according to my flight records I’m. Level 22. I’ve got a 122 flights 17.35 hours of flight time 423, 234 feet. So what does the flight level mean in the app if you can only advance levels by coming on the forums
  The level 22 is meaningless with all the flight time and you gain rank just by talking about things. I don’t understand the level system
2020-5-23
FarangPilot
Flight distance : 1318976 ft
jyc Posted at 2020-1-26 04:33
So if I have 700000 + points. That would give me 300+ $?
2021-2-15
