Can't get Dji Assistant 2 to recognise controller.
4472 19 2018-4-29
Kevin James ÓBrien
Flight distance : 1788297 ft
Hi, I know I'm becoming a right pain but I'm New to this. I just Can't get Dji Assistant 2 to recognise my controller and download the firmware update? Thanks for any help.
2018-4-29
msinger
Flight distance : 228255 ft
Try installing the current version of the DJI Assistant 2 application. You can download the installer here:
https://www.dji.com/phantom-4-pro/info#downloads
2018-4-29
Kevin James ÓBrien
Thanks Dude. I really want to fly this bird
2018-4-29
Kevin James ÓBrien
msinger Posted at 2018-4-29 09:42
Tried that, no change unfortunately. Thanks anyway
2018-4-29
msinger
Why not update the firmware from DJI GO?
2018-4-29
Kevin James ÓBrien
msinger Posted at 2018-4-29 10:40
2018-4-29
Kevin James ÓBrien
This the firmware currently in use. How does this compare to yours?
2018-4-29
Kevin James ÓBrien
I just read that the rc wouldn't be recognised by assistant 2 anyway. I can't find any firmware on the app for the rc and the phantom says it's up to date. I'm done in by all this tbh lol
2018-4-29
msinger
The "-" at the end of "01.03.00.00-" means your remote controller firmware is not updated.
Do you see a prompt to install the firmware update on the main screen of DJI GO?
2018-4-29
Jenee 2
Flight distance : 7852129 ft
Only the Phantom is updated via Assistant 2 software. To update the RC, connect it to your phone/tablet and open the DJI GO 4 app. Make sure your phone/tablet has an internet connection. When you open the app, it should advise you if there is an update available. Otherwise, long press on the three bars, top right hand corner and it will show you if an update is available. Just follow the prompts to update.
2018-4-29
Kevin James ÓBrien
Thanks all. I managed to get sorted last night thanks to another member.
2018-4-29
Nice to see the issue has been figured out. Currently, the P4P RC is not available to update via DJI Assistant 2, please kindly note.
2018-4-30
KedDK
Flight distance : 1133038 ft
It would be nice if you posted the solution that worked for you and also add a [Solved] in the subject field on #1, then it might help the next with similar trouble.
Good you found a solution.
2018-4-30
Kevin James ÓBrien
I will do that very shortly KedDK.
2018-4-30
KedDK
Kevin James ÓBrien Posted at 2018-4-30 05:41
Well yes thanks, i did think of posting it here so with a little luck the next searching on a problem also would see the possible solutions suggested and the final solution for your case but WtH they might as well get the new thread up in the search results.
Glad you found a way and welcome to the group of Phantom owners, may all the bad upgrades stay clear of your way.
2018-4-30
jan.vanderwalt
Flight distance : 82149 ft
Hi Guys,
I've got the same problem as Kevin (not recognised by DJI Assistant 2, no visual streaming between p4p and RC etc). Would be very interested in what you did Kevin.
Cheers,
Jan
2018-6-19
Kobski
jan.vanderwalt Posted at 2018-6-19 00:03
Hi Guys,
Hello Jan. To up date your RC turn power on then you should see three horizontal lines in the top right hand corner of the screen. Put your finger there for a long press. Screen should change to a menu with available updates if applicable. Choose one and this should put you right if that was the problem. I know how frustrating it is so feel free to get in touch and i will help if i can. Good luck
2018-6-19
jan.vanderwalt
Hi Kobski,
Thanks for the reply. I have already tried that and then this pops up...
Its like it doesnt have any firmware on it at all...
2018-6-20
Kobski
jan.vanderwalt Posted at 2018-6-20 02:01
Hi Kobski,
That is really weird Jan. Unfortunately it is beyond my experience. Maybe you could post it on here? There are some very experienced pilots in this community. Very sorry i couldnt help you Jan.
2018-6-20
Grumpy Old Man
Flight distance : 37795 ft
DJI Susan Posted at 2018-4-30 01:43
Any reason why? The RC used to connect to Assistant 2 perfectly, and display the current version.
Why was this option removed? I've been trying for days to connect!!
2022-11-20
