Firmware update V02.00.0700
3603 16 2018-6-25
pb1982
Hi All,
I decided I'd update my Phantom 4 this morning before going on holiday in a few weeks. It looks as though there have been a few issues with this update and the fixes I have found online, don't seem to be fixing it for me.
Originally, I installed Assist and it just kept telling me the update had failed when it got to 100%. So I un-installed and tried to install v.1.2.2 as recommended on this forum. When I followed the link, it had been updated to v.1.2.4 so I installed that instead.
The file downloads, and then flicks over to 'transmitting.' But then it fails.
Can anybody please advise?
Thanks in advance,
Paul
2018-6-25
Eric13
Flight distance : 15551037 ft
You are mixing two things up here I think.
The versions you are talking about are software versions of the Assistant 2, not firmware versions for the drone.
See below that black screenshot for current firmware versions on P4P. How does that look in your go app?
You have the P4, correct? Not P4A or P4P?
I have the P4P only but according to DJI these are the latest P4 firmwares for AC + RC:
2018-6-25
Eric13
I want to add:
I have never used the assistant for updates. You don't need it unless you want to downgrade.
In the "About" page click on that box "Check For Update" behind 'Aircraft'. It should be updating via the Go4 app then.
2018-6-25
pb1982
Eric13 Posted at 2018-6-25 04:09
I want to add:
Ah right, many thanks Eric.
It confused me because I couldn't see how I could connect the drone to the tablet knowing I needed two 'small ends' of a USB. Then I saw the adapter! Dur.
I followed your instructions... the version before the update was 01.02.0602. It's now currently installing 02.00.0700. Saying that, it got to 99% after re-starting itself several times and then I got an alert on my tablet saying the connection had timed out and I should disconnect then reconnect the USB - which I did. So now it's still on 99% and I'm not sure if it's doing anything. The little blue file and flying arrow are still on my tablet screen, and the far left light on the controller is flickering rapidly between red and green.
Shall I leave it, or power everything off and try again?
Thanks again for your help, I'm new to all this drone stuff so still finding my feet. Much appreciated
2018-6-25
pb1982
pb1982 Posted at 2018-6-25 04:57
Update: All sorted after a bit of faffing. Cheers again
2018-6-25
Aardvark
Flight distance : 384432 ft
pb1982 Posted at 2018-6-25 06:18
Along with the 02.00.0700 update you should also get prompted to update RC to V1.9.3 which is needed for RC to communicate with the aircraft on the 02.00.0700 build.
Check 'About' as shown above and see what builds all is at.
Edit:- The RC update is not carried out in the 'About' section as was the aircraft. The RC update will flag itself up on the front page in the 'aircraft status' when you first open up DJI Go 4 with all connected and powered up.
2018-6-25
pb1982
Aardvark Posted at 2018-6-25 06:48
Hi Aardvark,
Cheers for your reply. Once updated, I powered everything off and on, and as you mentioned, the RC needed updating as well. It gave me a distorted picture from the camera and the RC unit peeped constantly until I updated!
As far as I can tell, both the drone and control have been successfully updated (the peeping has stopped and a proper picture from the camera has returned) - all that's left to do now is fly the bugger!  Fingers crossed the updates are fine and there will be no issues when I get around to taking it out over the next few days.
2018-6-25
Aardvark
pb1982 Posted at 2018-6-25 06:56
Hi Aardvark,
Sounds good to go
Just find a big, open, treeless area for testing :-)
2018-6-25
Eric13
I'm glad you were successful!
Yes - the updates can be nerve racking sometimes :-)
2018-6-25
fans68c05089
Well I have the Phantom 4 also and I tried updating the craft using my laptop with Windows 10 and it failed at 55% so I checked to see if there was a later version of Assistant 2 and there was so i installed that and tried it again but still failed several more times again at 55% that was all yesterday so today I tried updating from my iPad Air and I thought it was going to work because it got to 73% then failed.  I tried several times with the same results.  I talked with Online Support both days and today they said I need to send it in so I just dropped it off at UPS and I had my controller worked on once before and it was like a month.  I was hoping I could find something on the Forum but NO.  The only good thing is that I see someone else is having the same issue.
2018-6-26
pb1982
fans68c05089 Posted at 2018-6-26 13:04
Hi fans, well mine worked in the end... once a few of the kind souls on here got me to understand I didn't need that Assistant thingy-mi-jig! I'm using a Samsung tab though not an iPad - don't really see how that should make any difference but it probably does! Hope you get it sorted
2018-6-26
DJI Natalia
Two thumbs up for sorting out the issue. Happy flying!
2018-6-26
djiuser_Nzi1oTbGmIdZ
My phantom4 has calibration problem failed error 71 (overall status abnormal) calibration failed many time. Can I solve this problem in india
2018-7-2
DontFlyHigh
Flight distance : 20682 ft
fans68c05089 Posted at 2018-6-26 13:04........I was hoping I could find something on the Forum but NO.  The only good thing is that I see someone else is having the same issue.
You shouldn’t of had a problem finding something on the forum with issues similar to yours. I had the same situation going on and searched and found lots of peeps using  assistant and at 55% firmware failed to update and even 73% in the GO app. I commented on a few after I solved my problem and even made a thread at some point I believe. But I also used an Android in the GO app and android is a lil more descriptive when updating, mainly instead of just the % being shown, it also tells you what files are being updated at that %. The last thing it tried updating before failing (68%-73% I think) was main gimbal esc. After a ton of troubleshooting with 2 separate p4’s and swapping parts between them, it ended up being the short cable that connects the crafts board, to the camera. Have no idea why it went bad all of a sudden but lost transmission signal, sd card wasn’t registering, wouldn’t update. But I’ve been bask in the air for awhile now. Love firmware 2..00.0700
2018-7-5
Aardvark
"and I thought it was going to work because it got to 73% then failed."
There are times during the upgrade where it doesn't move on for a good while, minutes sometimes, are you allowing it enough time.
2018-7-6
franperezzzz
Flight distance : 18885 ft
Hola, mismo problema
[19:18:48.699][DJIIdentifierMgr    ] Device Arrive COM3
[19:18:48.699][DJICmdIo            ] open COM3
[19:18:48.900][DJISerialIo         ] Open COM3 success!
[19:18:48.900][DJIIdentifierMgr    ] open device succeed
[19:18:51.901][DJISerial2          ] Write Data Timeout! Wait = 3000
[19:18:53.054][DJIWebFileGetter    ] [OnFinish]reply statusCode=201
[19:18:53.189][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:18:53.194][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:18:53.221][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:18:53.367][DJIWebFileGetter    ] [OnFinish]reply statusCode=201
[19:18:53.368][DJILogin            ] user type:
[19:18:55.844][DJIIdentifierMgr    ] [Uav          , wm330        , 01.00.2567   ], App
[19:18:55.845][DJIDeviceMgr        ] device service ready! COM3
[19:18:55.962][DJIDeviceMgr        ] DevArrival, Uav, wm330, ,01.00.2567, 8bacaa2b745ab636f8e2ae0d3a9b1f89a980c3f4, normal
[19:18:55.966][DJIUpgradeMgr       ] set date time to device 0x0801 success!!!
[19:18:56.026][DJIDynamicParamTable] Table: 0, Size: 390  , Hash: 7aca872f
[19:18:56.026][DJIDynamicPushTable ] Table: 0, Size: 45   , Hash: 56987d00
[19:18:56.026][DJIDynamicCmdTable  ] Cmd Table Size: 113  , Hash: 12345678
[19:18:56.046][DJIDynamicParamTable] Table: 1, Size: 746  , Hash: a50518cf
[19:18:56.047][DJIDynamicPushTable ] Table: 1, Size: 60   , Hash: 569c1000
[19:18:56.064][DJIDynamicParamTable] GetConfigTableAttribute failed!!! Error Code: 9
[19:18:56.258][DJIDynamicPushTable ] GetPushConfigTableAttribute failed!!! Error Code: 8
[19:18:56.304][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:18:56.553][DJIDynamicTableMgr  ]   0%
[19:18:56.555][DJIDynamicTableMgr  ]   1%
[19:18:56.556][DJIDynamicTableMgr  ]   2%
[19:18:56.558][DJIDynamicTableMgr  ]   3%
[19:18:56.559][DJIDynamicTableMgr  ]   4%
[19:18:56.561][DJIDynamicTableMgr  ]   5%
[19:18:56.562][DJIDynamicTableMgr  ]   6%
[19:18:56.564][DJIDynamicTableMgr  ]   7%
[19:18:56.565][DJIDynamicTableMgr  ]   8%
[19:18:56.567][DJIDynamicTableMgr  ]   9%
[19:18:56.568][DJIDynamicTableMgr  ]  10%
[19:18:56.570][DJIDynamicTableMgr  ]  11%
[19:18:56.571][DJIDynamicTableMgr  ]  12%
[19:18:56.573][DJIDynamicTableMgr  ]  13%
[19:18:56.574][DJIDynamicTableMgr  ]  14%
[19:18:56.576][DJIDynamicTableMgr  ]  15%
[19:18:56.577][DJIDynamicTableMgr  ]  16%
[19:18:56.579][DJIDynamicTableMgr  ]  17%
[19:18:56.580][DJIDynamicTableMgr  ]  18%
[19:18:56.582][DJIDynamicTableMgr  ]  19%
[19:18:56.583][DJIDynamicTableMgr  ]  20%
[19:18:56.584][DJIDynamicTableMgr  ]  21%
[19:18:56.586][DJIDynamicTableMgr  ]  22%
[19:18:56.587][DJIDynamicTableMgr  ]  23%
[19:18:56.589][DJIDynamicTableMgr  ]  24%
[19:18:56.590][DJIDynamicTableMgr  ]  25%
[19:18:56.592][DJIDynamicTableMgr  ]  26%
[19:18:56.593][DJIDynamicTableMgr  ]  27%
[19:18:56.594][DJIDynamicTableMgr  ]  28%
[19:18:56.596][DJIDynamicTableMgr  ]  29%
[19:18:56.597][DJIDynamicTableMgr  ]  30%
[19:18:56.598][DJIDynamicTableMgr  ]  31%
[19:18:56.600][DJIDynamicTableMgr  ]  32%
[19:18:56.601][DJIDynamicTableMgr  ]  33%
[19:18:56.603][DJIDynamicTableMgr  ]  34%
[19:18:56.604][DJIDynamicTableMgr  ]  35%
[19:18:56.606][DJIDynamicTableMgr  ]  36%
[19:18:56.607][DJIDynamicTableMgr  ]  37%
[19:18:56.608][DJIDynamicTableMgr  ]  38%
[19:18:56.610][DJIDynamicTableMgr  ]  39%
[19:18:56.611][DJIDynamicTableMgr  ]  40%
[19:18:56.613][DJIDynamicTableMgr  ]  41%
[19:18:56.614][DJIDynamicTableMgr  ]  42%
[19:18:56.615][DJIDynamicTableMgr  ]  43%
[19:18:56.617][DJIDynamicTableMgr  ]  44%
[19:18:56.618][DJIDynamicTableMgr  ]  45%
[19:18:56.619][DJIDynamicTableMgr  ]  46%
[19:18:56.621][DJIDynamicTableMgr  ]  47%
[19:18:56.622][DJIDynamicTableMgr  ]  48%
[19:18:56.624][DJIDynamicTableMgr  ]  49%
[19:18:56.625][DJIDynamicTableMgr  ]  50%
[19:18:56.626][DJIDynamicTableMgr  ]  51%
[19:18:56.628][DJIDynamicTableMgr  ]  52%
[19:18:56.629][DJIDynamicTableMgr  ]  53%
[19:18:56.631][DJIDynamicTableMgr  ]  54%
[19:18:56.632][DJIDynamicTableMgr  ]  55%
[19:18:56.634][DJIDynamicTableMgr  ]  56%
[19:18:56.635][DJIDynamicTableMgr  ]  57%
[19:18:56.636][DJIDynamicTableMgr  ]  58%
[19:18:56.638][DJIDynamicTableMgr  ]  59%
[19:18:56.639][DJIDynamicTableMgr  ]  60%
[19:18:56.641][DJIDynamicTableMgr  ]  61%
[19:18:56.642][DJIDynamicTableMgr  ]  62%
[19:18:56.644][DJIDynamicTableMgr  ]  63%
[19:18:56.645][DJIDynamicTableMgr  ]  64%
[19:18:56.646][DJIDynamicTableMgr  ]  65%
[19:18:56.648][DJIDynamicTableMgr  ]  66%
[19:18:56.649][DJIDynamicTableMgr  ]  67%
[19:18:56.651][DJIDynamicTableMgr  ]  68%
[19:18:56.652][DJIDynamicTableMgr  ]  69%
[19:18:56.653][DJIDynamicTableMgr  ]  70%
[19:18:56.655][DJIDynamicTableMgr  ]  71%
[19:18:56.656][DJIDynamicTableMgr  ]  72%
[19:18:56.658][DJIDynamicTableMgr  ]  73%
[19:18:56.659][DJIDynamicTableMgr  ]  74%
[19:18:56.661][DJIDynamicTableMgr  ]  75%
[19:18:56.662][DJIDynamicTableMgr  ]  76%
[19:18:56.663][DJIDynamicTableMgr  ]  77%
[19:18:56.665][DJIDynamicTableMgr  ]  78%
[19:18:56.666][DJIDynamicTableMgr  ]  79%
[19:18:56.668][DJIDynamicTableMgr  ]  80%
[19:18:56.669][DJIDynamicTableMgr  ]  81%
[19:18:56.671][DJIDynamicTableMgr  ]  82%
[19:18:56.673][DJIDynamicTableMgr  ]  83%
[19:18:56.675][DJIDynamicTableMgr  ]  84%
[19:18:56.676][DJIDynamicTableMgr  ]  85%
[19:18:56.678][DJIDynamicTableMgr  ]  86%
[19:18:56.724][DJIDynamicTableMgr  ]  87%
[19:18:56.746][DJIDynamicTableMgr  ]  88%
[19:18:56.785][DJIDynamicTableMgr  ]  89%
[19:18:56.804][DJIDynamicTableMgr  ]  90%
[19:18:56.826][DJIDynamicTableMgr  ]  91%
[19:18:56.865][DJIDynamicTableMgr  ]  92%
[19:18:56.886][DJIDynamicTableMgr  ]  93%
[19:18:56.907][DJIDynamicTableMgr  ]  94%
[19:18:56.944][DJIDynamicTableMgr  ]  95%
[19:18:56.966][DJIDynamicTableMgr  ]  96%
[19:18:56.987][DJIDynamicTableMgr  ]  97%
[19:18:57.024][DJIDynamicTableMgr  ]  98%
[19:18:57.046][DJIDynamicTableMgr  ]  99%
[19:18:57.067][DJIDynamicTableMgr  ] 100%
[19:18:57.067][DJIDynamicTableMgr  ] load from file: Template v3.2.14.0.cfg
[19:18:57.235][DJIDynamicTableMgr  ] dyn_mgr read, TIME: 1269(ms).
[19:19:00.810][DJIUpgradeMgr       ] get nfz version timeout!!!
[19:19:04.800][DJIDeviceMgr        ] Refresh DevArrival, Uav, wm330, ,01.00.2567, 8bacaa2b745ab636f8e2ae0d3a9b1f89a980c3f4, normal
[19:19:04.820][DJIWebSocketServer  ] No service for [/controller/user_feedback/8bacaa2b745ab636f8e2ae0d3a9b1f89a980c3f4]
[19:19:04.905][DJIFirmPackListRefre] GetDevFirmPackCfgInfo failed!!! target module: 31(0), retcode: 0xe0
[19:19:04.909][DJIDeviceInfoEnumera]   5%  1/19 1860(1)
[19:19:04.911][DJIDeviceInfoEnumera]  10%  2/19 CPLD(3)
[19:19:04.920][DJIDeviceInfoEnumera]  15%  3/19 UltrasonicM0(4)
[19:19:04.924][DJIDeviceInfoEnumera]  21%  4/19 FC_Loader(5)
[19:19:04.936][DJIDeviceInfoEnumera]  26%  5/19 ESC0(0)
[19:19:04.944][DJIDeviceInfoEnumera]  31%  6/19 OFDM_103(0)
[19:19:04.945][DJIDeviceInfoEnumera]  36%  7/19 FC(6)
[19:19:04.945][DJIDeviceInfoEnumera]  42%  8/19 Battery0(0)
[19:19:04.952][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:05.107][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:05.234][DJIDeviceInfoEnumera]  47%  9/19 ESC1(1)
[19:19:05.536][DJIDeviceInfoEnumera]  52% 10/19 ESC2(2)
[19:19:05.853][DJIDeviceInfoEnumera]  57% 11/19 ESC3(3)
[19:19:06.930][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Mvo(17:5)
[19:19:06.930][DJIDeviceInfoEnumera]  63% 12/19 Mvo(5)
[19:19:06.930][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: 2100(8:2)
[19:19:06.930][DJIDeviceInfoEnumera]  68% 13/19 2100(2)
[19:19:06.930][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Camera4K(1:0)
[19:19:06.930][DJIDeviceInfoEnumera]  73% 14/19 Camera4K(0)
[19:19:06.930][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: DJI_Vision(8:5)
[19:19:06.930][DJIDeviceInfoEnumera]  78% 15/19 DJI_Vision(5)
[19:19:06.930][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Camera4K_Loader(1:1)
[19:19:06.930][DJIDeviceInfoEnumera]  84% 16/19 Camera4K_Loader(1)
[19:19:08.300][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Gimbal303(4:0)
[19:19:08.300][DJIDeviceInfoEnumera]  89% 17/19 Gimbal303(0)
[19:19:08.300][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Gimbal5223_1(4:1)
[19:19:08.300][DJIDeviceInfoEnumera]  94% 18/19 Gimbal5223_1(1)
[19:19:08.300][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Gimbal5223_2(4:2)
[19:19:08.300][DJIDeviceInfoEnumera] 100% 19/19 Gimbal5223_2(2)
[19:19:08.300][DJIDeviceInfoEnumera] 1860           (8 :1) Ldr : 01.00.10.07 App : 00.00.00.00   DJI P1 SYS
[19:19:08.300][DJIDeviceInfoEnumera] FC_Loader      (3 :5) Ldr : 34.04.00.17 App : 34.04.00.17   07JDD7400101NE
[19:19:08.300][DJIDeviceInfoEnumera] FC             (3 :6) Ldr : 34.04.00.17 App : 03.02.44.07  wm330v2 07JDD7400101NE
[19:19:08.300][DJIDeviceInfoEnumera] Battery0       (11:0) Ldr : 03.04.00.15 App : 02.00.07.30   PHANTOM4_DJIBAT
[19:19:08.300][DJIDeviceInfoEnumera] ESC0           (12:0) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:19:08.300][DJIDeviceInfoEnumera] ESC1           (12:1) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:19:08.300][DJIDeviceInfoEnumera] ESC2           (12:2) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:19:08.300][DJIDeviceInfoEnumera] ESC3           (12:3) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:19:08.300][DJIDeviceInfoEnumera] UltrasonicM0   (8 :4) Ldr : 01.00.00.02 App : 01.00.03.05   WM330_001
[19:19:08.300][DJIDeviceInfoEnumera] Gimbal303      (4 :0) device no reply, request timeout!
[19:19:08.300][DJIDeviceInfoEnumera] Mvo            (17:5) device no reply, request timeout!
[19:19:08.300][DJIDeviceInfoEnumera] Gimbal5223_1   (4 :1) device no reply, request timeout!
[19:19:08.300][DJIDeviceInfoEnumera] Gimbal5223_2   (4 :2) device no reply, request timeout!
[19:19:08.300][DJIDeviceInfoEnumera] 2100           (8 :2) device no reply, request timeout!
[19:19:08.300][DJIDeviceInfoEnumera] Camera4K       (1 :0) device no reply, request timeout!
[19:19:08.300][DJIDeviceInfoEnumera] DJI_Vision     (8 :5) device no reply, request timeout!
[19:19:08.300][DJIDeviceInfoEnumera] OFDM_103       (9 :0) Ldr : 04.09.00.07 App : 04.03.00.00
[19:19:08.301][DJIDeviceInfoEnumera] CPLD           (8 :3) Ldr : 00.00.00.00 App : 01.00.05.06   DJI CPLD
[19:19:08.301][DJIDeviceInfoEnumera] Camera4K_Loader(1 :1) device no reply, request timeout!
[19:19:08.305][DJIFirmPackListRefre] Release Product: 1
[19:19:08.763][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:08.924][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:09.042][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:09.389][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:09.425][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:18.465][DJIBatteryPowerCheck] GetBatteryInfo failed, error code: 224
[19:19:18.485][DJIBatteryPowerCheck]  Battery Power 95
[19:19:18.646][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:18.728][DJIWebFileGetter    ] Downloading [wm330_0900_v04.01.00.00_20170510.pro.fw.sig] 100% 908.54 kB/s
[19:19:18.728][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:18.884][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:19.070][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:19.229][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:19.417][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:19.577][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:19.760][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:19.921][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:20.305][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:20.460][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:20.639][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:20.801][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:21.025][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:21.181][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:21.281][DJIWebFileGetter    ] Downloading [wm330_0306_v03.02.35.06_20170619.pro.fw.sig]  18% 2779.22 kB/s
[19:19:21.387][DJIWebFileGetter    ] Downloading [wm330_0306_v03.02.35.06_20170619.pro.fw.sig]  94% 6959.06 kB/s
[19:19:21.452][DJIWebFileGetter    ] Downloading [wm330_0306_v03.02.35.06_20170619.pro.fw.sig] 100% 5645.49 kB/s
[19:19:21.452][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:21.625][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:21.662][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:21.827][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:21.863][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:22.026][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:22.068][DJIWebFileGetter    ] Downloading [wm330_0400_v01.64.00.82_20170328.pro.fw.sig] 100% 2201.98 kB/s
[19:19:22.068][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:22.416][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:22.517][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]   5% 7747.28 kB/s
[19:19:22.634][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  13% 8779.88 kB/s
[19:19:22.734][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  19% 8930.65 kB/s
[19:19:22.837][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  27% 9523.44 kB/s
[19:19:22.937][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  38% 10679.21 kB/s
[19:19:23.037][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  46% 11016.84 kB/s
[19:19:23.137][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  55% 11262.78 kB/s
[19:19:23.237][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  64% 11450.54 kB/s
[19:19:23.338][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  73% 11583.40 kB/s
[19:19:23.439][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  82% 11708.05 kB/s
[19:19:23.539][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  89% 11671.83 kB/s
[19:19:23.639][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  99% 11887.32 kB/s
[19:19:23.642][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig] 100% 11883.84 kB/s
[19:19:23.643][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:23.883][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:23.930][DJIWebFileGetter    ] Downloading [469a082b...b922692d811c1e93769f6.sig] 100% 4057.18 kB/s
[19:19:23.930][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:24.088][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:24.128][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:24.285][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:24.328][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:24.485][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:24.586][DJIWebFileGetter    ] Downloading [wm330_0802_v02.00.00.07_20170227.pro.fw.sig]  46% 10066.17 kB/s
[19:19:24.668][DJIWebFileGetter    ] Downloading [wm330_0802_v02.00.00.07_20170227.pro.fw.sig] 100% 12001.71 kB/s
[19:19:24.668][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:24.833][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:24.934][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]   1% 10226.49 kB/s
[19:19:25.034][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]   4% 12228.53 kB/s
[19:19:25.134][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]   6% 12415.09 kB/s
[19:19:25.235][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]   8% 12473.96 kB/s
[19:19:25.335][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  10% 12548.23 kB/s
[19:19:25.435][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  12% 12588.40 kB/s
[19:19:25.535][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  14% 12617.13 kB/s
[19:19:25.635][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  16% 12642.23 kB/s
[19:19:25.735][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  18% 12657.05 kB/s
[19:19:25.835][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  20% 12668.91 kB/s
[19:19:25.935][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  22% 12679.91 kB/s
[19:19:26.035][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  24% 12687.89 kB/s
[19:19:26.136][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  27% 12687.09 kB/s
[19:19:26.236][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  29% 12694.43 kB/s
[19:19:26.336][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  31% 12700.79 kB/s
[19:19:26.436][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  33% 12706.36 kB/s
[19:19:26.536][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  35% 12711.28 kB/s
[19:19:26.636][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  37% 12715.65 kB/s
[19:19:26.736][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  39% 12718.81 kB/s
[19:19:26.836][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  41% 12722.37 kB/s
[19:19:26.936][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  43% 12725.59 kB/s
[19:19:27.036][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  45% 12727.87 kB/s
[19:19:27.137][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  47% 12730.58 kB/s
[19:19:27.237][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  50% 12733.05 kB/s
[19:19:27.337][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  52% 12729.11 kB/s
[19:19:27.437][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  54% 12731.45 kB/s
[19:19:27.537][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  56% 12733.10 kB/s
[19:19:27.637][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  58% 12735.13 kB/s
[19:19:27.737][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  60% 12737.51 kB/s
[19:19:27.837][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  62% 12739.73 kB/s
[19:19:27.937][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  64% 12741.81 kB/s
[19:19:28.038][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  66% 12715.01 kB/s
[19:19:28.139][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  68% 12687.27 kB/s
[19:19:28.239][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  70% 12675.72 kB/s
[19:19:28.342][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  72% 12659.65 kB/s
[19:19:28.442][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  74% 12662.48 kB/s
[19:19:28.542][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  76% 12659.04 kB/s
[19:19:28.642][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  78% 12668.44 kB/s
[19:19:28.744][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  81% 12676.31 kB/s
[19:19:28.845][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  83% 12692.59 kB/s
[19:19:28.945][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  85% 12708.07 kB/s
[19:19:29.045][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  87% 12735.94 kB/s
[19:19:29.145][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  89% 12743.44 kB/s
[19:19:29.245][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  92% 12744.18 kB/s
[19:19:29.346][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  94% 12742.68 kB/s
[19:19:29.446][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  96% 12743.40 kB/s
[19:19:29.546][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig]  98% 12744.09 kB/s
[19:19:29.627][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.54_20170629.pro.fw.sig] 100% 12743.61 kB/s
[19:19:29.627][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:30.323][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:19:30.424][DJIWebFileGetter    ] Downloading [wm330_0905_v01.00.01.04_20170527.pro.fw.sig]  68% 9673.07 kB/s
[19:19:30.454][DJIWebFileGetter    ] Downloading [wm330_0905_v01.00.01.04_20170527.pro.fw.sig] 100% 10908.40 kB/s
[19:19:30.454][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:19:30.608][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   0.15 second
[19:19:30.862][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   0.40 second
[19:19:31.111][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   0.65 second
[19:19:31.351][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   0.89 second
[19:19:31.606][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   1.14 second
[19:19:31.850][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   1.39 second
[19:19:32.100][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   1.64 second
[19:19:32.351][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   1.89 second
[19:19:32.601][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   2.14 second
[19:19:32.852][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   2.39 second
[19:19:33.102][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   2.64 second
[19:19:33.356][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   2.89 second
[19:19:33.602][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   3.14 second
[19:19:33.852][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   3.39 second
[19:19:34.101][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   3.64 second
[19:19:34.350][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   3.89 second
[19:19:34.601][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   4.14 second
[19:19:34.851][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   4.39 second
[19:19:35.106][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   4.64 second
[19:19:35.352][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   4.89 second
[19:19:35.601][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   5.14 second
[19:19:35.852][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   5.39 second
[19:19:36.102][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   5.64 second
[19:19:36.351][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   5.89 second
[19:19:36.614][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   6.15 second
[19:19:36.855][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   6.39 second
[19:19:37.101][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   6.64 second
[19:19:37.351][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   6.89 second
[19:19:37.610][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   7.15 second
[19:19:37.852][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   7.39 second
[19:19:38.103][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   7.64 second
[19:19:38.353][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   7.89 second
[19:19:38.606][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   8.15 second
[19:19:38.852][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   8.39 second
[19:19:39.102][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   8.64 second
[19:19:39.351][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   8.89 second
[19:19:39.602][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   9.14 second
[19:19:39.852][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   9.39 second
[19:19:40.102][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   9.64 second
[19:19:40.354][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   9.89 second
[19:19:40.602][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  10.14 second
[19:19:40.860][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  10.40 second
[19:19:41.101][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  10.64 second
[19:19:41.350][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  10.89 second
[19:19:41.600][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  11.14 second
[19:19:41.853][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  11.39 second
[19:19:42.105][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  11.64 second
[19:19:42.364][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  11.90 second
[19:19:42.601][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  12.14 second
[19:19:42.850][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  12.39 second
[19:19:43.115][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  12.65 second
[19:19:43.350][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  12.89 second
[19:19:43.602][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  13.14 second
[19:19:43.850][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  13.39 second
[19:19:44.110][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  13.65 second
[19:19:44.353][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  13.89 second
[19:19:44.602][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  14.14 second
[19:19:44.852][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  14.39 second
[19:19:45.102][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  14.64 second
[19:19:45.353][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  14.89 second
[19:19:45.605][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  15.14 second
[19:19:45.865][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  15.40 second
[19:19:46.101][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  15.64 second
[19:19:46.350][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  15.89 second
[19:19:46.601][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  16.14 second
[19:19:46.853][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  16.39 second
[19:19:47.100][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  16.64 second
[19:19:47.355][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  16.89 second
[19:19:47.600][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  17.14 second
[19:19:47.851][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  17.39 second
[19:19:48.102][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  17.64 second
[19:19:48.351][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  17.89 second
[19:19:48.612][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  18.15 second
[19:19:48.857][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  18.40 second
[19:19:49.106][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  18.65 second
[19:19:49.625][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  19.16 second
[19:19:49.628][DJIFirmwareUpgrader ] Wait [         prepare]   0.00 second
[19:19:49.632][DJIFirmUpgrader2    ] GetUpgradeLog Failed, Error Code: 0
[19:19:49.632][DJIFirmUpgrader2    ] ======================= UPGRADE FAILURE: DoUpgradePrepare Failed, Error Code: 255
[19:19:49.632][DJIFirmUpgrader2    ] ======================= Time :  19.17 second
[19:19:54.921][DJIWebFileGetter    ] [OnFinish]reply statusCode=201
[19:20:07.050][DJIDeviceMgr        ] Refresh DevArrival, Uav, wm330, ,01.00.2567, 8bacaa2b745ab636f8e2ae0d3a9b1f89a980c3f4, normal
[19:20:07.726][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:07.750][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:09.488][DJIDeviceMgr        ] Refresh DevArrival, Uav, wm330, ,01.00.2567, 8bacaa2b745ab636f8e2ae0d3a9b1f89a980c3f4, normal
[19:20:09.520][DJIWebSocketServer  ] No service for [/controller/user_feedback/8bacaa2b745ab636f8e2ae0d3a9b1f89a980c3f4]
[19:20:09.580][DJIFirmPackListRefre] GetDevFirmPackCfgInfo failed!!! target module: 31(0), retcode: 0xe0
[19:20:09.585][DJIDeviceInfoEnumera]   5%  1/19 1860(1)
[19:20:09.586][DJIDeviceInfoEnumera]  10%  2/19 CPLD(3)
[19:20:09.586][DJIDeviceInfoEnumera]  15%  3/19 FC_Loader(5)
[19:20:09.597][DJIDeviceInfoEnumera]  21%  4/19 ESC0(0)
[19:20:09.597][DJIDeviceInfoEnumera]  26%  5/19 UltrasonicM0(4)
[19:20:09.606][DJIDeviceInfoEnumera]  31%  6/19 OFDM_103(0)
[19:20:09.606][DJIDeviceInfoEnumera]  36%  7/19 FC(6)
[19:20:09.607][DJIDeviceInfoEnumera]  42%  8/19 Battery0(0)
[19:20:09.643][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:09.649][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:09.914][DJIDeviceInfoEnumera]  47%  9/19 ESC1(1)
[19:20:10.217][DJIDeviceInfoEnumera]  52% 10/19 ESC2(2)
[19:20:10.534][DJIDeviceInfoEnumera]  57% 11/19 ESC3(3)
[19:20:11.620][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Mvo(17:5)
[19:20:11.620][DJIDeviceInfoEnumera]  63% 12/19 Mvo(5)
[19:20:11.620][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: 2100(8:2)
[19:20:11.620][DJIDeviceInfoEnumera]  68% 13/19 2100(2)
[19:20:11.620][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Camera4K(1:0)
[19:20:11.620][DJIDeviceInfoEnumera]  73% 14/19 Camera4K(0)
[19:20:11.620][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: DJI_Vision(8:5)
[19:20:11.620][DJIDeviceInfoEnumera]  78% 15/19 DJI_Vision(5)
[19:20:11.620][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Camera4K_Loader(1:1)
[19:20:11.620][DJIDeviceInfoEnumera]  84% 16/19 Camera4K_Loader(1)
[19:20:12.990][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Gimbal303(4:0)
[19:20:12.990][DJIDeviceInfoEnumera]  89% 17/19 Gimbal303(0)
[19:20:12.990][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Gimbal5223_1(4:1)
[19:20:12.990][DJIDeviceInfoEnumera]  94% 18/19 Gimbal5223_1(1)
[19:20:13.000][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Gimbal5223_2(4:2)
[19:20:13.000][DJIDeviceInfoEnumera] 100% 19/19 Gimbal5223_2(2)
[19:20:13.000][DJIDeviceInfoEnumera] 1860           (8 :1) Ldr : 01.00.10.07 App : 00.00.00.00   DJI P1 SYS
[19:20:13.000][DJIDeviceInfoEnumera] FC_Loader      (3 :5) Ldr : 34.04.00.17 App : 34.04.00.17   07JDD7400101NE
[19:20:13.000][DJIDeviceInfoEnumera] FC             (3 :6) Ldr : 34.04.00.17 App : 03.02.44.07  wm330v2 07JDD7400101NE
[19:20:13.000][DJIDeviceInfoEnumera] Battery0       (11:0) Ldr : 03.04.00.15 App : 02.00.07.30   PHANTOM4_DJIBAT
[19:20:13.000][DJIDeviceInfoEnumera] ESC0           (12:0) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:20:13.000][DJIDeviceInfoEnumera] ESC1           (12:1) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:20:13.000][DJIDeviceInfoEnumera] ESC2           (12:2) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:20:13.000][DJIDeviceInfoEnumera] ESC3           (12:3) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:20:13.000][DJIDeviceInfoEnumera] UltrasonicM0   (8 :4) Ldr : 01.00.00.02 App : 01.00.03.05   WM330_001
[19:20:13.000][DJIDeviceInfoEnumera] Gimbal303      (4 :0) device no reply, request timeout!
[19:20:13.000][DJIDeviceInfoEnumera] Mvo            (17:5) device no reply, request timeout!
[19:20:13.000][DJIDeviceInfoEnumera] Gimbal5223_1   (4 :1) device no reply, request timeout!
[19:20:13.000][DJIDeviceInfoEnumera] Gimbal5223_2   (4 :2) device no reply, request timeout!
[19:20:13.000][DJIDeviceInfoEnumera] 2100           (8 :2) device no reply, request timeout!
[19:20:13.000][DJIDeviceInfoEnumera] Camera4K       (1 :0) device no reply, request timeout!
[19:20:13.000][DJIDeviceInfoEnumera] DJI_Vision     (8 :5) device no reply, request timeout!
[19:20:13.000][DJIDeviceInfoEnumera] OFDM_103       (9 :0) Ldr : 04.09.00.07 App : 04.03.00.00
[19:20:13.000][DJIDeviceInfoEnumera] CPLD           (8 :3) Ldr : 00.00.00.00 App : 01.00.05.06   DJI CPLD
[19:20:13.000][DJIDeviceInfoEnumera] Camera4K_Loader(1 :1) device no reply, request timeout!
[19:20:13.004][DJIFirmPackListRefre] Release Product: 1
[19:20:13.177][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:13.346][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:13.381][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:13.550][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:13.586][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:18.365][DJIBatteryPowerCheck] GetBatteryInfo failed, error code: 224
[19:20:18.385][DJIBatteryPowerCheck]  Battery Power 94
[19:20:18.540][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:18.798][DJIWebFileGetter    ] Downloading [wm330_0900_v04.03.00.00_20171101.pro.fw.sig]  62% 180.36 kB/s
[19:20:18.800][DJIWebFileGetter    ] Downloading [wm330_0900_v04.03.00.00_20171101.pro.fw.sig] 100% 288.25 kB/s
[19:20:18.800][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:18.956][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:19.001][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:19.348][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:19.385][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:19.549][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:19.587][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:19.749][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:19.787][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:19.945][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:19.982][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:20.137][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:20.176][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:20.331][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:20.504][DJIWebFileGetter    ] Downloading [wm330_0306_v03.02.44.07_20171116.pro.fw.sig]   4% 399.06 kB/s
[19:20:20.597][DJIWebFileGetter    ] Downloading [wm330_0306_v03.02.44.07_20171116.pro.fw.sig] 100% 5524.55 kB/s
[19:20:20.597][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:20.765][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:20.805][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:20.975][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:21.016][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:21.171][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:21.211][DJIWebFileGetter    ] Downloading [wm330_0400_v01.64.00.87_20170803.pro.fw.sig] 100% 2275.78 kB/s
[19:20:21.211][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:21.371][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:21.472][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]   6% 9261.50 kB/s
[19:20:21.572][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  16% 11764.79 kB/s
[19:20:21.672][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  25% 12110.13 kB/s
[19:20:21.772][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  33% 12276.16 kB/s
[19:20:21.872][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  42% 12384.40 kB/s
[19:20:21.972][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  51% 12447.18 kB/s
[19:20:22.072][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  60% 12496.10 kB/s
[19:20:22.172][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  68% 12531.03 kB/s
[19:20:22.272][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  77% 12558.20 kB/s
[19:20:22.372][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  86% 12581.37 kB/s
[19:20:22.472][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig]  95% 12600.33 kB/s
[19:20:22.527][DJIWebFileGetter    ] Downloading [1d13afcdc7b27503f3cf41b4f3c37a67.sig] 100% 12603.45 kB/s
[19:20:22.527][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:22.757][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:22.811][DJIWebFileGetter    ] Downloading [469a082b...b922692d811c1e93769f6.sig] 100% 3597.88 kB/s
[19:20:22.811][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:22.984][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:23.030][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:23.194][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:23.240][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:23.419][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:23.521][DJIWebFileGetter    ] Downloading [wm330_0802_v02.00.00.07_20170227.pro.fw.sig]  49% 10737.81 kB/s
[19:20:23.602][DJIWebFileGetter    ] Downloading [wm330_0802_v02.00.00.07_20170227.pro.fw.sig] 100% 12067.65 kB/s
[19:20:23.602][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:23.770][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:23.871][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]   1% 10498.12 kB/s
[19:20:23.971][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]   3% 12069.49 kB/s
[19:20:24.071][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]   6% 12304.96 kB/s
[19:20:24.171][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]   8% 12429.79 kB/s
[19:20:24.271][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  10% 12507.52 kB/s
[19:20:24.372][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  12% 12552.25 kB/s
[19:20:24.472][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  14% 12566.24 kB/s
[19:20:24.572][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  16% 12592.42 kB/s
[19:20:24.672][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  18% 12615.93 kB/s
[19:20:24.772][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  20% 12636.16 kB/s
[19:20:24.872][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  22% 12650.14 kB/s
[19:20:24.972][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  25% 12662.97 kB/s
[19:20:25.072][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  27% 12671.65 kB/s
[19:20:25.173][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  29% 12675.11 kB/s
[19:20:25.284][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  31% 12684.27 kB/s
[19:20:25.385][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  33% 12621.47 kB/s
[19:20:25.485][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  35% 12566.78 kB/s
[19:20:25.585][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  37% 12534.53 kB/s
[19:20:25.686][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  39% 12501.35 kB/s
[19:20:25.786][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  41% 12486.83 kB/s
[19:20:25.887][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  43% 12474.48 kB/s
[19:20:25.987][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  45% 12474.01 kB/s
[19:20:26.089][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  47% 12484.22 kB/s
[19:20:26.189][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  49% 12501.56 kB/s
[19:20:26.290][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  51% 12502.99 kB/s
[19:20:26.391][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  54% 12514.04 kB/s
[19:20:26.491][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  56% 12542.44 kB/s
[19:20:26.592][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  58% 12563.36 kB/s
[19:20:26.693][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  60% 12572.64 kB/s
[19:20:26.793][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  62% 12590.16 kB/s
[19:20:26.893][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  64% 12631.53 kB/s
[19:20:26.994][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  67% 12647.05 kB/s
[19:20:27.094][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  69% 12653.49 kB/s
[19:20:27.194][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  71% 12657.06 kB/s
[19:20:27.294][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  73% 12660.04 kB/s
[19:20:27.394][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  75% 12664.02 kB/s
[19:20:27.494][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  77% 12667.40 kB/s
[19:20:27.594][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  79% 12670.24 kB/s
[19:20:27.694][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  81% 12673.29 kB/s
[19:20:27.794][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  83% 12675.85 kB/s
[19:20:27.894][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  86% 12678.62 kB/s
[19:20:27.995][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  88% 12680.92 kB/s
[19:20:28.095][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  90% 12680.18 kB/s
[19:20:28.195][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  92% 12683.63 kB/s
[19:20:28.295][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  94% 12685.98 kB/s
[19:20:28.395][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  96% 12687.93 kB/s
[19:20:28.495][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig]  98% 12690.09 kB/s
[19:20:28.555][DJIWebFileGetter    ] Downloading [wm330_0801_v01.00.10.58_20171103.pro.fw.sig] 100% 12689.90 kB/s
[19:20:28.555][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:29.010][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:29.111][DJIWebFileGetter    ] Downloading [wm330_0905_v01.00.01.07_20170929.pro.fw.sig]  32% 9752.95 kB/s
[19:20:29.211][DJIWebFileGetter    ] Downloading [wm330_0905_v01.00.01.07_20170929.pro.fw.sig]  79% 12181.05 kB/s
[19:20:29.316][DJIWebFileGetter    ] Downloading [wm330_0905_v01.00.01.07_20170929.pro.fw.sig]  99% 9965.77 kB/s
[19:20:29.319][DJIWebFileGetter    ] Downloading [wm330_0905_v01.00.01.07_20170929.pro.fw.sig] 100% 9936.79 kB/s
[19:20:29.319][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:29.366][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   0.03 second
[19:20:29.616][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   0.28 second
[19:20:29.868][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   0.53 second
[19:20:30.116][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   0.78 second
[19:20:30.370][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   1.03 second
[19:20:30.627][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   1.29 second
[19:20:30.877][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   1.54 second
[19:20:31.117][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   1.78 second
[19:20:31.378][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   2.04 second
[19:20:31.616][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   2.28 second
[19:20:31.872][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   2.54 second
[19:20:32.117][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   2.78 second
[19:20:32.373][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   3.04 second
[19:20:32.617][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   3.28 second
[19:20:32.870][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   3.54 second
[19:20:33.117][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   3.78 second
[19:20:33.367][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   4.03 second
[19:20:33.622][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   4.29 second
[19:20:33.871][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   4.54 second
[19:20:34.130][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   4.80 second
[19:20:34.377][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   5.04 second
[19:20:34.620][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   5.28 second
[19:20:34.877][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   5.54 second
[19:20:35.130][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   5.80 second
[19:20:35.367][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   6.03 second
[19:20:35.618][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   6.28 second
[19:20:35.876][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   6.54 second
[19:20:36.128][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   6.79 second
[19:20:36.372][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   7.04 second
[19:20:36.617][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   7.28 second
[19:20:36.877][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   7.54 second
[19:20:37.116][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   7.78 second
[19:20:37.367][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   8.03 second
[19:20:37.616][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   8.28 second
[19:20:37.868][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   8.53 second
[19:20:38.116][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   8.78 second
[19:20:38.367][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   9.03 second
[19:20:38.629][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   9.29 second
[19:20:38.872][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   9.54 second
[19:20:39.117][DJIFirmwareUpgrader ] Wait [   enter_upgrade]   9.78 second
[19:20:39.377][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  10.04 second
[19:20:39.619][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  10.28 second
[19:20:39.869][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  10.53 second
[19:20:40.118][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  10.78 second
[19:20:40.377][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  11.04 second
[19:20:40.622][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  11.29 second
[19:20:40.867][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  11.53 second
[19:20:41.116][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  11.78 second
[19:20:41.367][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  12.03 second
[19:20:41.617][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  12.28 second
[19:20:41.880][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  12.55 second
[19:20:42.117][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  12.78 second
[19:20:42.367][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  13.03 second
[19:20:42.620][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  13.28 second
[19:20:42.866][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  13.53 second
[19:20:43.131][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  13.80 second
[19:20:43.371][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  14.04 second
[19:20:43.628][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  14.29 second
[19:20:43.867][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  14.53 second
[19:20:44.122][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  14.79 second
[19:20:44.366][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  15.03 second
[19:20:44.617][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  15.28 second
[19:20:44.866][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  15.53 second
[19:20:45.120][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  15.78 second
[19:20:45.368][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  16.03 second
[19:20:45.630][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  16.30 second
[19:20:45.870][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  16.53 second
[19:20:46.117][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  16.78 second
[19:20:46.367][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  17.03 second
[19:20:46.617][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  17.28 second
[19:20:46.870][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  17.53 second
[19:20:47.127][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  17.79 second
[19:20:47.367][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  18.03 second
[19:20:47.621][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  18.29 second
[19:20:47.866][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  18.53 second
[19:20:48.116][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  18.78 second
[19:20:48.617][DJIFirmwareUpgrader ] Wait [   enter_upgrade]  19.28 second
[19:20:48.619][DJIFirmwareUpgrader ] Wait [         prepare]   0.00 second
[19:20:48.624][DJIFirmUpgrader2    ] GetUpgradeLog Failed, Error Code: 0
[19:20:48.624][DJIFirmUpgrader2    ] ======================= UPGRADE FAILURE: DoUpgradePrepare Failed, Error Code: 255
[19:20:48.624][DJIFirmUpgrader2    ] ======================= Time :  19.29 second
[19:20:53.676][DJIDeviceMgr        ] Refresh DevArrival, Uav, wm330, ,01.00.2567, 8bacaa2b745ab636f8e2ae0d3a9b1f89a980c3f4, normal
[19:20:53.830][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:53.836][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:55.514][DJIDeviceMgr        ] Refresh DevArrival, Uav, wm330, ,01.00.2567, 8bacaa2b745ab636f8e2ae0d3a9b1f89a980c3f4, normal
[19:20:55.535][DJIWebSocketServer  ] No service for [/controller/user_feedback/8bacaa2b745ab636f8e2ae0d3a9b1f89a980c3f4]
[19:20:55.604][DJIFirmPackListRefre] GetDevFirmPackCfgInfo failed!!! target module: 31(0), retcode: 0xe0
[19:20:55.608][DJIDeviceInfoEnumera]   5%  1/19 FC_Loader(5)
[19:20:55.609][DJIDeviceInfoEnumera]  10%  2/19 1860(1)
[19:20:55.610][DJIDeviceInfoEnumera]  15%  3/19 CPLD(3)
[19:20:55.618][DJIDeviceInfoEnumera]  21%  4/19 ESC0(0)
[19:20:55.619][DJIDeviceInfoEnumera]  26%  5/19 UltrasonicM0(4)
[19:20:55.627][DJIDeviceInfoEnumera]  31%  6/19 FC(6)
[19:20:55.635][DJIDeviceInfoEnumera]  36%  7/19 ESC1(1)
[19:20:55.647][DJIDeviceInfoEnumera]  42%  8/19 OFDM_103(0)
[19:20:55.647][DJIDeviceInfoEnumera]  47%  9/19 Battery0(0)
[19:20:55.670][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:55.676][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:55.937][DJIDeviceInfoEnumera]  52% 10/19 ESC2(2)
[19:20:56.235][DJIDeviceInfoEnumera]  57% 11/19 ESC3(3)
[19:20:57.639][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Mvo(17:5)
[19:20:57.639][DJIDeviceInfoEnumera]  63% 12/19 Mvo(5)
[19:20:57.639][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: 2100(8:2)
[19:20:57.639][DJIDeviceInfoEnumera]  68% 13/19 2100(2)
[19:20:57.639][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Camera4K(1:0)
[19:20:57.639][DJIDeviceInfoEnumera]  73% 14/19 Camera4K(0)
[19:20:57.639][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: DJI_Vision(8:5)
[19:20:57.639][DJIDeviceInfoEnumera]  78% 15/19 DJI_Vision(5)
[19:20:57.639][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Camera4K_Loader(1:1)
[19:20:57.639][DJIDeviceInfoEnumera]  84% 16/19 Camera4K_Loader(1)
new initialization
log:  before_init -> before_init, cam: 0, m_cnt:0
log:  enter P4Calibration::run() main loop
log:  pattern resolution: 1558x1028
log:  current resolution: 1920x1080
        recommand pix w: 1920, pix h: 1080
log:  guess screen diag inch: 21.540615
log:  before_init -> initialization, cam: 0, m_cnt:0
------------- cam init ret: 0 --------------
log:  init failed, cam open retcode: 21
P4Calibration::run, 1095 open camera fail, ret code: 211
err:  open camera fail:211
log:  initialization -> before_init, cam: 0, m_cnt:0
[19:20:58.990][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Gimbal303(4:0)
[19:20:58.990][DJIDeviceInfoEnumera]  89% 17/19 Gimbal303(0)
[19:20:58.990][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Gimbal5223_1(4:1)
[19:20:58.990][DJIDeviceInfoEnumera]  94% 18/19 Gimbal5223_1(1)
[19:20:58.990][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Gimbal5223_2(4:2)
[19:20:58.990][DJIDeviceInfoEnumera] 100% 19/19 Gimbal5223_2(2)
[19:20:58.990][DJIDeviceInfoEnumera] 1860           (8 :1) Ldr : 01.00.10.07 App : 00.00.00.00   DJI P1 SYS
[19:20:58.990][DJIDeviceInfoEnumera] FC_Loader      (3 :5) Ldr : 34.04.00.17 App : 34.04.00.17   07JDD7400101NE
[19:20:58.990][DJIDeviceInfoEnumera] FC             (3 :6) Ldr : 34.04.00.17 App : 03.02.44.07  wm330v2 07JDD7400101NE
[19:20:58.990][DJIDeviceInfoEnumera] Battery0       (11:0) Ldr : 03.04.00.15 App : 02.00.07.30   PHANTOM4_DJIBAT
[19:20:58.990][DJIDeviceInfoEnumera] ESC0           (12:0) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:20:58.990][DJIDeviceInfoEnumera] ESC1           (12:1) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:20:58.990][DJIDeviceInfoEnumera] ESC2           (12:2) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:20:58.990][DJIDeviceInfoEnumera] ESC3           (12:3) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:20:58.990][DJIDeviceInfoEnumera] UltrasonicM0   (8 :4) Ldr : 01.00.00.02 App : 01.00.03.05   WM330_001
[19:20:58.990][DJIDeviceInfoEnumera] Gimbal303      (4 :0) device no reply, request timeout!
[19:20:58.990][DJIDeviceInfoEnumera] Mvo            (17:5) device no reply, request timeout!
[19:20:58.990][DJIDeviceInfoEnumera] Gimbal5223_1   (4 :1) device no reply, request timeout!
[19:20:58.990][DJIDeviceInfoEnumera] Gimbal5223_2   (4 :2) device no reply, request timeout!
[19:20:58.990][DJIDeviceInfoEnumera] 2100           (8 :2) device no reply, request timeout!
[19:20:58.990][DJIDeviceInfoEnumera] Camera4K       (1 :0) device no reply, request timeout!
[19:20:58.990][DJIDeviceInfoEnumera] DJI_Vision     (8 :5) device no reply, request timeout!
[19:20:58.990][DJIDeviceInfoEnumera] OFDM_103       (9 :0) Ldr : 04.09.00.07 App : 04.03.00.00
[19:20:58.990][DJIDeviceInfoEnumera] CPLD           (8 :3) Ldr : 00.00.00.00 App : 01.00.05.06   DJI CPLD
[19:20:58.990][DJIDeviceInfoEnumera] Camera4K_Loader(1 :1) device no reply, request timeout!
[19:20:58.994][DJIFirmPackListRefre] Release Product: 1
[19:20:59.170][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:59.335][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:59.370][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:20:59.525][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:20:59.563][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
new initialization
new initialization
new initialization
new initialization
new initialization
new initialization
new initialization
[19:21:09.945][DJIDeviceMgr        ] Refresh DevArrival, Uav, wm330, ,01.00.2567, 8bacaa2b745ab636f8e2ae0d3a9b1f89a980c3f4, normal
[19:21:10.102][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:21:10.107][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:21:12.869][DJIDeviceMgr        ] Refresh DevArrival, Uav, wm330, ,01.00.2567, 8bacaa2b745ab636f8e2ae0d3a9b1f89a980c3f4, normal
[19:21:12.890][DJIWebSocketServer  ] No service for [/controller/user_feedback/8bacaa2b745ab636f8e2ae0d3a9b1f89a980c3f4]
[19:21:12.983][DJIFirmPackListRefre] GetDevFirmPackCfgInfo failed!!! target module: 31(0), retcode: 0xe0
[19:21:12.987][DJIDeviceInfoEnumera]   5%  1/19 FC_Loader(5)
[19:21:12.987][DJIDeviceInfoEnumera]  10%  2/19 1860(1)
[19:21:12.989][DJIDeviceInfoEnumera]  15%  3/19 CPLD(3)
[19:21:12.998][DJIDeviceInfoEnumera]  21%  4/19 UltrasonicM0(4)
[19:21:12.998][DJIDeviceInfoEnumera]  26%  5/19 ESC0(0)
[19:21:13.007][DJIDeviceInfoEnumera]  31%  6/19 FC(6)
[19:21:13.008][DJIDeviceInfoEnumera]  36%  7/19 Battery0(0)
[19:21:13.015][DJIDeviceInfoEnumera]  42%  8/19 ESC1(1)
[19:21:13.024][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:21:13.027][DJIDeviceInfoEnumera]  47%  9/19 OFDM_103(0)
[19:21:13.031][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:21:13.318][DJIDeviceInfoEnumera]  52% 10/19 ESC2(2)
[19:21:13.615][DJIDeviceInfoEnumera]  57% 11/19 ESC3(3)
[19:21:15.010][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Mvo(17:5)
[19:21:15.010][DJIDeviceInfoEnumera]  63% 12/19 Mvo(5)
[19:21:15.010][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: 2100(8:2)
[19:21:15.010][DJIDeviceInfoEnumera]  68% 13/19 2100(2)
[19:21:15.010][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Camera4K(1:0)
[19:21:15.010][DJIDeviceInfoEnumera]  73% 14/19 Camera4K(0)
[19:21:15.010][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: DJI_Vision(8:5)
[19:21:15.010][DJIDeviceInfoEnumera]  78% 15/19 DJI_Vision(5)
[19:21:15.010][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Camera4K_Loader(1:1)
[19:21:15.010][DJIDeviceInfoEnumera]  84% 16/19 Camera4K_Loader(1)
[19:21:16.370][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Gimbal303(4:0)
[19:21:16.370][DJIDeviceInfoEnumera]  89% 17/19 Gimbal303(0)
[19:21:16.370][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Gimbal5223_1(4:1)
[19:21:16.370][DJIDeviceInfoEnumera]  94% 18/19 Gimbal5223_1(1)
[19:21:16.370][DJIDeviceInfoEnumera] QueryDeviceVersion Timeout, Fail Dev: Gimbal5223_2(4:2)
[19:21:16.370][DJIDeviceInfoEnumera] 100% 19/19 Gimbal5223_2(2)
[19:21:16.370][DJIDeviceInfoEnumera] 1860           (8 :1) Ldr : 01.00.10.07 App : 00.00.00.00   DJI P1 SYS
[19:21:16.370][DJIDeviceInfoEnumera] FC_Loader      (3 :5) Ldr : 34.04.00.17 App : 34.04.00.17   07JDD7400101NE
[19:21:16.370][DJIDeviceInfoEnumera] FC             (3 :6) Ldr : 34.04.00.17 App : 03.02.44.07  wm330v2 07JDD7400101NE
[19:21:16.370][DJIDeviceInfoEnumera] Battery0       (11:0) Ldr : 03.04.00.15 App : 02.00.07.30   PHANTOM4_DJIBAT
[19:21:16.370][DJIDeviceInfoEnumera] ESC0           (12:0) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:21:16.370][DJIDeviceInfoEnumera] ESC1           (12:1) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:21:16.370][DJIDeviceInfoEnumera] ESC2           (12:2) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:21:16.370][DJIDeviceInfoEnumera] ESC3           (12:3) Ldr : 01.01.00.00 App : 01.08.00.07   WM330_EV1
[19:21:16.370][DJIDeviceInfoEnumera] UltrasonicM0   (8 :4) Ldr : 01.00.00.02 App : 01.00.03.05   WM330_001
[19:21:16.370][DJIDeviceInfoEnumera] Gimbal303      (4 :0) device no reply, request timeout!
[19:21:16.370][DJIDeviceInfoEnumera] Mvo            (17:5) device no reply, request timeout!
[19:21:16.370][DJIDeviceInfoEnumera] Gimbal5223_1   (4 :1) device no reply, request timeout!
[19:21:16.370][DJIDeviceInfoEnumera] Gimbal5223_2   (4 :2) device no reply, request timeout!
[19:21:16.370][DJIDeviceInfoEnumera] 2100           (8 :2) device no reply, request timeout!
[19:21:16.370][DJIDeviceInfoEnumera] Camera4K       (1 :0) device no reply, request timeout!
[19:21:16.371][DJIDeviceInfoEnumera] DJI_Vision     (8 :5) device no reply, request timeout!
[19:21:16.371][DJIDeviceInfoEnumera] OFDM_103       (9 :0) Ldr : 04.09.00.07 App : 04.03.00.00
[19:21:16.371][DJIDeviceInfoEnumera] CPLD           (8 :3) Ldr : 00.00.00.00 App : 01.00.05.06   DJI CPLD
[19:21:16.371][DJIDeviceInfoEnumera] Camera4K_Loader(1 :1) device no reply, request timeout!
[19:21:16.374][DJIFirmPackListRefre] Release Product: 1
[19:21:16.734][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:21:17.092][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:21:17.127][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:21:17.284][DJIWebFileGetter    ] [OnFinish]reply statusCode=302
[19:21:17.320][DJIWebFileGetter    ] [OnFinish]reply statusCode=200
[19:21:30.814][                    ] release class DJIIdentifierInterface<class DJISecondIdentifier>
[19:21:30.814][                    ] Release DJIIdentifier.
[19:21:30.815][                    ] release class DJIIdentifierInterface<class DJIGeneralIdentifier>
[19:21:30.815][                    ] Release DJIIdentifier.
[19:21:30.815][DJISecondIdentifier_] release class DJIIdentifierInterface<class DJISecondIdentifier>
[19:21:30.815][DJISecondIdentifier_] Release DJIIdentifier.
[19:21:30.836][DJISerialIo         ] Free COM3 success!
2018-11-12
Kirk R
DontFlyHigh Posted at 2018-7-5 11:53
Hello, I think I'm having the same issue with my Phantom 4 firmware update to v02.00.0700. It keeps stopping at 55% every time I try to update.
Not sure if you remember this since it has been about 3 years since you posted, but did you replace the wide but very thin cable that says "3 IN 1" on one end and "CAMERA" on the other end?
I'm thinking I might buy a replacement for that cable to see if it fixes my issue.
2021-4-15
