Litchi waypoint mission disconnect
1843 6 2018-6-29
flyingbosnian
Flight distance : 360522 ft
Bulgaria
Hi everyone, I was wondering if you had some experi3nce with this. The other day my MPP disconnected for the first time during a Litchi waypoint mission and I wasn't able to reconnect video for the remainder of the flight. It reconnected with the remote shortly after losing signal and I was able to land the bird visually but couldn't see anything from the camera.
Is this normal for signal loss during the waypoint mission?
The week before I lost connection while using Litchi in normal mode but the video came back as soon as RTH kicked in and the drone flew back in range.
Is this something specific to the waypoint mode or just a freak coincidence?
Thanks for your thoughts...
2018-6-29
Hi, sorry for the inconvenience. We cannot speak on behalf of Litchi since it is not our software. If you have issues with your DJI Go 4 app, we are happy to help you.
2018-6-29
Suren
Flight distance : 13498560 ft
What distance were you when you disconnected
2018-6-29
flyingbosnian
Bulgaria
Suren Posted at 2018-6-29 09:12
I was about 2 km away
2018-7-1
Suren
I also have disconnect issues with Litchi on the Pro at around the same distance. Some have mentioned going much further but with Litchi but I have found that the same route that I have flown with Go4 and getting over 3.5km with Litchi is very limited and signal drop to under 41% is very fast
2018-7-1
If your on a Litchi mission, and you lose RC signal or video signal, Litchi will continue the mission , will not RTH unless it reaches its max distance, it can be a bit disconcerting , but that’s how it works. Your program is into the drone not the RC, If you just lose video signal you can just switch to sport and back to P mode, this will pause the drone stop the mission and you can fly manually back or hit RTH and it will RTH .
In normal mode Litchi flight is the very same as djigo 4 so loss of signal can be set to hover or RTH .
2018-7-1
Ahmed Hussain
Flight distance : 1339761 ft
Kuwait
Once I lost the video and the signal during waypoints mission at the last 300 meters and the MPP returend back to home and landed still without signal and video.
I only turned off and on the controller and they were back again.
2018-7-1
