Aircraft disconnected
1152 9 2018-7-15
djilover10
Flight distance : 63225 ft
I was flying my drone. Suddenly, the live view went blank and showed aircraft disconnected. The remote control went to solid red. However, the remote control was still piloting the drone. What probably happened? It did keep saying strong interferences.
2018-7-15
Peterx
Flight distance : 1499708 ft
What area have you chosen for the flight? Was a strong EM field near the area?
2018-7-15
Rene Jensen
maybe try to relink ac to rc again the led on rc should always be solid green
2018-7-15
DJI Natalia
Hi there, thanks for reaching out DJI Forum. Can you please try to re-link your remote controller to your aircraft? then connect the device and open DJI Go app again. May I also know what device are you using? Please make sure that your device is compatible with the drone. Please see the attached image below for compatible devices on Phantom 3 standard. If you have any other concern, please let us know. Thank you.
2018-7-16
djilover10
DJI Natalia Posted at 2018-7-16 06:40
I use the iPod 6g which is better than the iPad mini 3.
2018-7-16
djilover10 Posted at 2018-7-16 09:32
Hi, thanks for reaching DJI Forum. We do apologize if you are having issues with your DJI aircraft. Unfortunately, the iPod 6G is not fully supported to run the DJI Go 4 app. Are you having issues with the iPad mini 3?
2018-7-16
djilover10
DJI Gamora Posted at 2018-7-16 10:11
I don’t have an iPad mini 3. The iPod 6g has a more powerful processor. I am using the original dji go with my p3 standard. I have already relinked once not that long ago. I will try again. I also have my antenna perpendicular to the aircraft and everything is fully charged. I downgraded to the 1.8 firmware because 1.9 was awful. Don’t worry I am not mad or upset.
2018-7-16
Hi, apologies I thought you have also the iPad mini 3. Just in case you are still having issues, don't hesitate to reach us. We're here to help.
2018-7-16
P3KoYoT
Flight distance : 1846667 ft
It happend to me once but it was for sure due to strong interference. I fly and record RC Glider working on 2.4GHz. Other flight in same location without any trouble. My Firmware is the newest one.
2018-7-18
Texas-Mark
Flight distance : 23002 ft
Make sure your device stays on wifi and/or is not auto switching to another wifi if the signal drops momentarily or it will cause a disconnected message.  The remote will still work.
2018-7-18
