New Spark Firmware Release Notes (07/19/2018)
2146005504 2146005504 2018-7-18
Locationscout_Bavaria
Flight distance : 62201 ft
Locationscout_Bavaria Posted at 2018-7-20 09:47
I was brave today and updated AC, RC and app. Thank you for OTG Support DJI. The app is in german now. Tomorrow I will make further tests, but so far everything went fine. Firmware update with assistant was successfull, too. Big relief.
After testing I have problems with the system as followed.
no map is showing up in the mapwindow, no homepoint is recorded (missing voice)
and
now videfeed is stored on my Android phone (its on SD Card, but not on phone)
any advice is apprecitated.
2018-7-22
Macaulayjuan 4
Flight distance : 865469 ft
Updated, no issues. IOS
2018-7-22
nixuspix
Flight distance : 2864974 ft
Latvia
Locationscout_Bavaria Posted at 2018-7-22 03:52
If i understand you correctly, the dji go4 app was the last you've been updated, but it should be updated first to 4.2.21 on Android or to 4.2.22 on ios and then rest things have to be updated.
2018-7-22
RGMGFitness
Flight distance : 233757 ft
Glad things are looking better now for everyone with Android Phones.  Looks like there is no benefit for me to upgrade as I have an iPhone and have been running the SPARK for months WITHOUT use of the OTG Cable (which I actually like) and the connection is rock solid without use of the OTG cable.  Again, I'm here in the USA which is different than what others experience outside of the USA.
If it aint' broke..don't fix it.
2018-7-22
czechmark01
Flight distance : 1101673 ft
Updated without issue - IOS.
2018-7-22
fans812df717
Flight distance : 1092280 ft
Updated firmware and flew with android and OTG cable. No issues whatsoever for the time being....
2018-7-22
nixuspix Posted at 2018-7-22 06:02
think you´re right. I updated firmware first to .1000. So would you suggest to go back (I was on 701) delete the app on the phone, then install app again, then do the firmware update back 1000. ?
Thank you for answering me.
2018-7-22
nixuspix
Latvia
Locationscout_Bavaria Posted at 2018-7-22 10:16
It is difficult for me to answer precisely, but if the RC is upgraded to correct version, don't touch it. But as for the drone, downgrade may be to 0900, but using DJI Assistant, remove DJI go4 completely and install it from the scratch and then install latest firmware to Spark, using DJI Assitant again.
2018-7-22
nixuspix Posted at 2018-7-22 10:37
i will give it a try tomorrow and give report. Thank you.
2018-7-22
macropoutsis
Flight distance : 32139 ft
Locationscout_Bavaria Posted at 2018-7-22 10:43
Good luck to you
2018-7-22
Shoonay
Flight distance : 591831 ft
Shoonay Posted at 2018-7-19 08:54
Upgraded to the new firmware without problems, restarted RC and drone, flew the drone a bit but had to change the bettery quickly cause the update process drained it before.
Started from hand, while waiting for the GPS to link in I flew the drone a few meters back with the controller and than my connection died.
Few more flights and no such problems so far, seems it was a one-time issue that went away after the restart of the smartphone itself.
2018-7-22
djiuser_OxW1VTmR6473
Indonesia
This update bricked my RC successfully. Any way to fix this? RC firmware rollback maybe? Really apreciate any good advice. Thanks!
2018-7-22
mark murray
hello , I updated the firmware and everything went fine . but now my rc isn't seen by my phone or any other device .. it seems the update has bricked it..  just brought it to my servicecenter and they told me this can happen sometimes.. wtf
what can I do ?
2018-7-23
djiuser_UDKDQ5Xp8Vbz
Flight distance : 292612 ft
The video tutorial at the start of this thread is about how to update the firmware with DJI GO4 with a phone and the Spark AirCraft.  Could someone (or DJI) please post a video tutorial of how to do a firmware update for the Spark Aircraft as well as the Remote Controller?!!  It seems that there are many cases of the Remote Controller becoming bricked as a result of people trying to do the firmware update.  I have read that the OTG cable should not be plugged in?  What is the proper sequence?  Should we follow the the current video and update the firmware in the Spark Aircraft first (without the Remote Controller), turn off everything and then restart everything and this time connect to the remote controller to update?  Or should we connect the Spark Aircraft and the Remote Controller and the phone all at the same time to update the firmware???  I think many people here would love to hear from those of you who have successfully updated the firmware with your Spark AirCraft, Remote Controller and Android Phone.  Looking forward to hear from you!  Thanks.
2018-7-23
AdamM
Flight distance : 87408 ft
DJI Support are idiots...they don't know anything about update and products!!!!
2018-7-23
spookster
Flight distance : 419649 ft
mark murray Posted at 2018-7-23 01:29
what can I do ?
if the rc is in warranty and otherwise good shape (to be sure it is no drop damage) try to get it replaced.
2018-7-23
Sparky_17
Flight distance : 62349 ft
updated my spark, and it doesn't seem to have any additional features.  I'm on IOS so the android additions don't affect me.
2018-7-23
fansf72809a3
Flight distance : 42605 ft
Was able to connect to my drone with cable, only to have rc start flashing red after a couple seconds. Still can’t connect to WiFi at all
2018-7-23
Stray Cat
Flight distance : 35502 ft
Updated AC and Controller. With OTG connected, Video display is very clear and no longer stutters even with heavy panning.
2018-7-23
djiuser_BqhuX360EG1R
Flight distance : 16440 ft
Guys I updated the firmaware and remote. All good. How do I know if the OTG is working. I tried switching off wifi but lost connection. Do we have to do something special? Does anyone have a video on how to connect using OTG.
2018-7-23
Hi guys i updated and all is good. How do i know that the OTG is working?
2018-7-23
fansf72809a3
fansf72809a3 Posted at 2018-7-23 10:42
Downgraded my firmware to fix DJI’s poor update. Only cost me a day of vacation time.
2018-7-23
Ronnie.Choy
Flight distance : 1261211 ft
djiuser_BqhuX360EG1R Posted at 2018-7-23 17:06
Did you connect the OTG cable between the phone and the RC?
If you have done that, and the DJI Go 4 app is not connected to the RC, your OTG is not working.
2018-7-23
Ronnie.Choy Posted at 2018-7-23 19:30
I did , Thing is, do I have to change my setting on the android or something? I tried turning on usb debugging to no avail.  Any ideas. Did you do it and it worked right away?
2018-7-24
PRock
Flight distance : 15344 ft
djiuser_BqhuX360EG1R Posted at 2018-7-24 03:48
perhaps your USB-connection is on 'charging', so search in the settings for USB and check this
2018-7-24
Bobdsjr
Flight distance : 70312 ft
Updated Last Friday Night 7/20/18 no issues updating. OTG works continuously Connected. Power down spark and Change batteries and the app reconnects flawlessly. Connect cable first to RC then Tablet( Galaxy Tab A 2017), turn on RC and the Go4 opens on the tablet. Flew 3 1/2 batteries on Saturday 7/21/18 only issue was would not save to local cache because it was full. Cleared out the cache and problem went away.
2018-7-24
Ronnie.Choy
I am using iPhone .... I just plug in the OTG cable and need not change any settings or whatever. But as usual the phone will display that the accessory (OTG cable) is not supported and I just ignored it.
Hope you can find a solution soon and happy flying.
2018-7-24
Charliejspark
Flight distance : 286654 ft
It's fascinating how the same upgrade can have such different results for so many people from 'all working fine' to 'disaster'!  I assume that this must be the different devices used rather than the Spark update.
For me partial success on mobile (Samsung S7) and disaster on tablet (Samsung 10.1)
2018-7-24
RonnyRenneR
Flight distance : 3724 ft
When we can shoot 25p?
24p also!
2018-7-25
S.J
Flight distance : 322454 ft
Kuwait
Charliejspark Posted at 2018-7-24 23:14
i believe the SPARK software is  developed by more than one team. Therefore so may variations of the software code and resulting hardware issues are seen.
2018-7-25
S.J
Kuwait
djiuser_UDKDQ5Xp8Vbz Posted at 2018-7-23 01:49
there is no such thing as bricked on a SPARK OR the RC. We just need to do the procedure again.
2018-7-25
Charliejspark
S.J Posted at 2018-7-25 01:58
Aah.
2018-7-25
Nate The Great
I'm on vacation with limited internet and my RC update failed now it refuses to connect to Wi-Fi. It only flys with the phone and it sucks! Anything I can do?
2018-7-25
adriank
Flight distance : 106558 ft
Dear DJI Support. Is there a safe description how to enter OTG. I am running a Samsung Galaxy S8+ with the newest GO4 App and all updated. Do I need to go in developper mode on my android? Do I need to use USB debugging? etc.?
2018-7-26
RGMGFitness
It's all in the details.  For example, all this needs to work together and there are some many possible variations.  Plus, new codes/version coming out on each of these platforms.  Sometimes it's amazing it works at all.
Phone Type:  Android | iPhone
Phone Models:  Apple iPhone 6S | LG G7
Phone Software Versions:  IOS 11.4.1 (Newest IOS) vs IOS 11.2
DJI GO4 App Versions:   4.2.2  vs 4.2.6 (etc)
Spark Firmware Version:
Remote Controller Firmware Version
Country of Origin:  USA, China, Spain, etc.
Federal Communications Commission (FCC in USA) vs European Commission (CE in Europe)
Operating Frequencies:  2.4 GHz vs 5.7-5.8 GHz (impacts transmission distances)
2018-7-26
BerkoZg
Flight distance : 2628 ft
Croatia
djiuser_BqhuX360EG1R Posted at 2018-7-23 17:08
In my case. Android User. I turn on Spark and RC. When led indicator on RC stop blinking red and goes on still green (rc connected with spark) then i plug in OTG cable. Wait for couple of seconds and djigo app starts automaticaly with otg connected (wifi is off btw).
2018-7-26
chrisdutton
Flight distance : 14511 ft
I downloaded the latest firmware and had loads of issues. I was told to put the app on my phone to 4.2.16. Do I need to change the firmware on my controller now and on the drone? If so, how do I do this?
2018-7-27
DJT_MVSP
Flight distance : 2018645 ft
How do I update the RC using DJI assistant? My PC just charges the RC and doesn't seem to recognize it. The Mavic's RC can be recognized though, just not the Spark's.
2018-7-27
BeastMaster_101
Flight distance : 1082992 ft
小仙女的星巴克 Posted at 2018-7-19 06:10
Updated successfully using DJI assistance. Then rebooted and connected OTG on my Essential Phone Android P. Setting check latest firmware need update. Updated Remote controller to 600. During updating RC beep constantly till it's done. Long time didn't fly Spark lol cos love my MA. I will fly the Spark later.
ya the remote beeped during the entire update for me as well
2018-7-27
Noble797
S.J Posted at 2018-7-25 02:00
I do not agree, if can’t connect to a device to repair/downgrade than it is bricked. The is exactly what happening with the rc’s.
2018-7-28
