Astro Sapphire
As you have mentioned it has been shot with the internal memory, It seems the issue is with the camera settings. if you have shot this in auto mode, there are reasons the ISO can be taken way higher on its own. The video will be more blurry when ISO is set high. Make sure that you put the camera in auto mode and set the ISO to 100 (anything above that will be blurry) as with there is no aperture to control in Mavic air you can first take off the flight about 10 feet height and set the shutter speed. People often say shutter speed is to be double with the frame rate. As there is no aperture if you set it double the video will be bleached out. You can play around with the shutter speed and check out various possibilities. Along side, I would recommend buying a memory card which has high-speed rate more than 12.5mb/s. Hope this resolves. |
