horizon on the return video was not level
888 9 2018-8-27
chichid
Flight distance : 3675 ft
Hello,  I made some pictures with my inspire 2, and I found on the rushes that the horizon on the return video was not level, he leaned. There was some wind on the day of the shots, but not much. I used the Olympus Zuico 45 mm lens with a variable filter. The basket was normally well balanced. A solution of settings exists to have a balanced level of the image. Thank you!Best regards, R.Houanoh
2018-8-27
MRTN.photo
Flight distance : 1395259 ft
Yeah, I noticed similar issues, not sure this is wind related as it happened also under average conditions. Especially when you turn the gimbal it will become rather obvious. I've no idea where this came from, I didn't notice it before the update with the POI...
2018-8-27
Rodger8
Flight distance : 20145135 ft
I have the same issue with the same lens doing still shots. I am going to try a gimbal calibration.
2018-8-27
DJI Wanda
Hi. We apologize for the inconvenience. Did you try to calibrate the gimbal?
2018-8-27
chichid
No change after calibrating the gimbal and the IMU...
2018-8-29
DJI Wanda
chichid Posted at 2018-8-29 03:39
Do you have a sample photo showing the problem?
2018-8-29
chichid
2018-8-29
DJI Wanda
May I know what camera are you using? Did you also installed a balancing ring?
2018-8-29
chichid
I used a compatible Olympus 45mm zuico well balanced with a filter Gobe, as recommended
2018-8-29
DJI Wanda
chichid Posted at 2018-8-29 07:32
I see. If that's the case, we highly suggest to send it to our repair facility to have it check. You may start up a case online: repair.dji.com or send an email to support.nl@dji.com.
2018-8-30
