fans3c343695
Flight distance : 5066562 ft
I came across that company on my LinkedIn feed.
Figured I would add it here in case anyone else was wondering about close quarters flight protection, but glad to see you already had.
As well, another drone I have is called the Elios made by Flyability based out of Switzerland.
Their drone is a lot more expensive -$23,000.00 USD.
But their position control is pretty good.
As well another company I know of - Emesent, based out of Australia, have removed the need for a cage all together, by implementing active Lidar scanning to their position control.
The Active Lidar gives 2 benefits, 1 the position control, and 2 you can use the Lidar scan for 3d modeling.
If your in mining like myself, you can send the drone down the drift and not only will the active lidar prevent a collision, but it will also map a 3d mesh for you.
